2nd Dimming Expansion Module
PostPosted: Mon Feb 26, 2018 5:57 pm
:) Yep, LOL,I figured you were going to ask me that... The RA* is in one room and the module is screwed to the mounting board in another... with the 72" heat sink and lights.
I'll un-mount the module and use my multi-meter to check for voltage.
Try to learn something about everything and everything about something... Thomas Huxley
210gal DT | 50gal sump/refug | Jebao DCP 10000 pump | RO 200-int skimmer | DIY built stand | DIY 160 led, 12 channel, 458 watt, on MakersLED 72" heatsink
PostPosted: Mon Feb 26, 2018 6:23 pm
With 0x41 attached to the RA* and the below code:
    // 16 channelPWM testing
    ReefAngel.PWM.Set16ChannelRaw(0,369);
    ReefAngel.PWM.Set16ChannelRaw(1,1107);
    ReefAngel.PWM.Set16ChannelRaw(2,1845);
    ReefAngel.PWM.Set16ChannelRaw(3,2583);
I get the following:
ch 0 - 0.43v
ch 1 - 1.33v
ch 2 - 2.24v
ch 3 - 3.14v
ch 4 - 0.0v
ch 5 - 0.0v
You still have any of those 16ch dimming modules left?
PostPosted: Mon Feb 26, 2018 6:57 pm
So, that means the module is working fine as well as your code.
The only thing left is the communication from RA* to the cloud wifi hub.
I have to check, but I'm almost sure I didn't include it.
I'll check it later tonight after I put my kid to sleep.
It's feeding time now :)
PostPosted: Mon Feb 26, 2018 7:02 pm
Dude, no hurry. I understand the night time feedings; got five kids and did most of them late nighters... wonderful time as I remember it.
PostPosted: Tue Feb 27, 2018 9:00 am
Yes, the 16ch is confirmed not to be in the publishing of variables.
It would take a change in the libraries for this to work.
I think the best would be to just add this to your own code and it would take a bit of patience to get this completed.
Do you want to give it a try?
I can get the code started for you to test.
PostPosted: Tue Feb 27, 2018 11:44 am
Yes, please. I would love to do this.
I was also serious when I asked if you had any 16ch modules left? Some of the things I'm thinking of doing with my lights, I'm thinking, would be easier with a single 16ch module as opposed to two 6ch modules.
PostPosted: Tue Feb 27, 2018 11:55 am
Those modules were only 0-5V PWM signal.
What drivers are you using?
PostPosted: Tue Feb 27, 2018 12:05 pm
Meanwell LDD-1000H and LDD-700H.
PostPosted: Tue Feb 27, 2018 12:24 pm
I think those are 0-5V PWM, right?
If that is the case, I can make one for you, but it takes a few weeks and it does not come with a plastic enclosure.
It would be about $89.
PM me if interested.
PostPosted: Tue Feb 27, 2018 12:33 pm
That's correct; 0-5V PWM for those drivers.
A few weeks, $89, and a PM. Got it.
Return to How do I code ...
Users browsing this forum: Majestic-12 [Bot] and 3 guests
