feedmode delay
Posted: Thu Jun 07, 2018 4:27 pm
by troylong45
update..fixxed
delay return only after feed mode
//C First X sec after feeding mode disable return
    static time_t FMTimer=0;
    if (ReefAngel.DisplayedMenu == FEEDING_MODE) FMTimer=now();
    if (now()-FMTimer >= 0 && now()-FMTimer < 300))//300 is secs
    {ReefAngel.Relay.Off(RETURN);}else{ReefAngel.Relay.On(RETURN);}
Re: feedmode delay
Posted: Sat Jun 09, 2018 11:45 am
Have you looked at the DelayedOn() function in the libraries? That would be my suggestion on where to start. (I have not read/looked through your code you posted yet. I just wanted to give you a reference place to start first.)
Re: feedmode delay
Posted: Sat Jun 09, 2018 12:50 pm
by troylong45
i just found a fix i thought i deleated this post oups
