skimmer code help
PostPosted: Sat Jun 09, 2018 12:38 pm
im trying to get this to work for me .
i want when the float active then skimmer is auto,on or delayedon to override
when the float is deactive it turns off but when active again it turns back to auto,on or delayedon to override
im doing this
if(ReefAngel.HighATO.IsActive()!=1){ReefAngel.Relay.Override(SKIMMER,0);} else {ReefAngel.Relay.Override( SKIMMER,2 );}
and it is ignoring the relay off for waterchangemode,feedmode but the delayon is working
full code
        // Define Custom Memory Locations
        #define Mem_B_AtoHourInterval     101    //MB101
        #define Mem_B_LightsOffPerc       102    //MB102
        #define Mem_I_ReturnDelay         103    //MI103
void init_memory() {
         // Initialize Custom Memory Locations
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //MB101 "(Mem_B_AtoHourInterval,X)"X=hour
          InternalMemory.write(Mem_B_LightsOffPerc,0);         //MB102
          InternalMemory.write(Mem_I_ReturnDelay,300);         //MI103 "(Mem_I_ReturnDelay,X)"X=sec
         // Define Relay Ports by Name
    #define AUTOTOPOFF        1
    #define SKIMMER           2
    #define BLUELED           3
    #define WHITELED          4
    #define HEATER            5
    #define POWERHEAD         6
    #define FAN               7
    #define RETURN            8
    //dimmingchannel call out
    // 0    blue led channel
    // 1    white led channel
    // 2
    // 3
    // 4    powerhead left
    // 5    powerhead right
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit ;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit ;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit ;
    ReefAngel.OverheatShutoffPorts = Port5Bit ;
//    ReefAngel.Relay.On( SKIMMER );
    ReefAngel.Relay.On( POWERHEAD );
    ReefAngel.Relay.On( FAN );
    ReefAngel.Relay.On( RETURN );
    // Ports that are delayed on
    ReefAngel.Relay.DelayedOn( SKIMMER );
    ReefAngel.SingleATO(true, AUTOTOPOFF , InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
    ReefAngel.StandardHeater ( HEATER );
//REMOVE    ReefAngel.DCPump.DaylightChannel = None;
//REMOVE    ReefAngel.DCPump.ActinicChannel = None;
//REMOVE    ReefAngel.DCPump.ExpansionChannel[0] = None;
//REMOVE    ReefAngel.DCPump.ExpansionChannel[1] = None;
//REMOVE    ReefAngel.DCPump.ExpansionChannel[2] = None;
//REMOVE    ReefAngel.DCPump.ExpansionChannel[3] = None;
    ReefAngel.DCPump.ExpansionChannel[4] = Sync;
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
//if ( ReefAngel.HighATO.IsActive() == 1 ) {ReefAngel.Relay.Override( SKIMMER,2 );} else {ReefAngel.Relay.Off( SKIMMER );}
//REMOVE    if ( ReefAngel.HighATO.IsActive() != 1 ) ReefAngel.Relay.Off( SKIMMER );
//C blue led relay port 3/BLUELED +dimming channel 0
if (ReefAngel.PWM.GetChannelValue(0) >  InternalMemory.read(Mem_B_LightsOffPerc)) {
   // Value over MB102
   ReefAngel.Relay.On(BLUELED);
   // otherwise, value IS MB102 or less (which should never happen)
   ReefAngel.Relay.Off(BLUELED);
//C white led relay port 4/WHITELED +dimming channel 1
    if (ReefAngel.PWM.GetChannelValue(1) >  InternalMemory.read(Mem_B_LightsOffPerc)) {
   // Value over MB102
   ReefAngel.Relay.On(WHITELED);
   ReefAngel.Relay.Off(WHITELED);
//C First X minutes after feeding mode disable return
    static time_t FMTimer=0;
    if (ReefAngel.DisplayedMenu == FEEDING_MODE) FMTimer=now();
    if (now()-FMTimer >= 0 && now()-FMTimer < InternalMemory.read(Mem_I_ReturnDelay))
    {ReefAngel.Relay.Off(RETURN);}else{ReefAngel.Relay.On(RETURN);}
    ReefAngel.Portal( "troylong45" );
PostPosted: Sat Jun 09, 2018 3:37 pm
the On function overrides the DelayedOn function.
you should remove the DelayedOn call right before the if statement. then I would replace the On with DelayedOn.
the way your statement reads is if the condition is true it's on, otherwise it's off. you want it to be DelayedOn if it's going to be on.
PostPosted: Sat Jun 09, 2018 3:40 pm
just re-read your original question, my answer is only part right. you need to have a more complex if statement with other clauses to get your full answer. the way your code is, the float switch controls the port.
PostPosted: Sat Jun 09, 2018 3:43 pm
binder wrote:just re-read your original question, my answer is only part right. you need to have a more complex if statement with other clauses to get your full answer. the way your code is, the float switch controls the port.
I came up with a new code and working but it is ignoreing relay off when feed/water change mode
I just updated the above post
I also can not manualy turn the relay off .
PostPosted: Sun Jun 10, 2018 8:02 am
yes, when you use the Override function, it ignores the feed and water change settings. in fact, it ignores all programmed settings and uses whatever setting is overridden with.
PostPosted: Sun Jun 10, 2018 12:43 pm
I'm at a loss to code this i tryed lol I even been searching all day. I thought i got close since it did everything but letting me manualy change it or the feed mode,wc off mode, if i take the else off it does everything besides reset its self to auto when the float reactives but I use it as a level monitor for sump to turn off and on the skimmer when the water raises for feed mode but then I also want it as a fail safe if some how the water raised with out feed mode
Its only the else part that's the issue I'm trying to think of something to fix that
Return to How do I code ...
