RA* Unable to Update via Remote Upload
PostPosted: Sat Sep 29, 2018 7:07 pm
Let me check the server log and see what the request looked like.
PostPosted: Sun Sep 30, 2018 9:41 pm
I couldn't find any log.
Maybe the server doesn't log this type of error.
I don't know what to make out of this.
Does it get disconnected from the cloud server too?
PostPosted: Mon Oct 01, 2018 4:38 am
No
PostPosted: Sun Oct 07, 2018 5:07 pm
Any further thoughts on this?
PostPosted: Mon Oct 08, 2018 2:35 pm
Not sure.
I don't understand how it stays connected when you are monitoring by itself and not when you bring downstairs.
PostPosted: Mon Oct 08, 2018 4:44 pm
The unit says connected and I can do things like turn on/off ports and clear alerts through my phone. The problem is that for some reason it stops connecting to the Portal after some time which prohibits me from sending remote uploads and receiving any email alerts or updates to the Portal. There is no difference on where it is located.
The reference to taking it downstairs had to do with troubleshooting. I originally thought the problem was where it was connected, thinking it was a networking issue. I proved that wrong by setting up the monitor and verifying that the device was logging a 400 error after some time. I left the monitor on for 24 hours and it never reconnected to the portal after the 400 errors started.
PostPosted: Mon Oct 08, 2018 10:53 pm
I am wondering if it does the same with a very basic code with just the cloudportal function.
PostPosted: Tue Oct 09, 2018 8:06 am
Let me know if you want me to test something
PostPosted: Tue Oct 09, 2018 9:26 am
Try running a new code with just the cloudportal function and monitor.
PostPosted: Tue Oct 23, 2018 10:49 pm
I uploaded the following to the RA*:
ReefAngel.Star();
ReefAngel.Network.Cloud();
After leaving it on the monitor for nearly 24 hours it looks like everything is going through fine. Here's my first and last monitor logs.
Connecting...
Connected
HTTP/1.1 200 OK
Content-Type: text/html; charset=UTF-8
Server: Microsoft-IIS/8.5
X-Powered-By: PHP/5.6.24
Date: Mon, 22 Oct 2018 23:53:10 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
Portal Call
Data Sent
HTTP/1.1 200 OK
Cache-Control: private
Content-Type: text/html; charset=utf-8
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Date: Tue, 23 Oct 2018 06:58:08 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Portal Call
Data Sent
HTTP/1.1 200 OK
Date: Wed, 24 Oct 2018 05:42:50 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Date: Tue, 23 Oct 2018 22:42:53 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
So it looks like something with the code is causing the problem. What should my next steps be?
PreviousNext
Return to How do I code ...
