RA* Unable to Update via Remote Upload
Posted: Fri Jul 20, 2018 12:39 pm
I've got my RA* up and running with the exception of being able to update the code via Remote Upload through the wizard.
Here's my code:
- The unit is showing connected to the cloud
I'm able to check the status and turn ports on/off through uapp
If I connect via a com port on my PC I can upload code
Here's my code:
ReefAngel.Star();
ReefAngel.FeedingModePortsE[0] = Port2Bit | Port8Bit;
ReefAngel.FeedingModePortsE[1] = 0;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePortsE[1] = 0;
ReefAngel.OverheatShutoffPortsE[0] = Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[1] = 0;
ReefAngel.LightsOnPortsE[1] = 0;
ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,83 );//Alk
ReefAngel.SingleATO( true,Box1_Port2,1000,0 );//ATO
ReefAngel.DosingPumpRepeat( Box1_Port3,30,60,82 );//Cal
ReefAngel.StandardHeater( T1_PROBE,Box1_Port4,780,785 );
ReefAngel.StandardLights( Box1_Port6,12,0,19,0 ); //T5
ReefAngel.StandardLights( Box1_Port7,23,0,6,0 ); //Refugium Lights
ReefAngel.PWM.SetDaylight( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetDaylight2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.PWM.SetActinic2( PWMSlope( 9,0,17,0,15,70,60,0 ) );
ReefAngel.DCPump.SetMode( LongPulse,80,60000 );
ReefAngel.DCPump.Daylight2Channel = AntiSync;
ReefAngel.DCPump.Actinic2Channel = None;
boolean buzzer=false;
if ( ReefAngel.isATOTimeOut() ) buzzer=true;
if ( ReefAngel.isOverheat() ) buzzer=true;
static unsigned long feeding;
//feeding mode nutrient transport time
if (now()-feeding<3600) {
ReefAngel.DCPump.SetMode(NutrientTransport,100,4000);
//vacation mode
if (hour()==17 && minute()==0 && second()==0)
ReefAngel.FeedingModeStart();
if (hour() > 21 || hour() < 7)
ReefAngel.DCPump.SetMode( Lagoon,60,10 );
if (hour() >= 8 || ReefAngel.Params.PH > 860)
ReefAngel.Relay.Off (Box1_Port1);
ReefAngel.Relay.Off (Box1_Port3);
ReefAngel.Network.Cloud();
