RA* Unable to Update via Remote Upload
PostPosted: Tue Sep 11, 2018 5:49 pm
<RA>
<ID>ReefingHavoc</ID>
<T1>0</T1>
<T2>0</T2>
<T3>0</T3>
<PH>852</PH>
<R>0</R>
<RON>0</RON>
<ROFF>255</ROFF>
<R1>144</R1>
<RON1>0</RON1>
<ROFF1>255</ROFF1>
<R2>0</R2>
<RON2>0</RON2>
<ROFF2>255</ROFF2>
<R3>0</R3>
<RON3>0</RON3>
<ROFF3>255</ROFF3>
<R4>0</R4>
<RON4>0</RON4>
<ROFF4>255</ROFF4>
<R5>0</R5>
<RON5>0</RON5>
<ROFF5>255</ROFF5>
<R6>0</R6>
<RON6>0</RON6>
<ROFF6>255</ROFF6>
<R7>0</R7>
<RON7>0</RON7>
<ROFF7>255</ROFF7>
<R8>0</R8>
<RON8>0</RON8>
<ROFF8>255</ROFF8>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>1</EM>
<EM1>6</EM1>
<REM>1</REM>
<BID>4</BID>
<AF>0</AF>
<SF>0</SF>
<PWMA>0</PWMA>
<PWMD>80</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<PWMA2>0</PWMA2>
<PWMD2>0</PWMD2>
<PWMA2O>255</PWMA2O>
<PWMD2O>255</PWMD2O>
<DCM>4</DCM>
<DCS>80</DCS>
<DCD>100</DCD>
<DCT>30</DCT>
<LEAK>0</LEAK>
<ALARM>0</ALARM>
<PWME0>0</PWME0>
<PWME0O>255</PWME0O>
<PWME1>0</PWME1>
<PWME1O>255</PWME1O>
<PWME2>0</PWME2>
<PWME2O>255</PWME2O>
<PWME3>0</PWME3>
<PWME3O>255</PWME3O>
<PWME4>0</PWME4>
<PWME4O>255</PWME4O>
<PWME5>0</PWME5>
<PWME5O>255</PWME5O>
</RA>
PostPosted: Tue Sep 11, 2018 5:51 pm
More came through on the monitor:
Portal Call
Data Sent
HTTP/1.1 200 OK
Cache-Control: private
Content-Type: text/html; charset=utf-8
Server: Microsoft-IIS/8.5
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Date: Wed, 12 Sep 2018 00:19:33 GMT
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Content-Type: text/html; charset=UTF-8
X-Powered-By: PHP/5.6.24
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
PostPosted: Tue Sep 11, 2018 5:57 pm
Ok, so whatever you did a while ago made the controller connect to the portal.
status/chart.aspx?id=ReefingHavoc&filter=ph
You can see that it started sending data about half hour ago.
So, you should be able to set your email alerts now.
Try doing the remote upload again.
PostPosted: Sun Sep 16, 2018 5:50 pm
Thought I'd close the loop on this. I had my connection running through a patch panel that was connected to a AT&T U-verse router. I did some troubleshooting to determine where the problem was as when I connected the RA* directly to a Netgear router, everything seemed to work. Patch panel and all connections turned out to be fine. Tried running the patch panel to the Netgear instead of U-verse and miraculously I'm able to able to now upload remotely and updates hitting the portal. Strange...
PostPosted: Tue Sep 18, 2018 2:41 pm
ReefingHavoc wrote:Thought I'd close the loop on this. I had my connection running through a patch panel that was connected to a AT&T U-verse router. I did some troubleshooting to determine where the problem was as when I connected the RA* directly to a Netgear router, everything seemed to work. Patch panel and all connections turned out to be fine. Tried running the patch panel to the Netgear instead of U-verse and miraculously I'm able to able to now upload remotely and updates hitting the portal. Strange...
I guess it was too good to be true. I haven't touched the RA* since Sunday, but it looks like it stopped communicating yesterday (see attached)
PostPosted: Thu Sep 20, 2018 4:13 pm
Any thoughts on what is going on? The unit will connect for short periods of time and all of a sudden stop updating to the portal (still shows connected on the unit). I've tried swapping out power cables, ethernet cables, connecting to different routers, observing traffic through a serial monitor. Just today the unit had a black screen and unresponsive to touch. I had to reboot it by unplugging and when it did, saw that the temperature in the tank dropped by 3 degrees. The RA+ was rock solid for years; not sure why I'm having so many issues.
PostPosted: Sat Sep 22, 2018 9:30 am
When you were watching the monitor, what did you get when it was not communicating?
PostPosted: Sat Sep 22, 2018 10:41 am
rimai wrote:When you were watching the monitor, what did you get when it was not communicating?
I had it connected to a monitor for a couple hours and did not see issues, but when I plugged it back in to the power supply it stopped updating shortly after. I'll run a monitor on it for 24hrs to see what happens. The problem has been that my tank is in the basement and my PC is on the first floor so I have to disconnect the RA* from my system to monitor. I'll figure out how to keep it connected to the system with monitoring in place.
Thanks for the follow up
Mike
PostPosted: Sun Sep 23, 2018 7:33 pm
I ran the monitor for 24 hours and did capture a 400 error at the time the Portal stopped being updated.
Data: 0
Header: 0
Disconnected
Portal Call
Data Sent
HTTP/1.1 200 OK
Date: Sun, 23 Sep 2018 14:20:17 GMT - This is the time when Portal last updated
Connection: close
Content-Length: 4
DoneDisconnected
Connecting...
Connected
HTTP/1.1 200 OK
Date: Sun, 23 Sep 2018 14:20:18 GMT
Connection: close
Content-Length: 0
Data: 0
Header: 0
Disconnected
Portal Call
Actinic 2Data Sent
Actinic 2HTTP/1.1 400 Bad Request
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Date: Sun, 23 Sep 2018 14:25:18 GMT
Connection: close
Content-Length: 311
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request</h2>
<hr><p>HTTP Error 400. The request is badly formed.</p>
</BODY></HTML>
ÿDisconnected
Actinic 2Connecting...
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:25:19 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Disconnected
Actinic 2Portal Call
Actinic 2Data Sent
Date: Sun, 23 Sep 2018 14:30:19 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:30:20 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Data Sent
Date: Sun, 23 Sep 2018 14:35:20 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:35:21 GMT
Connection: close
Content-Length: 339
Data: 339
Actinic 2Header: 0
Actinic 2Data Sent
Date: Sun, 23 Sep 2018 14:40:21 GMT
Connection: close
Content-Length: 311
</BODY></HTML>
ÿDisconnected
Actinic 2Connected
Date: Sun, 23 Sep 2018 14:40:22 GMT
Connection: close
Content-Length: 339
The 400 error captured repeats until 6 PM EST when I disconnected the monitor
PostPosted: Fri Sep 28, 2018 12:07 pm
Any thoughts on the 400 error?
Return to How do I code ...
