Timed ports not working....
Posted: Tue Aug 07, 2018 12:50 am
Hello
I'm trying to setup a CO2 solenoid to turn on between 12:00 and 19:00.
I have an RA Plus.
I used the Wizard via the web plugin and created my basic code using internal memory.
I used the Timed Schedule option to setup the port.
It didn't turn on and off
I used the Android App to change the on/off times using StdLights On/Off in the memory tab and had no luck.
I have control over the relay via the the phone app and the Local web interface.
So I figured what the heck..... try code it and see if I can do it - spoiler alert...I have failed
Can you guys help me trouble shoot the Timed Schedule and grade my attempt at coding as well
I have defined my ports and labelled them like this so I can make sense of my code -
This sits under the #include right at the start.
And I have Defined labels for the head unit to match..
I setup this at the top as a block (I find it easier to read the code) as attempt 1
Attempt1 ripped from your guys forum replies..
So then I tried to flip the thinking
I also tried the same thing with different format (I put each hour argument in its own brackets)...
It will toggle the relay on but not off.
If I flip the < and > logic it turns the relay off and that's it. it seems to ignore the "second half".
So I thought..... aha.....I need an "else".
Bring on...
But it had the same issue if I use it with the && option or the || option.
I also commented out
to check if that was messing with it.
What am I missing?
I have an RA Plus.
#define Return Port1
#define Osmolater Port2
#define Heater Port3
#define RW4 Port4
#define SumpPump Port5
#define Doser Port6
#define GasPump Port7 // I originally had this labelled CO2 but thought it might be the cause of the issue
#define Fans Port8
ReefAngel.CustomLabels[0]="Return";
ReefAngel.CustomLabels[1]="ATO";
ReefAngel.CustomLabels[2]="Heater";
ReefAngel.CustomLabels[3]="RW4";
ReefAngel.CustomLabels[4]="SumpPump";
ReefAngel.CustomLabels[5]="Doser";
ReefAngel.CustomLabels[6]="GasPump";
ReefAngel.CustomLabels[7]="Fans";
void GasPumpTimer() //Timer for CO2 Relay until I get the std light timer working
if (hour()>=12 && hour()<19)
ReefAngel.Relay.On (GasPump);
if (hour()<12 || hour()>=19)
ReefAngel.Relay.Off (GasPump);
if ((hour()<12) || (hour()>=19))
Bring on...
ReefAngel.Relay.On(GasPump);
ReefAngel.Relay.On( GasPump );
What am I missing?
