Water Level ATO Delay
PostPosted: Mon Sep 24, 2018 10:41 pm
I should know this, but I'm either too slow or too tired to make it work. How can I add in a delay so that my water level ATO will only run once per hour?
My code:
ReefAngel.FeedingModePorts = Port1Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardFan( Port1,784,800 );
ReefAngel.StandardHeater( Port2,775,780 );
ReefAngel.StandardLights( Port3,21,0,7,0 );
ReefAngel.StandardHeater( Port6,774,780 );
ReefAngel.WaterLevelATO( Port7,3600,95,100 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.StandardLights( Box1_Port1,8,30,20,0 );
ReefAngel.StandardLights( Box1_Port2,8,0,21,0 );
ReefAngel.StandardLights( Box1_Port3,8,30,20,0 );
ReefAngel.StandardLights( Box1_Port4,8,0,21,0 );
ReefAngel.DosingPumpRepeat( Box1_Port6,0,60,80 );
ReefAngel.DosingPumpRepeat( Box1_Port8,30,60,90 );
ReefAngel.DCPump.SetMode( LongPulse,50,10 );
ReefAngel.DCPump.ExpansionChannel[0] = None;
if(ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Override(Port8,0);
ReefAngel.Relay.On(Port8);
int repeat=2880; // in minutes
int runtime=3600; // in seconds
static time_t t;
// Manual mode
if (ReefAngel.Relay.isMaskOn(Box1_Port5)) {
ReefAngel.Relay.Auto(Box1_Port5);
t=now();
if (now()-t < runtime) {
ReefAngel.Relay.On(Box1_Port5);
} else {
ReefAngel.DosingPumpRepeat(Box1_Port5,0,repeat,runtime);
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.On(Port3);
ReefAngel.Portal( "redacted" );
PostPosted: Tue Sep 25, 2018 1:49 pm
I'm looking at the libraries and I don't think it has ever been implemented.
PostPosted: Tue Sep 25, 2018 7:37 pm
How long would you want it to run each hour? The easiest way is to say to run it for 10 minutes at the top of each hour.
if (now()%3600<600) ReefAngel.WaterLevelATO(...);
PostPosted: Wed Sep 26, 2018 9:29 am
Thanks for checking and replying! I really just want to be able to tell it to run only once per hour or once per half hour. For example. If the water surface has a ripple to it the ATO will keep going on and off with the waves. I don't like the relay and pump having to turn on and off so many times unnecessarily. I was sure that I used to have that code in place, but maybe not?
Ted
Return to How do I code ...
