Water Level ATO Delay
Posted: Mon Sep 24, 2018 10:41 pm
I should know this, but I'm either too slow or too tired to make it work. How can I add in a delay so that my water level ATO will only run once per hour?
My code:
ReefAngel.FeedingModePorts = Port1Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardFan( Port1,784,800 );
ReefAngel.StandardHeater( Port2,775,780 );
ReefAngel.StandardLights( Port3,21,0,7,0 );
ReefAngel.StandardHeater( Port6,774,780 );
ReefAngel.WaterLevelATO( Port7,3600,95,100 );
ReefAngel.Relay.DelayedOn( Port8,10 );
ReefAngel.StandardLights( Box1_Port1,8,30,20,0 );
ReefAngel.StandardLights( Box1_Port2,8,0,21,0 );
ReefAngel.StandardLights( Box1_Port3,8,30,20,0 );
ReefAngel.StandardLights( Box1_Port4,8,0,21,0 );
ReefAngel.DosingPumpRepeat( Box1_Port6,0,60,80 );
ReefAngel.DosingPumpRepeat( Box1_Port8,30,60,90 );
ReefAngel.DCPump.SetMode( LongPulse,50,10 );
ReefAngel.Relay.Override(Port8,0);
ReefAngel.Relay.On(Port8);
int repeat=2880; // in minutes
int runtime=3600; // in seconds
static time_t t;
// Manual mode
if (ReefAngel.Relay.isMaskOn(Box1_Port5)) {
ReefAngel.Relay.Auto(Box1_Port5);
t=now();
if (now()-t < runtime) {
ReefAngel.Relay.On(Box1_Port5);
} else {
ReefAngel.DosingPumpRepeat(Box1_Port5,0,repeat,runtime);
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.On(Port3);
ReefAngel.Portal( "redacted" );
My code:
static time_t t;
// Manual mode
t=now();
} else {
