How to cycle power to 4 wave pumps?
PostPosted: Thu Feb 28, 2019 9:29 pm
I have the reef angel plus controller with 2 relay expansions. Currently i am using internal memory.
I have the wave maker setup to cycle every 180 seconds. I am using standard wave pumps plugged into ports 5-6 on both relay expansions.
Right now they all turn on/off at the same time. Is there any way for me to have them cycle randomly? If not randomly then at least cycle on a set time, as long as they do not all go on/off at the same time. That kind of defeats the purpose.
Can this be done at all with internal memory?
PostPosted: Fri Mar 01, 2019 12:32 am
Can you post your code?
PostPosted: Fri Mar 01, 2019 9:11 am
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.DayLights( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.MoonLights( Port3 );
ReefAngel.MoonLights( Port4 );
ReefAngel.WavemakerRandom1(Port5,60,180); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.WavemakerRandom2(Port6,60,180); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
// Port 5 and 6 are not synchronized.
// They work independent of each other at random times.
ReefAngel.WaterLevelATO( Port7 );
ReefAngel.Relay.DelayedOn( Box1_Port2 );
ReefAngel.StandardHeater( Box1_Port4 );
ReefAngel.WavemakerRandom1(Box1_Port5,60,180); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.WavemakerRandom2(Box1_Port6,60,180); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
ReefAngel.MoonLights( Box1_Port7 );
ReefAngel.Portal( "" );
ReefAngel.DDNS( "" ); // Your DDNS is
PostPosted: Fri Mar 01, 2019 11:06 am
I see 4 pumps.
Do you want just 1 on and 3 off at a time?
So, each stays on for 45 seconds with a total of 180 seconds?
PostPosted: Fri Mar 01, 2019 12:54 pm
I would really like for them to cycle. Not all turn off/on at the same time like its been doing.
Based on the comments in the code
It sounds like they should cycle at random times, or maybe i am misunderstanding it.
Right now all 4 pumps turn off/on at at exactly the same time.
PostPosted: Fri Mar 01, 2019 12:57 pm
Elaborate please. What is cycle for you?
Give me exactly what you want the ports to do.
PostPosted: Fri Mar 01, 2019 1:00 pm
rimai wrote:Elaborate please. What is cycle for you?
Is it possible to randomize each wave maker ports 'on' and 'off' duration? Like between 60-180 seconds?
So they will each turn on and off independently at a random time between 60-180 seconds.
I hope i am making sense. And thank you for responding.
PostPosted: Fri Mar 01, 2019 1:09 pm
I suppose i can modify these settings?
To different times and load it into the unit. It will use the times i set for each but will not turn on/off randomly within the times set?
Also will i be able to still use internal memory?
What confuses me is this:
Try this:
ReefAngel.Relay.Set(Port5,now()%180<random(60,120));
ReefAngel.Relay.Set(Port6,now()%180<random(60,120));
ReefAngel.Relay.Set(Box1_Port5,now()%180<random(60,120));
ReefAngel.Relay.Set(Box1_Port6,now()%180<random(60,120));
PostPosted: Fri Mar 01, 2019 1:11 pm
Thanks Roberto,
Will i need to disable internal memory?
Next
Return to How do I code ...
