awesome ideas! I'll keep messing with the ReefAngel.cpp for now, but look forward to this change!binder wrote:Having the GetDisplayedMenu() function to be able to process the menu would work for custom menus but those modes are slightly different than other scenarios since the controller is displaying a different screen and still processing requests from other stuff. I'm going to have to move the feeding and water change mode stuff to their own function. Then, process the main default_menu (main screen) stuff inside ShowInterface and then allow the user to handle the other 2 modes (feeding and water change) in their own function defined inside their PDE just like with CustomMain. Then they would have to handle the feeding mode or water change mode if they want along with whatever menu items they create. If they want the default options then they could just call the default function and be done with it.
This is all just a thought right now.
Auto Water Change
Re: Auto Water Change
Maybe my idea was a little vague and caused confusion.
Here is the code I tried and worked for me
I just turned DisplayedMenu into public for the purposes of testing.
// Autogenerated file by RAGen (v1.0.4.92), (06/14/2011 20:55)
// RA_061411_2055.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte LastDisplayedMenu=0;
ReefAngel.WaterChangePorts=B10000000;
ReefAngel.Relay.On(Port8);
ReefAngel.Timer[4].SetInterval(3);
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE && LastDisplayedMenu != ReefAngel.DisplayedMenu) ReefAngel.Timer[4].Start();
LastDisplayedMenu=ReefAngel.DisplayedMenu;
if (ReefAngel.Timer[4].IsTriggered()) ReefAngel.Relay.RelayMaskOff|=1<<(Port8-1);
thanks Roberto, I'll have to try that to see if it will work with the menu!
Curt, so you're saying while this mode is running, the stats from my tank wouldn't be reported to the banner?
If you have your own function that everything is contained in and the controller stays in it for the duration of the mode (say you have everything contained in a WaterChangeFunction()) then yes.alexwbush wrote:thanks Roberto, I'll have to try that to see if it will work with the menu!
But if you do what Roberto showed then no.
As long as the main loop keeps running and you still encounter the code that sends your banner stats then you will be fine.
I'm getting errors from adding in the code Roberto posted...
My code:
Errors:
My code:
// Autogenerated file by RAGen (v1.0.4.92), (05/08/2011 17:03)
// RA_050811_1703.pde
#define DisplayImages - ok
#define WavemakerSetup - ok
#define DateTimeSetup - ok
#define ATOSetup - ok, but probably not needed since the ato timeouts are not used
#define MetalHalideSetup - ok
#define DirectTempSensor - ok
#define RelayExp - ok
#define SingleATOSetup - ok, but probably not needed since the single ato function isn't used
#define StandardLightSetup -ok
#define CUSTOM_MAIN - ok
#define COLORS_PDE - ok
//Custom colors
#include <ReefAngel_Colors.h>
#define Box1_Port1 11 Fuge LED
#define Box1_Port2 12 Carbon Reactor
#define Box1_Port3 13
#define Box1_Port4 14 Vortech
#define Box1_Port5 15 WC Heater
#define Box1_Port6 16 WC Pump
#define Box1_Port7 17 Actinic LED
#define Box1_Port8 18
// Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2, "Alex's Cube");
ReefAngel.LCD.DrawMonitor(15, 63, ReefAngel.Params,
ReefAngel.PWM.GetDaylightValue(),
ReefAngel.PWM.GetActinicValue());
// draw main relay
#ifdef RelayExp
// draw 1st expansion relay
#endif // RelayExp
ReefAngel.LCD.DrawGraph(5, 10);
/*Need to set these up still
//ReefAngel.FeedingModePorts = B10101000;
//ReefAngel.WaterChangePorts = B10000010;
//ReefAngel.WaterChangePorts = B00000001;
//ReefAngel.OverheatShutoffPorts = B00000110;
ReefAngel.Relay.On(Port8); //Fuge LED
ReefAngel.Relay.On(Port5); //Vortech
ReefAngel.Relay.On(Box1_Port3); //Sump
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
ReefAngel.Timer[4].SetInterval(3); //start timer for water change menu
//water change menu
// Have PWM on from 12p to 23p, with gradual 60 minute ramp up and down starting at the given times
// From 12p to 1p, the Actinic PWM will slowly ramp from 15% to 50%
// From 22p to 23p, the Actinic PWM will slowly ramp from 50% to 15%
ReefAngel.PWM.SetActinic(PWMSlope(12,0,23,30,15,50,60,ReefAngel.PWM.GetActinicValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(13,0,22,30,15,50,60,ReefAngel.PWM.GetDaylightValue()));
if ((NumMins(hour(now()),minute(now())) < NumMins(12,0)) || (NumMins(hour(now()),minute(now())) > NumMins(23,0)))
ReefAngel.PWM.SetDaylight(15);
ReefAngel.PWM.SetActinic(15);
// Specific functions
// ReefAngel.SingleATOHigh(Port1);
ReefAngel.Relay.On(Port3); //WC Pump
ReefAngel.Relay.On(Box1_Port7); //ATO
if(ReefAngel.HighATO.IsActive()==false)
ReefAngel.Relay.Off(Port3); //WC Pump
ReefAngel.Relay.Off(Box1_Port7); //ATO
if(ReefAngel.LowATO.IsActive())
ReefAngel.DelayedOn(Box1_Port4, 1); //Skimmer Delayed on
if(ReefAngel.LowATO.IsActive()==false)
ReefAngel.Relay.Off(Box1_Port4); //Skimmer
ReefAngel.StandardLights(Box1_Port8); //Fuge PC
// ReefAngel.MHLights(Port6); //MH
ReefAngel.StandardFan(Box1_Port2);
ReefAngel.StandardHeater(Box1_Port1);
ReefAngel.StandardLights(Port1,13,00,22,30); //Daylight
ReefAngel.StandardLights(Port2,12,00,23,45); //Actinic
ReefAngel.StandardLights(Port7,12,00,23,45); //LED Fan
C:\Documents and Settings\Webmaster\My Documents\Arduino\libraries\ReefAngel/ReefAngel.h: In function 'void loop()':
C:\Documents and Settings\Webmaster\My Documents\Arduino\libraries\ReefAngel/ReefAngel.h:191: error: 'byte ReefAngelClass::DisplayedMenu' is private
RA_050811_1703:112: error: within this context
RA_050811_1703:115: error: within this context
That's why I said I changed the private variable "DisplayedMenu" to public.
This was just to test, since it would require modifying libraries. Maybe Curt could give us a better way to get the DisplayedMenu variable, so others could also create custom functions that depend on the menu options, for example, custom feeding mode function.
But, if you want to test it anyways the way it is, all you have to do is open ReefAngel.h and move "byte DisplayedMenu;" from private to public section.
ah ok, sorry... completely missed over that part!
and I'm about out of memory
ok, so I got the menu to run, but as soon as I tried to do a simple "relay on" if the water change menu is selected... it shows the water change text and graphic, but no timer. When I exit the menu, the relay turns off, but when I try to reselect water change mode... text and graphic show on controller (still no timer), but the relay won't turn on.
my pde:
my pde:
//Custom colors
// draw main relay
#ifdef RelayExp
#endif // RelayExp
//Need to set these up still
ReefAngel.WaterChangePorts = B00000000;
//water change menu
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Write();
ReefAngel.Relay.Off(Port6);
// From 12p to 1p, the Actinic PWM will slowly ramp from 15% to 70%
// From 22p to 23p, the Actinic PWM will slowly ramp from 70% to 15%
ReefAngel.PWM.SetActinic(PWMSlope(12,0,23,30,15,70,60,ReefAngel.PWM.GetActinicValue()));
ReefAngel.PWM.SetDaylight(PWMSlope(13,0,22,30,15,75,60,ReefAngel.PWM.GetDaylightValue()));
Hey Alex,
The timer is not being drawn in your code and that's why it does not show.
This line ReefAngel.Relay.Off(Port6); is being executed all the time as there is no if statement in front of it, so it is always turning port 6 off.
I changed you code a little and I think this is what you are trying to achieve
Code was edited after posting.
//Custom colors
// draw main relay
#ifdef RelayExp
#endif // RelayExp
//water change menu
if(ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
if(LastDisplayedMenu != ReefAngel.DisplayedMenu) // If Water change mode has just been chosen, let's start the timer and turn Port 6 on
//Draw Timer 4 in countdown mode
int t=ReefAngel.Timer[4].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,60+(intlength(t)*5),110,100,108);
ReefAngel.LCD.DrawText(0,255,60,110,t);
// draw main relay just to make it easy to see what's happening/debug purposes. comment out to save memory space
ReefAngel.Relay.Off(Port6); // Turns Port 6 off when timer 4 runs out
ButtonPress++; // Simulate a button press to exit water change mode
ReefAngel.DisplayedMenu=DEFAULT_MENU;
wow, thanks Roberto! I'll play with this this weekend!
