Custom Main Screens
Would you like to help?
Re: Custom Main Screens
Very cool!!!
JoelIreland
Post by JoelIreland »
Ive self taught myself too. I am a web developer but only php,html,css,js etc so had to learn new code but principle is still the same. Off topic is there a way to display the LowATO and HighATO positions, id like the green / red circles to go orange when they half way
Floats are only on or off. There is no between.
Where's the code :)
bencollinz
Post by bencollinz »
JoelIreland wrote:Hi all, thought i'd share my custom main screen ( still tweaking ) would love to know your thoughts.
Error Screen
No Power with timer Countdown
lnevo wrote:Where's the code :)
yes, code please?
Finally updated the document to remove the references of RAGen and to tell how to do it with the Wizard.
Badger55
Post by Badger55 »
OK this is my first attempt and I'm not even close to sure if this is right. I stole most of Drew's code and made what modifications I THOUGHT i should. Can anyone confirm?
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.StandardHeater( Port1,780,790 );
    ReefAngel.StandardHeater( Port2,780,790 );
    ReefAngel.StandardHeater( Port3,780,790 );
    ReefAngel.MHLights( Port4,10,0,21,0,7 );
    ReefAngel.Wavemaker( Port5,100 );
    ReefAngel.WavemakerRandom( Port6,60,120 );
    ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port5 ) );
    ReefAngel.PWM.SetDaylight( PWMParabola(10,0,21,0,0,90,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(9,30,22,0,0,90,0) );
    #define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#include <Wire.h>
#include <Time.h>
#include <RA_ATO.h>
#include <LED.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,3,17,"Dan's 90 gal Reef");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
  ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
  ReefAngel.LCD.DrawText(0,255,70,68,"Display");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
  TempRelay &= ReefAngel.Relay.RelayMaskOff;
  TempRelay |= ReefAngel.Relay.RelayMaskOn;
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
    ReefAngel.Portal( "badger55" );
Reefcam: dansreef.swanndvr.net login: guest pw: guest
Try this:
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
Badger55
Post by Badger55 »
That did it. Thanks Roberto!
Badger55
Post by Badger55 »
I have a question about this now, can I still use the wizard to make changes to my setup and this part of the code will remain or do I need to add it each time?
You will need to copy/paste your custom screen everytime.
My take on the custom screen. The temperature text changes color depending on the state of the heater and fan.
Green = Heater and fan off, temp good.
Red = Temp too high, fan on.
Blue = Temp too low, heater on.
Edit: This assumes the fan is on relay 1 and the heater is on relay 2.
Code:
  byte x;
  byte y = 2;
  char text[7];
  // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
  int TempColor;        // Color for drawing temperature
  boolean FanOn = ReefAngel.Relay.Status(Port1);    // Get the status of the fan relay
  boolean HeatOn = ReefAngel.Relay.Status(Port2);   // Get the status of the heater relay
  if (HeatOn)
    TempColor = COLOR_NAVY;    // Blue text, too cold, heater is on
  if (FanOn)
      TempColor = COLOR_RED;   // Red text, too warm, fan is on
  if (!HeatOn && !FanOn)
      TempColor = COLOR_GREEN;  // Green text, no fan or heater on
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Colin's Reef");       // Put a banner at the top
  ReefAngel.LCD.DrawDate(6, 119);                                                      // Put the date and time at the bottom
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11);                                    // Draw a black line under the banner
  x = 12;
  y += MENU_START_ROW+1;                                                               // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp     pH");
  ConvertNumToString(text, ReefAngel.Params.PH, 100);                                  // Get pH reading and convert
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);    // Put pH on the screen
  ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                       // Get T1 temp and convert
  y += MENU_START_ROW*2;
  x = 10;
  ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text);                   // Draw the temperature, white numbers on a colored background
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1);    // Draw the white light %
  ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1);   // Draw the blue light %
  // Code for drawing the relay box
  ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
Custom Main Screens
Awesome idea!!!! Getting copied!
I had NO IDEA that all these awesome designs and ideas would come from me creating these template functions to allow people to customize their displays.
Great idea for your display. Simple and clean. Looks great!
binder wrote:I had NO IDEA that all these awesome designs and ideas would come from me creating these template functions to allow people to customize their displays.
Thanks! And thanks for the templates. I'm having a blast with my Reef Angel. I doubt this is the final version of my main screen. :mrgreen:
Ok, so I'm getting ready to add the WiFi module. I noticed in the sample code there are pingserial() commands scattered about that have something to do with the WiFi module. How often do these need to be put in?
The libraries should take care of that for you.
If you are designing a custom main screen, just make sure to call it if you have lots of drawing on the screen.
Is that because of the length of time the drawing takes?
Yes.
Latest version:
  byte x;
  byte y = 2;
  char text[7];
  if (HeatOn)
  if (FanOn)
  ReefAngel.LCD.DrawText(COLOR_WHITE, COLOR_BLACK, 0, 1, "     Colin's Reef     ");    // Put a banner at the top
  pingSerial();        // Hit the Wifi Attachment
  x = 12;
  x = 10;
  ReefAngel.LCD.Clear(TempColor, x, y-1, x+63, y-1);                                   // Draw a line above and below the temp
  ReefAngel.LCD.Clear(TempColor, x, y+16, x+63, y+16);                                 // To make it look nicer and easier to read
  x += (16*4) + 8;
  ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,127,y+22);                                    // Draw a box around the light area
  ReefAngel.LCD.Clear(COLOR_BLACK,5,y+22,5,y+46);                                      //
  ReefAngel.LCD.Clear(COLOR_BLACK,127,y+22,127,y+46);                                  //
  ReefAngel.LCD.Clear(COLOR_BLACK,5,y+46,127,y+46);                                    //
  ReefAngel.LCD.DrawOutletBox(14, 92, TempRelay);
Bo0sted_Rafi
Post by Bo0sted_Rafi »
im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
Bo0sted_Rafi wrote:im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
Add this to the very end of the code posted above:
Did that fix it?
Bo0sted_Rafi
I wrote that but give me an error when i tried to compile
#define SIMPLE_MENU
    #define NUMBERS_8x16
    int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port3Bit;
      ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port6Bit;
      ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
      ReefAngel.OverheatShutoffPorts = Port7Bit ;
      ReefAngel.Relay.On( Port5 );
      for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
      totalavgph=0;
      avgph[avgindex]=analogRead(PHPin);
      avgindex++;
      if (avgindex==10) avgindex=0;
        totalavgph+=avgph[a];
      totalavgph/=10;
      totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
      totalavgph=constrain(totalavgph,100,1400);
      if (totalavgph <= 645) ReefAngel.Relay.Off(Port3);
      if (totalavgph >= 660) ReefAngel.Relay.On(Port3);
      ReefAngel.Relay.DelayedOn( Port2 );
      //    ReefAngel.CO2Control( Port3,645,660 );
      ReefAngel.StandardFan( Port4,780,788 );
      ReefAngel.WavemakerRandom( Port6,600,180 );
      ReefAngel.StandardLights( Port7,0,30,12,30 );
      ReefAngel.StandardLights( Port8,12,0,2,30 );
      ReefAngel.Portal( "Bo0sted_Rafi" );
      byte x;
      byte y = 2;
      char text[7];
      boolean FanOn = ReefAngel.Relay.Status(Port4);    // Get the status of the fan relay
      boolean HeatOn = ReefAngel.Relay.Status(Port7);   // Get the status of the heater relay
      if (HeatOn)
      if (FanOn)
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Rafi's Reef");       // Put a banner at the top
      x = 12;
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp    CA pH");
      x = 10;
      x += (16*4) + 8;
Dont let me erase the last code
Take that code out of loop() and put it under your #includes (after "Place global variable code below here").
Try this:
#define SIMPLE_MENU
    int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (FanOn)
      x = 12;
      x = 10;
      x += (16*4) + 8;
      totalavgph=0;
      avgindex++;
      totalavgph/=10;
Poiromaniax
Post by Poiromaniax »
Heres my custom main.
// Autogenerated file by RAGen (v1.2.2.171), (05/14/2012 18:11)
// RA_051412_1811.ino
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x8
  ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,DefaultBGColor,15,5,"Ariel's Reef");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,1,30,"Vortech:");
    byte vtechmode = InternalMemory.RFMode_read();
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,DefaultBGColor,50,30,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night");
    ReefAngel.LCD.DrawOutletBox(12, 97, TempRelay);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.MHLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.StandardHeater(Port4);
Im not the best at coding so i have chopped quite a bit from other people
Ideally i would love to take out the bottom two rows and have:
Tank Name
Vortech
2 LED Channels (got a vertex illumilux)
Temp
PH
Relays
ATO - Plan on getting one of the new ones - so if theres a way to see how full the reservoir is
if anyone is willing to help me, you would be awesome in my eyes :geek:
Oh, and no peripherals are connected right now as im in the process of switching tanks - incase youre wondering ;)
One thing I noticed is that you will want to make all these strings the same length:
The "Constant", "Lagoon", etc. should be the same length and if they are not, then you should pad them. Looks like "Short Pulse" is the longest at 11 chars.
So "Constant" should be "Constant   " and "Lagoon" should be "Lagoon     ".
The reason for this is when you change the modes and go from a larger text string to a smaller text string, there will be "ghosting" occurring from the extra characters not being overwritten.
Secondly, you say you want to change the layout of what is displayed? Do you not like having the 3 rows of 2 columns in the middle? Does that need to be changed for you?
Did you still want the date to be at the bottom of the screen? If not, you just need to remove this line:
from the DrawCustomMain() function and the date will no longer be displayed.
Poiromaniax
binder wrote:One thing I noticed is that you will want to make all these strings the same length:
Thanks for pointing that out! So let me just make sure i understand, I should rather have all the vortech modes lined up in the code? (im not so savvy when it comes to coding and terms used, what is padding? the gap between the end of the word and the quotations? )
E.G:
"Lagoon "
"Constant "
"Reef Crest "
I like the 3x2 layout, just would like to be able to change the paramaters viewed to something like this:
Ariel's Reef
Vortech : Reef Crest
Temp 1: 26 PH: 8.3
White : 70% Blue: 20%
ATO level : 65% etc
(ATO level will get its data from the pressure sensor)
Yeah i like the date and time at the bottom :) thanks though
Replies in red :)
EDIT - well my beautiful formatting has been destroyed by vBulletin/PHPBB
click edit the post and it will all look correct :P
Custom Main Screens
E.G:
"Lagoon "
"Constant "
"Reef Crest "
yes, the gap between the end of the word and quotation mark. the padding is simply just spaces. so count the letters and use spaces to fill in the extras like i mentioned.
Ariel's Reef
Temp 1: 26 PH: 8.3
ATO level : 65% etc
the 3x2 layout you like will have to be created manually with copying and updating the function that displays it. i can help with it later tonight or tomorrow when i get home and can have access to a keyboard and look things up better with formatting. you can look at the DrawMonitor function inside the nokialcd.cpp file to get an idea.
Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing DrawCustomMain().
    // Draw the custom monitor, function listed below
    DrawCustomMonitor(15, 60);
    if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant   ");
    else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon     ");
    else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest ");
    else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse ");
    else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night      ");
void DrawCustomMonitor(byte x, byte y) {
    // To change the column (move it right or left), you will need to adjust the value for X
    // The Labels start at X and the values for them start at X+18.
    // If you have to move them farther right (making 18 a larger number), you will need to adjust the values for X below for the second column.
    // The 2nd column labels start at X+60 and the values start at X+78
    // left column - top item
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x,y,"T1:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, x+18, y,10);
    // left column - middle item, White LED is on DP Channel
    ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x,y+10,"White:");
    // you may have to move the value farther to the right
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+18, y+10,1);
    // left column - bottom item
    ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+20,"ATO Level:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(), T3TempColor, x+18, y+20,0);
    // right column - top item
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,x+60,y,"PH:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+78, y,100);
    // right column - middle item, Blue LED is on AP Channel
    ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+10,"Blue:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+10,1);
    // right column - bottom item (not used)
    //DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
    //DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
The colors may need to be adjusted for you, but that's really easy to change. Also, I assumed that your Blue LED were on the AP channel and the White LED were on the DP channel. They can be flipped if needed. We may also need to adjust the spacing of the column based on the size of the text labels. You will just have to adjust it accordingly and experiment with it.
EDIT: Fixed my typo errors with the code
Reason: Fixed typos in code
Poiromaniax
Re:
binder wrote:Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing .
Wow, thanks dude - You have saved me days of work :D
Il fiddle around with it a bit and post a screenshot when its working nicely :)
Edit - its throwing up this error
Screen Shot 2013-05-01 at 7.08.51 PM.png (55.84 KiB) Viewed 8040 times
