Custom Main Screens
Re: Custom Menu
Curt, with the new version, i'd want on the screen:
the Relay , AP,DP,PH,T1,T2,T3 and not the graph... and i want to see if the Timeout is on.
Like:
ATO Timeout : YES
Overheat Timeout : NO
How can i do ?
THANKS
Like:
ATO Timeout : YES
How can i do ?
THANKS
Re: Custom Menu
When you say if the "Timeout is on" what are you asking? You want to know if the ATO pump is currently running and if the timeout is counting down? Or do you want to know if the timeout limit has exceeded?lukeluke wrote:Curt, with the new version, i'd want on the screen:
Like:
ATO Timeout : YES
How can i do ?
THANKS
Is this for the single ato or for the dual ato? The code will be different for both of them.
I ask because the Overheat doesn't have a timeout. It only has an exceeded value that when exceeded it turns on the RED LED on the controller and shuts off the lights.
PS. I moved your post to be under the proper topic for the custom main screens.
Re: Custom Main Screens
Hi Curt,
I'm having this error:
Tanks
Marcelo
'class ReefAngel_NokiaLCD'has no member named'DrawHugeNumbers'
What might be happening?ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
Tanks
Marcelo
you are missing a define statement inside your features file. Add this line to ReefAngel_Features.h
That will enable you to use that function.
#define NUMBERS_16X16
Tanks Curt.binder wrote:you are missing a define statement inside your features file. Add this line to ReefAngel_Features.hCode: Select all
My custon main screen,
just need to disable the functions that are not needed in the source code and fix the character that is trimmed further on the PH.
My PDE file:
// Autogenerated file by RAGen (v1.0.4.92), (08/10/2011 10:52)
// RA_081011_1052.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DirectTempSensor
#define SingleATOSetup
#define StandardLightSetup
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <Phillips6610LCDInv.h>
#include <avr/pgmspace.h>
Phillips6610LCDInv e;
void ConvertNumToString(char* string, int num, byte decimal)
char temptxt[3];
int Temp = num;
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,string,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(string, ".");
if (Temp%decimal<10 && decimal==100) strcat(string, "0");
strcat(string, temptxt);
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp pH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text,
Font8x16);
y += MENU_START_ROW*2;
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+8,y+25,"Temp2:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
x+24, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+50,"Temp3:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
x+24, y+60, 10);
y += 39*2;
x = 13;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port6);
// Specific functions
ReefAngel.StandardLights(Port1, 13, 30, 00, 30);
ReefAngel.StandardATO(Port2, 2400); //Quantidade de segundos para reposição, se desligar pelo timer, led vermelho do RA acende e bloqueia a reposição
ReefAngel.StandardFan(Port3, 270, 264); // Turn fan/chiller on at 270C and off at 264C
ReefAngel.StandardHeater(Port4, 260, 266); // Turn heater on at 260C and off at 266C
Marcelo
Marcelo
That's a nice and clean looking screen! I like it!
Side note:
You should be able to remove these lines from your PDE file. They are not used by the libraries.
I got friends thanks to Roberto and Curt.
Curt,
thanks for the recommendations.
I would leave the PDE file cleaner, if they have other recommendations, I will enjoy.
The only thing missing now I ride my custom menu, and remove some functions will not use. Do not use PWM and wave maker.
Best regards.
Marcelo
Curt,
Best regards.
Marcelo
Just wanted to add my Main Display. Its based off Marcelo's. It has room for a second Relay if needed.
Thanks to all. code to follow:
- IMG00181-20110825-0710.jpg (39.11 KiB) Viewed 10178 times
Hope this is better.
Here is my .pde.
Here is my .pde.
#include <ReefAngel_Colors.h>
char temptxt[3];
int Temp = num;
if (decimal>1)
byte x = 6;
byte y = 2;
byte t;
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display pH");
char text[7];
Font8x16);
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Sump:");
24, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"LED:");
x+24, y+35, 10);
//y += 39*2;
// x = 13;
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
// #ifdef RelayExp
// draw 1st expansion relay
// TempRelay = ReefAngel.Relay.RelayDataE[0];
// TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
// TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
// ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
//#endif RelayExp
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
randomSeed(second());
// setTime(1313771580); // Unix time
// now();
// ReefAngel.RTC.set(now());
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port5);
// ReefAngel.StandardLights(Port1,20,00,1,00);
ReefAngel.SingleATOLow(Port2);
ReefAngel.StandardLights(Port3,10,30,19,30);
ReefAngel.StandardLights(Port4,10,00,20,00);
// ReefAngel.StandardFan(Port8);
//ReefAngel.PWM.SetActinic(PWMSlope(10,0,20,00,15,100,60,ReefAngel.PWM.GetActinicValue()));
//ReefAngel.PWM.SetDaylight(PWMSlope(10,30,19,30,15,65,60,ReefAngel.PWM.GetDaylightValue()));
PWMChannel[LEDPWM0]=PWMSlope(10,0,20,0,15,100,60,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMSlope(10,30,19,30,15,75,60,PWMChannel[LEDPWM1]);
//PWMChannel[LEDPWM2]=MoonPhase();
if (hour()>=20 || hour()<1)
PWMChannel[LEDPWM2]=0;
CheckCloud();
//PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM3]);
//PWMChannel[LEDPWM4]=PWMSlope(11,0,21,30,0,50,40,PWMChannel[LEDPWM4]);
//PWMChannel[LEDPWM5]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM5]);
PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
//PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//PWMExpansion(LEDPWM4,int(2.55*PWMChannel[LEDPWM2]));
//PWMExpansion(LEDPWM5,int(2.55*PWMChannel[LEDPWM3]));
// ReefAngel.LCD.DrawText(0,255,75,120,PWMChannel[LEDPWM1]);
// ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
// ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
// ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m=month();
d=day();
y=year();
yy=y-((12-m)/10);
mm=m+9;
if (mm>=12) mm-=12;
K1=365.25*(yy+4712);
K2=30.6*mm+.5;
K3=int(int((yy/100)+49)*.75)-38;
J=K1+K2+d+59-K3;
V=(J-2451550.1)/0.29530588853;
V-=int(V/100)*100;
V=abs(V-50);
PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
return (PWMvalue*100)/255;
void CheckCloud()
#define Clouds_Every_X_Days 1
// Minimum number of minutes for cloud duration
#define Min_Cloud_Duration 3
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 5
#define Actinic_Channels B000001
#define Daylight_Channels B000010
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
#ifdef printdebug
Serial.print("Cloud Chance: ");
Serial.println(cloudchance,DEC);
#endif
if (cloudchance)
lightningchance=random(100);
#ifdef printdebug
Serial.print("Num of Clouds: ");
Serial.println(numclouds,DEC);
Serial.print("Cloud Start: ");
Serial.println(cloudstart,DEC);
Serial.print("Cloud Start Range: ");
Serial.print(Start_Cloud_After,DEC);
Serial.print(" - ");
Serial.println(Start_Cloud_After+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
Serial.print("Cloud Duration: ");
Serial.println(cloudduration,DEC);
Serial.print("Lightning Chance: ");
Serial.println(lightningchance,DEC);
Serial.print("Lightning at: ");
Serial.println(cloudstart+(cloudduration/2),DEC);
time_t t=cloudstart;
t*=60;
t+=1311551999;
setTime(t); // Unix time
now();
Serial.print("NumMins: ");
Serial.println(LastNumMins,DEC);
#endif
if (cloudchance)
//is it time for cloud yet?
for (int a=0;a<6;a++)
PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
#ifdef printdebug
if (second()==0)
Serial.print("Dimming Channel ");
Serial.print(a,DEC);
Serial.print(PWMChannel[a],DEC);
Serial.println("%");
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()>5)
adjustTime(((cloudduration/2)*60)-6);
Serial.print("Adjusting time to: ");
Serial.println(now());
#endif
#ifdef printdebug
Serial.println("Lightning...");
#endif
for (int b=0;b<6;b++)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
#ifdef printdebug
Serial.print(b,DEC);
Serial.println(PWMChannel[b],DEC);
#endif
PWMChannel[b]=20;
#ifdef printdebug
if ((NumMins(hour(),minute())!=(cloudstart+(cloudduration/2))) && second()==0)
adjustTime(((cloudduration/2)*60)-1);
if (second()==0) delay(1000);
#endif
cloudindex++;
if (cloudindex < numclouds)
#ifdef printdebug
Serial.print(Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2),DEC);
Serial.println((Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2))+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
t*=60;
t+=1311551999;
now();
#endif
ReefAngel.LCD.Clear(255,0,115,132,132);
ReefAngel.LCD.DrawText(0,255,5,115,"C");
ReefAngel.LCD.DrawText(0,255,11,115,"00:00");
ReefAngel.LCD.DrawText(0,255,45,115,"L");
ReefAngel.LCD.DrawText(0,255,51,115,"00:00");
int x=0;
ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart%60));
//ReefAngel.LCD.DrawText(0,255,35,120,cloudstart);
ReefAngel.LCD.DrawText(0,255,90,115,cloudduration);
ReefAngel.LCD.DrawText(0,255,110,115,PWMChannel[LEDPWM1]);
if (lightningchance)
int x=0;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
#ifdef printdebug
#endif
- IMG00181-20110825-0710.jpg (39.11 KiB) Viewed 10124 times
Hi bmhair03,
very good its Main Screen.
which means C11:47 L11:50 7 0???
congratulations
Marcelo
congratulations
Marcelo
Its display for the cloud lightning effect.
c=cloud L=lightning.
Here is another display based off of Marcelo's, It adds status of the two float switch relays under the big temperature value. I have my head unit in an area that I cannot get a picture. Feel free to comment or improve on this.
Add this into your loop
// GLOBAL variables for display
int FloatHigh = 0;
int FloatLow = 0;
// custom menu code
byte x = 6;
byte y = 2;
byte t;
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Sump pH");
char text[7];
Font8x16);
x = 10;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+18, "High Float:");
ConvertNumToString(text, FloatHigh, 1);
ReefAngel.LCD.DrawLargeText(COLOR_DIMGREY, COLOR_DEEPSKYBLUE, x+5, y+25, text, Font8x16);
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+41, "Low Float:");
ConvertNumToString(text, FloatLow, 1);
ReefAngel.LCD.DrawLargeText(COLOR_DIMGREY, COLOR_DEEPSKYBLUE, x+5, y+49, text, Font8x16);
ReefAngel.LCD.DrawText(COLOR_GREEN, COLOR_WHITE, x, y+65, "0=Empty 1=Full");
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+8,y+25,"Refug:");
x+24, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+50,"Room:");
x+24, y+60, 10);
y += 39*2;
x = 13;
// variables used for display
FloatLow = digitalRead(lowATOPin);
FloatHigh = digitalRead(highATOPin);
Here is my humble attempt at a custom screen....thanks to all who do hard work coding for us newbies to Arduino coding...I am getting real good at cutting and pasting all the good work you do, and I can do some giggling of code, but without you all who know the nitty-gritty of writing the code, I would be lost...
Sorry for the junky iphone pic, it is the best I could get...
- SCREEN.JPG (29.92 KiB) Viewed 9959 times
Here is my PDE
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "Rob's ReefAngel");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display PH");
char text[7];
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"ROOM:");
9, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"FRAG:");
x+9, y+35, 10);
how come I always get 'class ReefAngel_NokiaLCD' has no class named 'DrawLargeText'?
You need to pick the size of font you want to use and define it in the features file.
Either of these 2:
Take a look at the manual for more info:
http://forum.reefangel.com/viewtopic.php?p=653#p653
Either of these 2:
#define FONT_8x8
#define FONT_8x16
//Custom Main, Graph & Menu
Wire.requestFrom(8,8);
for (int a=0;a<8;a++)
if (Wire.available()) SeasonsVar[a]=Wire.receive();
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 99, 68, 10);
ReefAngel.LCD.DrawText(0,255,8,97,"Moon");
DayAge = MoonAge(day(), month(), year());
MoonState(DayAge);
if (ThisPhase == 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"New");
else if (ThisPhase == 1) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Crescent");
else if (ThisPhase == 2) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"First Quarter");
else if (ThisPhase == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Gibbous");
else if (ThisPhase == 4) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Full");
else if (ThisPhase == 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Gibbous");
else if (ThisPhase == 6) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Last Quarter");
else if (ThisPhase == 7) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Crescent");
// ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 105, 109, 1);
ReefAngel.LCD.DrawText(0,255,8,109, "Sunrise");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,119, SeasonsVar[1]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,119, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,25,119, SeasonsVar[2]);
ReefAngel.LCD.DrawText(0,255,75,109,"%");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255, 60, 109, SeasonsVar[0]);
ReefAngel.LCD.DrawText(0,255,88,109, "Sunset");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,119, SeasonsVar[3]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,102,119, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,107,119, SeasonsVar[4]);
Thanks man, I worked on it all day haha, nudging each thing around to make it perfect - ps all of the ecotech modes are centered when theyre called and the color of the vortech mode matches the driver
very nice screen!
Great screen!! Hey, where in your code does it make the relay box be blue and white instead of the standard red/black? I can't figure it out...
depends on how you want to do it. the values are stored in reefangel_globals.h or you can enable the colors file.psyrob wrote:Great screen!! Hey, where in your code does it make the relay box be blue and white instead of the standard red/black? I can't figure it out...
Like binder said - I edited the colors through globals.h
use caution with editing the globals.h file, that file gets updated with new releases of the libraries. the recommended way is to use the colors file.
hmmm yea i forgot that - come to think of it now that I went and looked at it, I did use colors. But I found out what colors were available/preprogrammed by looking at globals.h
ReefAngel_Colors.h contains a list of the colors in it's own file (same as Globals.h, there's a reason why it's like this).Deckoz2302 wrote:hmmm yea i forgot that - come to think of it now that I went and looked at it, I did use colors. But I found out what colors were available/preprogrammed by looking at globals.h
ReefAngel_CustomColors.h is the file that you can make your changes to.
If using those files, they must be included into your PDE file and also the Features.h file needs to have the #define CUSTOM_COLORS in it.
