Custom Main Screens
Would you like to help?
bmhair03
Re: Custom Main Screens
Post by bmhair03 »
Hope this is better.
Here is my .pde.
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
void ConvertNumToString(char* string, int num, byte decimal)
  char temptxt[3];
  int Temp = num;
  if (Temp==0xFFFF) Temp=0;
  itoa(Temp/decimal,string,10);
  if (decimal>1)
      itoa(Temp%decimal,temptxt,10);
      strcat(string, ".");
      if (Temp%decimal<10 && decimal==100) strcat(string, "0");
      strcat(string, temptxt);
  byte x = 6;
  byte y = 2;
  byte t;
  ReefAngel.LCD.DrawDate(6, 2);
  x = 12;
  y += MENU_START_ROW+1;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display         pH");
  char text[7];
  ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text,
Font8x16);
  y += MENU_START_ROW*2;
  x = 10;
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Sump:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
24, y+35, 10);
  ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"LED:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
x+24, y+35, 10);
  //y += 39*2;
 // x = 13;
  ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
   // #ifdef RelayExp
  // draw 1st expansion relay
 // TempRelay = ReefAngel.Relay.RelayDataE[0];
 // TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
//  TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
 // ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
//#endif   RelayExp
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
//End of PWM Expansion Code Header
  randomSeed(second());
//  setTime(1313771580);  // Unix time
//  now();
//  ReefAngel.RTC.set(now());
  ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.On(Port5);
  ReefAngel.Relay.On(Port6);
  ReefAngel.Relay.On(Port7);
  ReefAngel.Relay.On(Port8);
  // Specific functions
  // ReefAngel.StandardLights(Port1,20,00,1,00);
  ReefAngel.SingleATOLow(Port2);
  ReefAngel.StandardLights(Port3,10,30,19,30);
  ReefAngel.StandardLights(Port4,10,00,20,00);
 // ReefAngel.StandardFan(Port8);
  //ReefAngel.PWM.SetActinic(PWMSlope(10,0,20,00,15,100,60,ReefAngel.PWM.GetActinicValue()));
  //ReefAngel.PWM.SetDaylight(PWMSlope(10,30,19,30,15,65,60,ReefAngel.PWM.GetDaylightValue()));
  PWMChannel[LEDPWM0]=PWMSlope(10,0,20,0,15,100,60,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(10,30,19,30,15,75,60,PWMChannel[LEDPWM1]);
  //PWMChannel[LEDPWM2]=MoonPhase();
  if (hour()>=20 || hour()<1)
    PWMChannel[LEDPWM2]=0;
  CheckCloud();
  //PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM3]);
  //PWMChannel[LEDPWM4]=PWMSlope(11,0,21,30,0,50,40,PWMChannel[LEDPWM4]);
  //PWMChannel[LEDPWM5]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM5]);
  PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
  PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
  PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  //PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
  //PWMExpansion(LEDPWM4,int(2.55*PWMChannel[LEDPWM2]));
  //PWMExpansion(LEDPWM5,int(2.55*PWMChannel[LEDPWM3]));
//  ReefAngel.LCD.DrawText(0,255,75,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
//  ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
  Wire.beginTransmission(8); // transmit to device #2
  Wire.send('$'); // sends $
  Wire.send(cmd); // sends a value
  Wire.send(data); // sends 255
  Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
byte MoonPhase()
  int m,d,y;
  int yy,mm;
  long K1,K2,K3,J,V;
  byte PWMvalue;
  m=month();
  d=day();
  y=year();
  yy=y-((12-m)/10);
  mm=m+9;
  if (mm>=12) mm-=12;
  K1=365.25*(yy+4712);
  K2=30.6*mm+.5;
  K3=int(int((yy/100)+49)*.75)-38;
  J=K1+K2+d+59-K3;
  V=(J-2451550.1)/0.29530588853;
  V-=int(V/100)*100;
  V=abs(V-50);
  PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
  //pinMode(lowATOPin,OUTPUT);
  return (PWMvalue*100)/255;
void CheckCloud()
#define Clouds_Every_X_Days 1
  // Minimum number of minutes for cloud duration
#define Min_Cloud_Duration 3
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 5
#define Actinic_Channels B000001
#define Daylight_Channels B000010
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
#ifdef printdebug
      Serial.print("Cloud Chance: ");
      Serial.println(cloudchance,DEC);
#endif
      if (cloudchance)
        lightningchance=random(100);
#ifdef printdebug
        Serial.print("Num of Clouds: ");
        Serial.println(numclouds,DEC);
        Serial.print("Cloud Start: ");
        Serial.println(cloudstart,DEC);
        Serial.print("Cloud Start Range: ");
        Serial.print(Start_Cloud_After,DEC);
        Serial.print(" - ");
        Serial.println(Start_Cloud_After+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
        Serial.print("Cloud Duration: ");
        Serial.println(cloudduration,DEC);
        Serial.print("Lightning Chance: ");
        Serial.println(lightningchance,DEC);
        Serial.print("Lightning at: ");
        Serial.println(cloudstart+(cloudduration/2),DEC);
        time_t t=cloudstart;
        t*=60;
        t+=1311551999;
        setTime(t); // Unix time
        now();
        Serial.print("NumMins: ");
        Serial.println(LastNumMins,DEC);
#endif
  if (cloudchance)
    //is it time for cloud yet?
      for (int a=0;a<6;a++)
          PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
#ifdef printdebug
          if (second()==0)
            Serial.print("Dimming Channel ");
            Serial.print(a,DEC);
            Serial.print(PWMChannel[a],DEC);
            Serial.println("%");
          if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()>5)
            adjustTime(((cloudduration/2)*60)-6);
            Serial.print("Adjusting time to: ");
            Serial.println(now());
#endif
#ifdef printdebug
        Serial.println("Lightning...");
#endif
        for (int b=0;b<6;b++)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
#ifdef printdebug
            Serial.print(b,DEC);
            Serial.println(PWMChannel[b],DEC);
#endif
            PWMChannel[b]=20;
#ifdef printdebug
      if ((NumMins(hour(),minute())!=(cloudstart+(cloudduration/2))) && second()==0)
        adjustTime(((cloudduration/2)*60)-1);
      if (second()==0) delay(1000);
#endif
      cloudindex++;
      if (cloudindex < numclouds)
#ifdef printdebug
        Serial.print(Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2),DEC);
        Serial.println((Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2))+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
        t*=60;
        t+=1311551999;
        now();
#endif
    ReefAngel.LCD.Clear(255,0,115,132,132);
    ReefAngel.LCD.DrawText(0,255,5,115,"C");
    ReefAngel.LCD.DrawText(0,255,11,115,"00:00");
    ReefAngel.LCD.DrawText(0,255,45,115,"L");
    ReefAngel.LCD.DrawText(0,255,51,115,"00:00");
      int x=0;
      ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart/60));
      ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart%60));
    //ReefAngel.LCD.DrawText(0,255,35,120,cloudstart);
    ReefAngel.LCD.DrawText(0,255,90,115,cloudduration);
    ReefAngel.LCD.DrawText(0,255,110,115,PWMChannel[LEDPWM1]);
    if (lightningchance)
      int x=0;
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
#ifdef printdebug
#endif
mbertalha
Post by mbertalha »
Hi bmhair03,
very good its Main Screen.
which means C11:47 L11:50 7 0???
congratulations
Marcelo
bmhair03
Post by bmhair03 »
Its display for the cloud lightning effect.
c=cloud L=lightning.
peitro
Post by peitro »
Here is another display based off of Marcelo's, It adds status of the two float switch relays under the big temperature value. I have my head unit in an area that I cannot get a picture. Feel free to comment or improve on this.
#include <avr/pgmspace.h>
// GLOBAL variables for display
int FloatHigh = 0;
int FloatLow = 0;
// custom menu code
  byte x = 6;
  byte y = 2;
  byte t;
  x = 12;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Sump         pH");
  char text[7];
Font8x16);
  x = 10;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+18, "High Float:");
  ConvertNumToString(text, FloatHigh, 1);
  ReefAngel.LCD.DrawLargeText(COLOR_DIMGREY, COLOR_DEEPSKYBLUE, x+5, y+25, text, Font8x16);
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+41, "Low Float:");
  ConvertNumToString(text, FloatLow, 1);
  ReefAngel.LCD.DrawLargeText(COLOR_DIMGREY, COLOR_DEEPSKYBLUE, x+5, y+49, text, Font8x16);
  ReefAngel.LCD.DrawText(COLOR_GREEN, COLOR_WHITE, x, y+65, "0=Empty 1=Full");
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+8,y+25,"Refug:");
x+24, y+35, 10);
  ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+50,"Room:");
x+24, y+60, 10);
  y += 39*2;
  x = 13;
Add this into your loop
      // variables used for display
        FloatLow = digitalRead(lowATOPin);
        FloatHigh = digitalRead(highATOPin);
psyrob
Post by psyrob »
Here is my humble attempt at a custom screen....thanks to all who do hard work coding for us newbies to Arduino coding...I am getting real good at cutting and pasting all the good work you do, and I can do some giggling of code, but without you all who know the nitty-gritty of writing the code, I would be lost...
Sorry for the junky iphone pic, it is the best I could get...
psyrob
Post by psyrob »
Here is my PDE
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "Rob's ReefAngel");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display       PH");
char text[7];
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"ROOM:");
9, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"FRAG:");
x+9, y+35, 10);
Nice. Looks good. Good job. :)
I like it :)
Deckoz2302
Post by Deckoz2302 »
how come I always get 'class ReefAngel_NokiaLCD' has no class named 'DrawLargeText'?
You need to pick the size of font you want to use and define it in the features file.
Either of these 2:
#define FONT_8x8
#define FONT_8x16
Take a look at the manual for more info:
http://forum.reefangel.com/viewtopic.php?p=653#p653
Deckoz2302
//Custom Main, Graph & Menu
  Wire.requestFrom(8,8);
  for (int a=0;a<8;a++)
    if (Wire.available()) SeasonsVar[a]=Wire.receive();
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,8,97,"Moon");
  DayAge = MoonAge(day(), month(), year());
  MoonState(DayAge);
  if (ThisPhase == 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"New");
  else if (ThisPhase == 1) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Crescent");
  else if (ThisPhase == 2) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"First Quarter");
  else if (ThisPhase == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Gibbous");
  else if (ThisPhase == 4) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Full");
  else if (ThisPhase == 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Gibbous");
  else if (ThisPhase == 6) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Last Quarter");
  else if (ThisPhase == 7) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Crescent");
  //  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 105, 109, 1);
  ReefAngel.LCD.DrawText(0,255,8,109, "Sunrise");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,119, SeasonsVar[1]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,25,119, SeasonsVar[2]);
  ReefAngel.LCD.DrawText(0,255,75,109,"%");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255, 60, 109, SeasonsVar[0]);
  ReefAngel.LCD.DrawText(0,255,88,109, "Sunset");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,119, SeasonsVar[3]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,102,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,107,119, SeasonsVar[4]);
I love this screen!!!
Deckoz2302
Thanks man, I worked on it all day haha, nudging each thing around to make it perfect - ps all of the ecotech modes are centered when theyre called and the color of the vortech mode matches the driver
wolfador
Post by wolfador »
very nice screen!
John
psyrob
Post by psyrob »
Great screen!! Hey, where in your code does it make the relay box be blue and white instead of the standard red/black? I can't figure it out...
psyrob wrote:Great screen!! Hey, where in your code does it make the relay box be blue and white instead of the standard red/black? I can't figure it out...
depends on how you want to do it. the values are stored in reefangel_globals.h or you can enable the colors file.
Deckoz2302
Like binder said - I edited the colors through globals.h
use caution with editing the globals.h file, that file gets updated with new releases of the libraries. the recommended way is to use the colors file.
Deckoz2302
hmmm yea i forgot that - come to think of it now that I went and looked at it, I did use colors. But I found out what colors were available/preprogrammed by looking at globals.h
Deckoz2302 wrote:hmmm yea i forgot that - come to think of it now that I went and looked at it, I did use colors. But I found out what colors were available/preprogrammed by looking at globals.h
ReefAngel_Colors.h contains a list of the colors in it's own file (same as Globals.h, there's a reason why it's like this).
ReefAngel_CustomColors.h is the file that you can make your changes to.
If using those files, they must be included into your PDE file and also the Features.h file needs to have the #define CUSTOM_COLORS in it.
Deckoz2302
I changed it up a little bit - Where moon cycle is in the last picture -
At night it shows moon phase with pwm% and where moonphase is(crescent, quarter, gibb, full ect)
During the day it shows 4 PWM module %'s
If there is a cloud it will show time and duration, also if there is lightning it will change the label from cloud to storm
  for (int a=0;a<12;a++)
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  for (byte Left=93; Left < 133; Left+=10)
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  ConvertNumToString(text, ReefAngel.Params.Temp3, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_CORNFLOWERBLUE, 40, 68, 10);
  if (ReefAngel.PWM.GetActinicValue() > 0)//if moon phase is active display state and pwm %
    ReefAngel.LCD.DrawText(0,255,8,98,"Moon");
    MoonState(DayAge);
    char* ThisPhaseLabel[]={
      "New","Waxing Crescent","First Quarter","Waxing Gibbous","Full","Waning Gibbous","Last Quarter","Waning Crescent"                        };
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,98,ThisPhaseLabel[ThisPhase]);
    ReefAngel.LCD.DrawSingleMonitor(COLOR_CORNFLOWERBLUE,255, 60, 109, ReefAngel.PWM.GetActinicValue());
  else if (SeasonsVar[5] > 0) //or if there is a cloud display clouds instead
    if (SeasonsVar[8] > 0) ReefAngel.LCD.DrawText(0,255, 8, 98, "Storm"); //decide between dislaying storm or cloud based on lightningchance
    else ReefAngel.LCD.DrawText(0,255,8,98,"Cloud");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,42,98, SeasonsVar[5]);
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,54,98, ":");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,59,98, SeasonsVar[6]);
    ReefAngel.LCD.DrawText(0,255,75,98,"Length");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,115,98, SeasonsVar[7]);
  else //if no moon or clouds show LED PWM %'s
    ReefAngel.LCD.DrawText(0,255,8,98,"W");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,98,SeasonsVar[0]);
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255,33,98,"|");
    ReefAngel.LCD.DrawText(0,255,38,98,"R");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,45,98,SeasonsVar[9]);
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255,63,98,"|");
    ReefAngel.LCD.DrawText(0,255,68,98,"B");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,98,SeasonsVar[10]);
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255,93,98,"|");
    ReefAngel.LCD.DrawText(0,255,98,98,"V");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,105,98,SeasonsVar[11]);
psyrob
Post by psyrob »
Here is my new one....Thanks to the user who posted the wave maker timer code...I'm sure I will be tinkering and making a new screen before too long :)
photo (2).jpg (88.87 KiB) Viewed 10025 times
SuperDodge
Post by SuperDodge »
Here's where my screen seems to have settled at during my first week of tinkering with my Reef Angel.
The line that says "Lagoon" will eventually update with my Vortech status (when I save some coin for the RF adapter. The line is always centered
The line that says "Clear Skies" will update to say "Cloudy(XX:XX)" or "Storms(XX:XX)" if there is a cloud or a cloud with lightning coming. This line is always centered.
The moon status updates throughout the month and is always centered.
The line that says W:100% B:100% R:100% updates in real-time to reflect all three channels on my AI Nano fixture. The line is always centered as the position of the numbers changes depending on the number of digits.
THANKS TO EVERYONE WHO PROVIDED GREAT CODE AND IDEAS THROUGHOUT THIS THREAD!
CODE REMOVED BECAUSE I FOUND AN ERROR - WILL REPOST WHEN FIXED
That's a pretty slick screen SuperDodge!! Nice work. :)
Deckoz2302
Yes nice screen sir ;)
JNieuwenhuizen
Post by JNieuwenhuizen »
I love the screen Deckoz2302 made. What bit do i have to edit to change the temp from f to c ?
Also the PWM control bit - I run a vertex illumina unit and that does the cycles by it self.
tkeracer619
Post by tkeracer619 »
Is there any way to test the display code without uploading to the controller?
tkeracer619 wrote:Is there any way to test the display code without uploading to the controller?
Unfortunately, No. There isn't a way to test the code without running it on the controller.....at least not yet. That's not saying that something is close. It's just saying that the idea has been discussed just nothing has been done for it.
tkeracer619
I spend a lot of time in hotels and was thinking it would be something fun to do in my boring hotel room. No biggie. I figured there wasn't. Thanks for the reply.
It would be pretty cool if RAGen had a click, drag, place, and modify type screen maker and would generate the code for you based on the screen you come up with.
tkeracer619 wrote:I spend a lot of time in hotels and was thinking it would be something fun to do in my boring hotel room. No biggie. I figured there wasn't. Thanks for the reply.
well, apparently you can read minds. that is what i want to have it do, however i just have not had time to work on it.
