Custom Main Screens
Would you like to help?
Bo0sted_Rafi
Re: Custom Main Screens
Post by Bo0sted_Rafi »
im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
Bo0sted_Rafi wrote:im trying to use the custom screen that showed here but when I upload the code, still showing the graph of the standard screen. Where in the code i remove that graph?
Add this to the very end of the code posted above:
Did that fix it?
Bo0sted_Rafi
I wrote that but give me an error when i tried to compile
#define SIMPLE_MENU
    #define NUMBERS_8x16
    int avgph[10];
    unsigned long totalavgph=0;
    byte avgindex=0;
      ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port3Bit;
      ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port3Bit | Port6Bit;
      ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
      ReefAngel.OverheatShutoffPorts = Port7Bit ;
      ReefAngel.Relay.On( Port5 );
      for (int a=0;a<10;a++) avgph[a]=analogRead(PHPin);
      totalavgph=0;
      avgph[avgindex]=analogRead(PHPin);
      avgindex++;
      if (avgindex==10) avgindex=0;
        totalavgph+=avgph[a];
      totalavgph/=10;
      totalavgph=map(totalavgph, ReefAngel.PHMin, ReefAngel.PHMax, 700, 1000); // apply the calibration to the sensor reading
      totalavgph=constrain(totalavgph,100,1400);
      if (totalavgph <= 645) ReefAngel.Relay.Off(Port3);
      if (totalavgph >= 660) ReefAngel.Relay.On(Port3);
      ReefAngel.Relay.DelayedOn( Port2 );
      //    ReefAngel.CO2Control( Port3,645,660 );
      ReefAngel.StandardFan( Port4,780,788 );
      ReefAngel.WavemakerRandom( Port6,600,180 );
      ReefAngel.StandardLights( Port7,0,30,12,30 );
      ReefAngel.StandardLights( Port8,12,0,2,30 );
      ReefAngel.Portal( "Bo0sted_Rafi" );
      byte x;
      byte y = 2;
      char text[7];
      // *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
      int TempColor;        // Color for drawing temperature
      boolean FanOn = ReefAngel.Relay.Status(Port4);    // Get the status of the fan relay
      boolean HeatOn = ReefAngel.Relay.Status(Port7);   // Get the status of the heater relay
      if (HeatOn)
        TempColor = COLOR_NAVY;    // Blue text, too cold, heater is on
      if (FanOn)
          TempColor = COLOR_RED;   // Red text, too warm, fan is on
      if (!HeatOn && !FanOn)
          TempColor = COLOR_GREEN;  // Green text, no fan or heater on
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Rafi's Reef");       // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119);                                                      // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11);                                    // Draw a black line under the banner
      x = 12;
      y += MENU_START_ROW+1;                                                               // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp    CA pH");
      ConvertNumToString(text, ReefAngel.Params.PH, 100);                                  // Get pH reading and convert
      ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);    // Put pH on the screen
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10);                       // Get T1 temp and convert
      y += MENU_START_ROW*2;
      x = 10;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, TempColor, x, y, text);                   // Draw the temperature, white numbers on a colored background
      x += (16*4) + 8;
      // Code for drawing the relay box
      ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
Dont let me erase the last code
Take that code out of loop() and put it under your #includes (after "Place global variable code below here").
Try this:
#define SIMPLE_MENU
    int avgph[10];
    byte avgindex=0;
      byte x;
      byte y = 2;
      char text[7];
      if (HeatOn)
      if (FanOn)
      x = 12;
      x = 10;
      x += (16*4) + 8;
      totalavgph=0;
      avgindex++;
      totalavgph/=10;
Poiromaniax
Post by Poiromaniax »
Heres my custom main.
// Autogenerated file by RAGen (v1.2.2.171), (05/14/2012 18:11)
// RA_051412_1811.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define RFEXPANSION
#define FONT_8x8
  ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,DefaultBGColor,15,5,"Ariel's Reef");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,1,30,"Vortech:");
    byte vtechmode = InternalMemory.RFMode_read();
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,DefaultBGColor,50,30,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night");
    ReefAngel.LCD.DrawOutletBox(12, 97, TempRelay);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.MHLights(Port1);
    ReefAngel.MHLights(Port2);
    ReefAngel.StandardHeater(Port4);
Im not the best at coding so i have chopped quite a bit from other people
Ideally i would love to take out the bottom two rows and have:
Tank Name
Vortech
2 LED Channels (got a vertex illumilux)
Temp
PH
Relays
ATO - Plan on getting one of the new ones - so if theres a way to see how full the reservoir is
if anyone is willing to help me, you would be awesome in my eyes :geek:
Oh, and no peripherals are connected right now as im in the process of switching tanks - incase youre wondering ;)
One thing I noticed is that you will want to make all these strings the same length:
The "Constant", "Lagoon", etc. should be the same length and if they are not, then you should pad them. Looks like "Short Pulse" is the longest at 11 chars.
So "Constant" should be "Constant   " and "Lagoon" should be "Lagoon     ".
The reason for this is when you change the modes and go from a larger text string to a smaller text string, there will be "ghosting" occurring from the extra characters not being overwritten.
Secondly, you say you want to change the layout of what is displayed? Do you not like having the 3 rows of 2 columns in the middle? Does that need to be changed for you?
Did you still want the date to be at the bottom of the screen? If not, you just need to remove this line:
from the DrawCustomMain() function and the date will no longer be displayed.
Poiromaniax
binder wrote:One thing I noticed is that you will want to make all these strings the same length:
Thanks for pointing that out! So let me just make sure i understand, I should rather have all the vortech modes lined up in the code? (im not so savvy when it comes to coding and terms used, what is padding? the gap between the end of the word and the quotations? )
E.G:
"Lagoon "
"Constant "
"Reef Crest "
I like the 3x2 layout, just would like to be able to change the paramaters viewed to something like this:
Ariel's Reef
Vortech : Reef Crest
Temp 1: 26 PH: 8.3
White : 70% Blue: 20%
ATO level : 65% etc
(ATO level will get its data from the pressure sensor)
Yeah i like the date and time at the bottom :) thanks though
Replies in red :)
EDIT - well my beautiful formatting has been destroyed by vBulletin/PHPBB
click edit the post and it will all look correct :P
Custom Main Screens
E.G:
"Lagoon "
"Constant "
"Reef Crest "
yes, the gap between the end of the word and quotation mark. the padding is simply just spaces. so count the letters and use spaces to fill in the extras like i mentioned.
Ariel's Reef
Temp 1: 26 PH: 8.3
ATO level : 65% etc
the 3x2 layout you like will have to be created manually with copying and updating the function that displays it. i can help with it later tonight or tomorrow when i get home and can have access to a keyboard and look things up better with formatting. you can look at the DrawMonitor function inside the nokialcd.cpp file to get an idea.
Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing DrawCustomMain().
    // Draw the custom monitor, function listed below
    DrawCustomMonitor(15, 60);
    if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,DefaultBGColor,50,30,"Constant   ");
    else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_PURPLE,DefaultBGColor,50,30,"Lagoon     ");
    else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,DefaultBGColor,50,30,"Reef Crest ");
    else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,DefaultBGColor,50,30,"Long Pulse ");
    else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,DefaultBGColor,50,30,"Night      ");
void DrawCustomMonitor(byte x, byte y) {
    // To change the column (move it right or left), you will need to adjust the value for X
    // The Labels start at X and the values for them start at X+18.
    // If you have to move them farther right (making 18 a larger number), you will need to adjust the values for X below for the second column.
    // The 2nd column labels start at X+60 and the values start at X+78
    // left column - top item
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x,y,"T1:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, x+18, y,10);
    // left column - middle item, White LED is on DP Channel
    ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x,y+10,"White:");
    // you may have to move the value farther to the right
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+18, y+10,1);
    // left column - bottom item
    ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x,y+20,"ATO Level:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.WaterLevel.GetLevel(), T3TempColor, x+18, y+20,0);
    // right column - top item
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,x+60,y,"PH:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, x+78, y,100);
    // right column - middle item, Blue LED is on AP Channel
    ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+10,"Blue:");
    ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+10,1);
    // right column - bottom item (not used)
    //DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
    //DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+78, y+20,1);
The colors may need to be adjusted for you, but that's really easy to change. Also, I assumed that your Blue LED were on the AP channel and the White LED were on the DP channel. They can be flipped if needed. We may also need to adjust the spacing of the column based on the size of the text labels. You will just have to adjust it accordingly and experiment with it.
EDIT: Fixed my typo errors with the code
Reason: Fixed typos in code
Poiromaniax
Re:
binder wrote:Ok, here's some code for you based on what you were wanting. I added comments to it and cleaned up things as well (I fixed the spacing issue). Here's the DrawCustomMain function as well as a helper function for drawing your custom monitor box. So just copy and paste these 2 functions into your INO file and replace the existing .
Wow, thanks dude - You have saved me days of work :D
Il fiddle around with it a bit and post a screenshot when its working nicely :)
Edit - its throwing up this error
Screen Shot 2013-05-01 at 7.08.51 PM.png (55.84 KiB) Viewed 8024 times
I just fixed up my code in the previous post. I know the WHITE and Params errors should be gone now. I'm not sure why it is giving you the error about the WaterLevel member. It should be available because it found the Water Level Expansion Module.
Make sure you are running the latest libraries. Perhaps Roberto can shed some more light on this error.
Make sure you add this in your includes up top:
Poiromaniax
Custom Main Screens
Thanks guys, will give a shot in a bit later :)
ReeferBee
Post by ReeferBee »
//Custom Main, Graph & Menu
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  static byte vtechmode=0;
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ConvertNumToString(text, ReefAngel.Params. PH, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
Is it possible to mod this code to display the mode that my WP40 is running?
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
That will display the mode your mp40 is running? Only if you're controlling it via the RF module? The RA sets the mode and then that code displays it on your custom main. I hope you have the RA+ or you'll run out of space quickly.
ReeferBee
Post by ReeferBee »
DrewPalmer04 wrote:That will display the mode your mp40 is running? Only if you're controlling it via the RF module? The RA sets the mode and then that code displays it on your custom main. I hope you have the RA+ or you'll run out of space quickly.
Yes, using this part of the coding.
I believe this only works with the RF module though. I want it to display the mode my WP40 are in, through the use of the wp40 harness and dimming ports. Yep, the plus was a must!
Barry
You can do that.... Can you open a new thread and post your code?
ReeferBee
Post by ReeferBee »
It's not my code. Anther member posted it in this thread. I just wanted to change it up a litte bit. Should I still open another thread with it? Thanks
Barry
Yes, but post your code and that code seperately so we can see how it needs to be integrated.
ReeferBee
Post by ReeferBee »
After a day of tweaking the code I think i finally have it the way I like it.
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 4);
  ReefAngel.LCD.DrawLargeText(0,255,10,16,"  WP40 Mode:");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
  ReefAngel.LCD.DrawLargeText(0,255,17,49,"Sump");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
  ReefAngel.LCD.DrawLargeText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,89, "WP40L");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,20,100, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, "WP40R");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,100, ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawOutletBox(12, 113, TempRelay);
I cant take credit, I mostly copied and pasted others codes from this thread.
Barry
Super cool!!!
Can you post the code?
ReeferBee
Post by ReeferBee »
Done :)
Barry
ReeferBee wrote:Thanks!
Done :)
Very nice looking screen! Great job!
Poiromaniax
Custom Main Screens
Done :)
Agreed! Good job ReeferBee
I'm gonna use the basic layout and change a few parameters
jegillis
Post by jegillis »
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  //static byte vtechmode=0;
  ReefAngel.LCD.DrawLargeText(3,255,8,16,"Redneck Reefin!", Font8x8);
  ReefAngel.LCD.DrawLargeText(3,255,8,56,"Jason & Sarah's", Font8x8);
  ReefAngel.LCD.DrawLargeText(3,255,32,65,"Money Pit", Font8x8);
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
  ReefAngel.LCD.DrawText(0,255,8,109, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.PWM.GetDaylightValue(),
  ReefAngel.LCD.DrawText(0,255,88,108, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
  //ReefAngel.PWM.GetActinicValue());
  //ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
I like it :)
jegillis
Post by jegillis »
Well that didn't last long before I had to tinker would anyone have an idea on how I could have the temps change color if they are over a set limit?
#define SIMPLE_MENU
#define FONT_8x8
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawLargeText(3,255,8,14,"Redneck Reefin!", Font8x8);
  ReefAngel.LCD.DrawLargeText(3,255,8,55,"Jason & Sarah's", Font8x8);
  ReefAngel.LCD.DrawLargeText(3,255,32,64,"Money Pit", Font8x8);
  ReefAngel.LCD.DrawText(COLOR_RED,255, 6, 88, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 6, 125, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 123, "|");
  ReefAngel.LCD.DrawLargeText(0,255,8,25,"TANK", Font8x8);
  ReefAngel.LCD.DrawLargeText(224, 255, 42, 25, text, Font8x8);
  ReefAngel.LCD.DrawLargeText(0,255,8,35,"HOOD", Font8x8);
  ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(153, 255, 42, 35, text, Font8x8);
  ReefAngel.LCD.DrawLargeText(0,255,8,45,"ROOM", Font8x8);
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(66, 255, 42, 45, text, Font8x8);
  ReefAngel.LCD.DrawText(0,255,100,25,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 35, text, Num8x16);
  ReefAngel.LCD.DrawOutletBox(12, 75, TempRelay);
    ReefAngel.LCD.DrawText(0,255,8,96, "White=");
  ReefAngel.LCD.DrawText(197,255,46,96, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.PWM.GetDaylightValue()),
  ReefAngel.LCD.DrawText(0,255,72,96, "Blue=");
  ReefAngel.LCD.DrawText(3,255,106,96, ReefAngel.PWM.GetActinicValue());
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
    ReefAngel.SingleATOLow( Port1 );
    ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port3 ) );
    ReefAngel.ActinicLights( Port3 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.Wavemaker2( Port6 );
    ReefAngel.StandardFan( Port8 );
    ActinicPWMValue=PWMSlope(12,15,22,45,15,100,60,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(13,0,22,0,15,100,60,DaylightPWMValue);
    CheckCloud();
    ReefAngel.Portal( "jegillis" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(15,00)
#define End_Cloud_Before NumMins(22,00)
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,15,180);
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=15;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    ReefAngel.LCD.DrawText(0,255,8,108,"Cloud");
    ReefAngel.LCD.DrawText(0,255,8,118,"00:00");
    ReefAngel.LCD.DrawText(0,255,90,108,"Storm");
    ReefAngel.LCD.DrawText(0,255,48,108,"Length");
    ReefAngel.LCD.DrawText(0,255,90,118,"00:00");
      int x=0;
      if ((cloudstart/60)>=10) x=8; else x=14;
      ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart/60));
      if ((cloudstart%60)>=10) x=58; else x=64;
      ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart%60));
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=90; else x=96;
      ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=108; else x=114;
      ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
I know someone did some code to base their temp color off the value, but I can't find it at the moment.
I did help add a function to the library so that if you go over a certain limit it will flash. Take a look at this thread:
http://forum.reefangel.com/viewtopic.ph ... nitoralarm
Oh and here is the post in this thread where someone changed the temp colors to be based on range
http://forum.reefangel.com/viewtopic.php?p=23651#p23651
jegillis
Post by jegillis »
Thanks, I used the color change the flashing is cool but I had no idea what I was looking at on that code
jsclownfish
Post by jsclownfish »
Here is the code I used. I don't know if it ever went into the libraries...
//function to flash warning (parameter, high limt, low limit, x, y, decimal)
void Warningflash(int param, int high, int low, byte x, byte y, byte z)
  int mod=second()%2;
  if (param > high || param < low)
     if (mod==0) ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+40,y+10);
     else ReefAngel.LCD.DrawSingleMonitor(param, COLOR_RED, x, y, z);
 else ReefAngel.LCD.DrawSingleMonitor(param, DefaultFGColor, x, y, z);
