Re: Custom Main Screens
Posted: Tue May 21, 2013 8:56 pm
Super cool!!!
Can you post the code?
http://forum.reefangel.com/
Very nice looking screen! Great job!ReeferBee wrote:Thanks!
Done
binder wrote:Very nice looking screen! Great job!ReeferBee wrote:Thanks!
Done
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[7];
//static byte vtechmode=0;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawLargeText(3,255,8,16,"Redneck Reefin!", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,8,56,"Jason & Sarah's", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,32,65,"Money Pit", Font8x8);
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,109, "CWLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(0,255,88,108, "RBLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
#define SIMPLE_MENU
#define NUMBERS_8x16
#define FONT_8x8
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawLargeText(3,255,8,14,"Redneck Reefin!", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,8,55,"Jason & Sarah's", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,32,64,"Money Pit", Font8x8);
ReefAngel.LCD.DrawText(COLOR_RED,255, 6, 88, "--------------------");
ReefAngel.LCD.DrawText(COLOR_RED,255, 6, 125, "--------------------");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 123, "|");
ReefAngel.LCD.DrawLargeText(0,255,8,25,"TANK", Font8x8);
ReefAngel.LCD.DrawLargeText(224, 255, 42, 25, text, Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,8,35,"HOOD", Font8x8);
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(153, 255, 42, 35, text, Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,8,45,"ROOM", Font8x8);
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(66, 255, 42, 45, text, Font8x8);
ReefAngel.LCD.DrawText(0,255,100,25,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 35, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 75, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,96, "White=");
ReefAngel.LCD.DrawText(197,255,46,96, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue()),
ReefAngel.LCD.DrawText(0,255,72,96, "Blue=");
ReefAngel.LCD.DrawText(3,255,106,96, ReefAngel.PWM.GetActinicValue());
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.ActinicLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Wavemaker2( Port6 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.StandardFan( Port8 );
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(12,15,22,45,15,100,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(13,0,22,0,15,100,60,DaylightPWMValue);
CheckCloud();
ReefAngel.Portal( "jegillis" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(15,00)
#define End_Cloud_Before NumMins(22,00)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,15,180);
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=15;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,8,108,"Cloud");
ReefAngel.LCD.DrawText(0,255,8,118,"00:00");
ReefAngel.LCD.DrawText(0,255,90,108,"Storm");
ReefAngel.LCD.DrawText(0,255,48,108,"Length");
ReefAngel.LCD.DrawText(0,255,90,118,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=8; else x=14;
ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart/60));
if ((cloudstart%60)>=10) x=58; else x=64;
ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart%60));
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=90; else x=96;
ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=108; else x=114;
ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//function to flash warning (parameter, high limt, low limit, x, y, decimal)
void Warningflash(int param, int high, int low, byte x, byte y, byte z)
int mod=second()%2;
if (param > high || param < low)
if (mod==0) ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+40,y+10);
else ReefAngel.LCD.DrawSingleMonitor(param, COLOR_RED, x, y, z);
else ReefAngel.LCD.DrawSingleMonitor(param, DefaultFGColor, x, y, z);
Really Cool design but, i can't find where did you post the code...SuperDodge wrote:
Here's where my screen seems to have settled at during my first week of tinkering with my Reef Angel.
The line that says "Lagoon" will eventually update with my Vortech status (when I save some coin for the RF adapter. The line is always centered
The line that says "Clear Skies" will update to say "Cloudy(XX:XX)" or "Storms(XX:XX)" if there is a cloud or a cloud with lightning coming. This line is always centered.
The moon status updates throughout the month and is always centered.
The line that says W:100% B:100% R:100% updates in real-time to reflect all three channels on my AI Nano fixture. The line is always centered as the position of the numbers changes depending on the number of digits.
THANKS TO EVERYONE WHO PROVIDED GREAT CODE AND IDEAS THROUGHOUT THIS THREAD!
CODE REMOVED BECAUSE I FOUND AN ERROR - WILL REPOST WHEN FIXED
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
//Custom Main, Graph & Menu
static unsigned long PumpSpeed = InternalMemory.DCPumpSpeed_read(); //Sets Value to pump speed
static int PumpOffset = (PumpSpeed*1.10); //Change Value to match AntiSyncOffset value
void DrawCustomMain() {
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_BLACK,COLOR_WHITE, 6, 2, " GugsJr's Reef");
ReefAngel.LCD.DrawDate(6, 118);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE,COLOR_WHITE, 24,16,"Jebao Mode:");
if (now()%SECS_PER_DAY<52200|| now()%SECS_PER_DAY >=1800) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,28,26,"Night Mode");
else if (InternalMemory.DCPumpMode_read()==Lagoon) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,42,26,"Lagoon");
else if (InternalMemory.DCPumpMode_read()==ReefCrest) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,26,"Reef Crest");
else if (InternalMemory.DCPumpMode_read()==ShortPulse) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,22,26,"Short Pulse");
else if (InternalMemory.DCPumpMode_read()==LongPulse) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,25,26,"Long Pulse");
else if (InternalMemory.DCPumpMode_read()==NutrientTransport) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
else if (InternalMemory.DCPumpMode_read()==TidalSwell) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
else if (InternalMemory.DCPumpMode_read()==Custom) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Custom");
else if (InternalMemory.DCPumpMode_read()==Else) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Else");
else if (InternalMemory.DCPumpMode_read()==Sine) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Sine");
else if (InternalMemory.DCPumpMode_read()==Gyre) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Gyre");
else if (InternalMemory.DCPumpMode_read()== Constant) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,35,27,"Constant");
ReefAngel.LCD.DrawLargeText(0,255,17,36,"Display");
ReefAngel.LCD.DrawLargeText(0,255,17,49,"Temp");
ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
ReefAngel.LCD.DrawLargeText(0,255,100,45,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 65, text, Num8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,89, "Left");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,16,100, InternalMemory.DCPumpSpeed_read());
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,50,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,49,89, "Center");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,59,100, PumpOffset);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,93,80, "Jebao");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, " Right");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,100,100, InternalMemory.DCPumpSpeed_read());
// RA+ for 75 Gallon tank
// Updated: 6/18/2017
// Expansion Modules Added:
// Expansion Hub
// Salinity
// Water Level
// Features:
// T1 - Tank Temperature probe
// T2 - Room Temperature probe
// AP - N/A
// DP - Gyre XF230
// Water Level - Water Level of reservoir
// PH - probe in sump
// Salinity - probe in sump
// Ports:
// 1 - Skimmer
// 2 - WM Left
// 3 - Heater
// 4 - Return
// 5 - Maxspect Gyre XF230
// 6 - PhosBan 150 Reactor
// 7 - Hydra 26 HD Power Supply
// 8 - Hydra 26 HD Power Supply
// Global variables
// used for test controller
//#define __TEST__
// starting point for left edge of screen
#define LEFT_EDGE 8
// DC Pump mode text strings
String PUMP_MODES[] = {"Constant","Lagoon","ReefCrest","Short Pulse","Long Pulse","Nutrient",
"Tidal Swell","Feeding","","Night","","Custom","Else","Sine","Gyre"};
// graphics for the water level bar
const unsigned PROGMEM char BAR_CENTER[] = {0x92, 0x92, 0xFF, 0xFF, 0xFF, 0xFF, 0xDB, 0xDB, 0xB6, 0xB6, 0xB6, 0xB6};
const unsigned PROGMEM char BAR_WL_LEFT[] = {0x29, 0x29, 0x2A, 0x72, 0x72, 0x96};
const unsigned PROGMEM char BAR_WL_RIGHT[] = {0x6E, 0x92, 0x96, 0xDB, 0xDB, 0xDB};
const unsigned PROGMEM char BAR_DP_LEFT[] = {0xAB, 0xAB, 0xAF, 0xD3, 0xD7, 0xFB};
const unsigned PROGMEM char BAR_DP_RIGHT[] = {0xB7, 0xB7, 0xB7, 0xDB, 0xDB, 0xDB};
// Memory Locaitons
#define CURT_MEMORY 50
#define DCPUMP_NIGHT_MODE CURT_MEMORY
#define DCPUMP_NIGHT_SPEED DCPUMP_NIGHT_MODE + 1
#define DCPUMP_NIGHT_DURATION DCPUMP_NIGHT_MODE + 2
#define DCPUMP_NIGHT_THRESHOLD DCPUMP_NIGHT_MODE + 3
// Custom functions
boolean isNightTime();
void checkCustomMemoryValues();
uint8_t DCPumpNightMode_read();
uint8_t DCPumpNightSpeed_read();
uint8_t DCPumpNightDuration_read();
uint8_t DCPumpNightThreshold_read();
uint8_t CustomRead(int address);
void CustomWrite(int address, const uint8_t value);
ReefAngel.AddWifi();
ReefAngel.AddStandardMenu();
ReefAngel.AddSalinityExpansion();
// Default Salinity compensation
ReefAngel.Salinity.SetCompensation(0);
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit | Port8Bit;
// Feeding and water change mode speeds
ReefAngel.DCPump.FeedingSpeed = 0;
ReefAngel.DCPump.WaterChangeSpeed = 0;
ReefAngel.Relay.On(Port1); // Skimmer
ReefAngel.Relay.On(Port4); // Return
ReefAngel.Relay.On(Port5); // Gyre XF230
ReefAngel.Relay.On(Port6); // PhosBan Reactor
ReefAngel.Relay.On(Port7); // Hydra 26 HD
ReefAngel.Relay.On(Port8); // Hydra 26 HD
// Ports that are not in use
ReefAngel.Relay.Off(Port2);
Night mode - use alternate memory locations
Day mode - default memory locations
if ( isNightTime() ) {
// force in either Constant mode or Long Pulse mode
// use the nighttime memory locations
ReefAngel.DCPump.Mode = DCPumpNightMode_read();
ReefAngel.DCPump.Speed = DCPumpNightSpeed_read();
ReefAngel.DCPump.Duration = DCPumpNightDuration_read();
ReefAngel.DCPump.Threshold = DCPumpNightThreshold_read();
} else {
// use default memory values for the modes
#define LINE1 19
#define LINE2 47
#define LINE3 70
#define WL_BAR_OFFSET 41
#define DC_BAR_OFFSET 4
// Fonts in use: NUMBERS_16x16, FONT_8x16
byte x = 6;
byte y = 3;
byte t;
char text[11];
boolean fNight = isNightTime();
#ifdef __TEST__
ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, x, y, "_____TEST CODE_____");
#else
// Date & time
ReefAngel.LCD.DrawDate(x, y);
#endif // __TEST__
// Divider line
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
// Draw T1
x = 8;
y = LINE1; // 19
// NOTE huge numbers are 16x16 (width x height)
ReefAngel.LCD.Clear(DefaultBGColor, x, y, x+64, y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
// Draw T2
// NOTE 4 digits for T1 (16 width, 16*4 pixels)
x = 80;
#ifdef __TEST__
ReefAngel.Params.Temp[T2_PROBE] = 810;
#endif // __TEST__
if(ReefAngel.Params.Temp[T2_PROBE] > 0) {
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x, y, "T2:");
// NOTE "T2:" is 3 chars of 5 pixels each (15 pixels), plus 2 pixels space after, start on 3rd pixel
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, x+18, y, 10);
} else {
// No, T2, clear the entire space for it
ReefAngel.LCD.Clear(DefaultBGColor, x, y, x+38, y+8);
// Draw T3 if present
y = 29;
#ifdef __TEST__
ReefAngel.Params.Temp[T3_PROBE] = 796;
#endif // __TEST__
if(ReefAngel.Params.Temp[T3_PROBE] > 0) {
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x, y, "T3:");
// NOTE "T3:" is 3 chars of 5 pixels each (15 pixels), plus 2 pixels space after, start on 3rd pixel
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor, x+18, y, 10);
} else {
// No, T3, clear the entire space for it
// Draw PH
y = LINE2;
#ifdef __TEST__
strcpy(text, "8.20");
#else
#endif // __TEST__
// NOTE ph max is X.XX, 4 digits
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 3, y, "pH:", Font8x16);
x = 29;
// TODO confirm width to clear
ReefAngel.LCD.Clear(DefaultBGColor, x, y, x+32, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x, y, text, Font8x16);
// Draw Salinity
#ifdef __TEST__
strcpy(text, "35.0");
#else
#endif // __TEST__
// NOTE Salinity max is XX.X, 4 digits
x = 69;
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, DefaultBGColor, x, y, text, Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, DefaultBGColor, 102, y, "ppt", Font8x16);
// Draw Water Level Box (used code from libraries)
y = LINE3;
// TODO determine color to use for WATER level (COLOR_ROYALBLUE)
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE, DefaultBGColor, 8, y, "Water");
#ifdef __TEST__
t = 79;
#else
t = ReefAngel.WaterLevel.GetLevel(0);
#endif // __TEST__
// sanity check, ensure level isn't greater than 100
if(t > 100) {
t = 100;
x = 99;
// draw value to the right of the bar
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE, DefaultBGColor, 99, y, " ");
sprintf(text, "%d%%", t);
ReefAngel.LCD.DrawText(COLOR_ROYALBLUE, DefaultBGColor, 99, y, text);
// Water level is truncated to 50 pixels instead of 100
// Every 2% equals 1 pixel
// divide water level by 2
t = t / 2;
byte b;
// draw the image to the left of the center line, filled bar background
for(b = 0; b < t; b++)
// swidth,sheight, X, Y, img
ReefAngel.LCD.DrawImage(1, 6, b + WL_BAR_OFFSET, y + 2, BAR_WL_LEFT);
// draw the center image, indicator
ReefAngel.LCD.DrawImage(2, 6, t + WL_BAR_OFFSET, y + 2, BAR_CENTER);
// draw the image to the right of the center line, unfilled bar background
for(b = t; b < 50; b++)
ReefAngel.LCD.DrawImage(1, 6, b + WL_BAR_OFFSET + 2, y + 2, BAR_WL_RIGHT);
// Draw DC Pump Mode (next line)
y = 88;
x = 4;
if (fNight) {
t = DCPumpNightMode_read();
} else {
t = InternalMemory.DCPumpMode_read();
// copy the string from the global array into a buffer of 11 chars for display on screen
PUMP_MODES[t].toCharArray(text, 11);
// NOTE text is max of 11 chars, 11*5=55 pixels
ReefAngel.LCD.Clear(DefaultBGColor, x, y, x+55, y+8);
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, x, y, text);
// Draw Day/Night schedule (same line as pump mode)
// NOTE Center text in available space between column 72 and 128
if (fNight) {
strcpy(text, "Night");
b = COLOR_BLACK;
t = COLOR_WHITE;
x = 82;
} else {
strcpy(text, "Day");
b = DefaultBGColor;
t = COLOR_BLACK;
x = 90;
// clear entire space with the background color
// clear bigger space than just for the text to line up
// the bottom of the square with the dc pump speed bar
ReefAngel.LCD.Clear(b, 74, y, 128, y+18);
ReefAngel.LCD.DrawLargeText(t, b, x, y+1, text, Font8x16);
// Draw DC Pump Speed bar
y = 98;
x = 58;
#ifdef __TEST__
t = 65;
#else
t = ReefAngel.PWM.GetDaylightValue();
#endif // __TEST__
ReefAngel.LCD.Clear(DefaultBGColor, x, y, x+15, y+8);
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, x, y, t);
// scale bar to be half width, divide value by 2
t = t / 2;
ReefAngel.LCD.DrawImage(1, 6, b + DC_BAR_OFFSET, y + 2, BAR_DP_LEFT);
ReefAngel.LCD.DrawImage(2, 6, t + DC_BAR_OFFSET, y + 2, BAR_CENTER);
ReefAngel.LCD.DrawImage(1, 6, b + DC_BAR_OFFSET + 2, y + 2, BAR_DP_RIGHT);
// Draw outlet bar
t = ReefAngel.Relay.RelayData;
t &= ReefAngel.Relay.RelayMaskOff;
t |= ReefAngel.Relay.RelayMaskOn;
ReefAngel.LCD.DrawOutletBox(12, 112, t);
boolean fResult = false;
byte bOffHour = InternalMemory.StdLightsOffHour_read();
byte bOffMinute = InternalMemory.StdLightsOffMinute_read();
byte bOnHour = InternalMemory.StdLightsOnHour_read();
byte bOnMinute = InternalMemory.StdLightsOnMinute_read();
If current hour is off hour and current minute is equal or after off minute, night time is true
if current hour is after off hour, night time is true
(beyond midnight, aka early hours in morning, overnight wrap)
if current hour is before on hour, night time is true
if current hour is on hour and current minute is before off minute, night time is true
if ( ((hour() == bOffHour) && (minute() >= bOffMinute)) ||
(hour() > bOffHour) ||
(hour() < bOnHour) ||
((hour() == bOnHour) && (minute() < bOnMinute)) )
fResult = true;
return fResult;
if ( DCPumpNightMode_read() > 14 )
// Default to Constant Mode
CustomWrite(DCPUMP_NIGHT_MODE, 0);
if ( DCPumpNightSpeed_read() > 100 )
// Default to 0 speed
CustomWrite(DCPUMP_NIGHT_SPEED, 0);
if ( DCPumpNightDuration_read() > 100 )
// Default to 0 duration
CustomWrite(DCPUMP_NIGHT_DURATION, 0);
if ( DCPumpNightThreshold_read() > 100 )
// Default to 30 threshold
CustomWrite(DCPUMP_NIGHT_THRESHOLD, 30);
return CustomRead(DCPUMP_NIGHT_MODE);
return CustomRead(DCPUMP_NIGHT_SPEED);
return CustomRead(DCPUMP_NIGHT_DURATION);
return CustomRead(DCPUMP_NIGHT_THRESHOLD);
#if not defined __SAM3X8E__
return eeprom_read_byte((unsigned char *) address);
#else
return SPIEEPROM.Read(address);
#endif
if (CustomRead(address) != value )
eeprom_write_byte((unsigned char *) address, value);
#else
SPIEEPROM.Write(address, value);
#endif
