ReefAngel external web access [GUIDE]
Posted: Fri May 04, 2012 12:59 am
by Poiromaniax
Hey All,
Attached is my guide to setting up ReefAngel External web access :)
Enjoy and let me know if it helps
EDIT - Using this guide first should make life a bit easier too! - http://forum.reefangel.com/viewtopic.php?f=14&t=3427
Re: ReefAngel external web access [GUIDE]
Posted: Fri May 04, 2012 5:38 am
Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
Otherwise, nice guide. :)
Also, did you know that http://www.no-ip.com offers the free dynamic service (if you didn't want to pay dyndns)? I personally have accounts with both and they both work just fine for me.
Posted: Fri May 04, 2012 7:30 am
by Poiromaniax
binder wrote:Note: Your "Add Custom Service" step should be able to just do Port 2000 to Port 2000 instead of Port 1999 to Port 2001.
cool :)
Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one :( I wish I couldve
Posted: Fri May 04, 2012 1:13 pm
by Sebyte
Nice work :D
I will add a link to this from my "where to get started" guide, if that's ok?
Posted: Sat May 05, 2012 10:58 am
by Poiromaniax
Sebyte wrote:Nice work :D
With pleasure :)
Posted: Tue Jun 04, 2013 11:08 am
by oscarinw
Poiromaniax wrote: Problem is my router only offers dynamic DNS from dyndns.org. I can't use a different one :( I wish I couldve
Actually if you choose the dyndns from the dropdown menu and then input the host you get from no-ip.com, it works just the same... It stumped me too for a little while and then figured it's the same.
Hope it helps!
Posted: Wed Jun 05, 2013 8:34 am
by Poiromaniax
Hope it helps!
It all depends on your brand of router and the firmware it's on I believe.
As far as I'm aware, you can also get custom firmware to add more dns service providers
Thanks for the info though - hopefully it will help someone out :)
Posted: Wed Apr 20, 2016 8:48 pm
by Echo5delta16
So this reef angel cant be used to access from anywhere unless I BUY a dydns thing?
Posted: Thu Apr 21, 2016 3:04 am
by cosmith71
