Okay if renaming files then the compiler cache probably wasn't clearing correctly. If you have renamed files then click "Build>Clean Solution" to clear the cache.thekameleon wrote:@Tim,
the two things I was doing was editing code files and renaming a few code files. I will try to turn on the optimization and see if it works with the latest.
You can also switch on "Tools>Options>Visual Micro>Compiler>Show Build Folder". Switching this option on will give you a little extra detail when you compile. A CTRL+CLICK hyperlink will allow you to view the temporary folder that the compiler uses during an Arduino build. Deleting the TEMPORARY folder will also clear the cache but it can also be useful to have easy access to the build output and the compiled Arduino files.
Best of luck, do feel free to join the Visual Micro forum if you need any speedy help. We can't always promise to spot posts on other forums, not enough man power
