Clouds and Lightining Effects using standard PWM channels
Would you like to help?
Hi All,
Here is a similar code used on the PWM expansion module, except this one is made for the standard channels.
Attached is a demo PDE to be used.
Try it out and let me know if it works. I'd love to see a video.
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
CloudStandard.pde
(8.28 KiB) Downloaded 986 times
alexwbush
Re: Clouds and Lightining Effects using standard PWM channel
Post by alexwbush »
Sorry I've been out of the loop lately... I've been all over the place. I was actually up in your neck of the woods (kind of) at Yosemite. I'm going to change out my board and put this on and should have you a video this week. It's pretty much what I was looking for a while ago, right? Random light effects?
yeah :)
cain
Post by cain »
i get an error:
"DaylightPWMValue" was not declared in this scope
If you look at the PDE file attachde above, the variables need to be declared on top of the PDE and also initialized.
Please look at that PDE for an example on how to make it work.
You need this above setup():
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
You need this inside loop():
  ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
  CheckCloud();
cain
Post by cain »
  CheckCloud();
do i need to change the values?
like 10,00 and 22,15? or leave it as is.
Change it to suit your schedule :)
alexwbush
Post by alexwbush »
Here's how mine ran. Lightning storm over 10 min starting at 90%. I think we should maybe shorten it up a bit and repeat 2-3 times for a simulated storm. Thoughts?
[youtube]http://www.youtube.com/watch?v=Grz2e0C9WHs[/youtube]
alexwbush
Post by alexwbush »
and yes, my fish did get kind of scared and retreated until the torch for protection... so we'll see how long if this doesn't stress them too much
oh, and if this can be built into a menu item... that's what I want to work on next! I'd like to be able to show it as a party favor.. you know "hey, check this out."
Anyway to just eliminate the lighting parts of this? I'm just looking for random clouds lasting in duration of 15min-2hours...no lighting. :)
Also is it possible to use: instead of PWMSlope?
ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,80,0) );//80%
ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );//85%
Yes and yes.
You will see in the code that there is a % chance for the lightning. Just change it to 0%.
That would mean never happens :)
Anyway to fit this? Custom display adjustments or?
I'm at 32,902 of 32,256
// Autogenerated file by RAGen (v1.2.2.171), (06/09/2012 20:37)
// RA_060912_2037.ino
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define NUMBERS_8x16
#define SIMPLE_MENU
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
 // ReefAngel.LCD.DrawText(0,255,20,57,MoonPhaseLabel());
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
  ReefAngel.LCD.DrawText(0,255,8,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
     ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.PHMin=830; // 830=PH10.0
    ReefAngel.PHMin=430; // 430=PH7.0
    ReefAngel.SingleATO( true,Port1,600,0 );
    pinMode(lowATOPin,OUTPUT);
    //pinMode(highATOPin,false);//disable highATOpin
    ReefAngel.Relay.On(Port3);//Koralia
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.Off(Port2);//Off
    ReefAngel.Relay.Off(Port1);//Off
    ReefAngel.Relay.On(Port8);//temp fan on (see Standard Fan)
    //ReefAngel.AddWifi();
  CheckCloud();
    //ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights(Port7,8,15,18,30);//On 8:15 Off 6:30
    ReefAngel.StandardFan(Port8,900,910);
//5 min turbulence wavemaker
   if ( (hour()>=7 && hour()<11))
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(35,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
else if ( (hour()>=11 && hour()<13) )
if (cycle<0)
nexttoggle+=random(10,20);
state=!state;
if (cycle<5)
else if ( (hour()>=13 && hour()<20) )
if (cycle<0)
nexttoggle+=random(15,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
   // ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,80,0) );//80%
   // ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );//85%
    if (hour()>=6 && hour()<20)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
void CheckCloud()
#define Lightning_Change_per_Cloud 0
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
    //ReefAngel.LCD.Clear(255,0,120,132,132);
    //ReefAngel.LCD.DrawText(0,255,5,120,"C");
    //ReefAngel.LCD.DrawText(0,255,11,120,"00:00");
    //ReefAngel.LCD.DrawText(0,255,45,120,"L");
    //ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
Try removing the large fonts.
Got it to fit...I'm having problems with switching from PWMSlope to PWMParabola? I'm guessing it is because of how it is defined in the code...how do I go about using Parabola instead of Slope?
Like this?
ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
  DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
  CheckCloud();
I've noticed that PWMSlope is in the code? Will this mess up?
Here:
And here:
Yes, it should work the way you have.
Don't worry about the ReversePWM. It's for the cloud effect.
It's uploaded. We will see how it works!
Ok it seems to be working...how does this work for dimming? I noticed a ReversePWM based on my Cool White ramping down one step at a time...then it went to 0..then jumped by increments of 10 to 70...then down in increments of 10 to 0...
The other thing...the "Cloud" on my custom main just stayed at 00:00...how do I fix this?
Current code:
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
  CheckCloud();
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
state=!state;
if (cycle<5)
void CheckCloud()
#define Clouds_Every_X_Days 2
  // In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
  // In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
    ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
    ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
This is the section that draws the cloud time.
You moved the label, but didn't mode the rest.
      int x=0;
What's the purpose of:
ReefAngel.LCD.DrawText(0,255,48,57,"00:00"); <---Mainly this one
Just to draw zeros.
Otherwise, when you go from for example 17:10 to 9:32, if you don't clear or draw zeros, you would see 19:32 instead of 09:32.
ok...so should they overlap???? or be in a different location of them?
Yes, they should overlap, so you actually draw over the 00:00
For both the
ReefAngel.LCD.DrawText(0,255,48,57,(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,40,57,(cloudstart%60));
Both should overlap 00:00?
I don't think that will work.
That's what the x is for.
When it is >=10, it's 2 digits and you have to offset the drawing by 6 pixels.
So, I think it should be something like this for the hour:
if ((cloudstart/60)>=10) x=40; else x=46;
And same thing for the minutes.
if ((cloudstart%60)>=10) x=48; else x=54;
got it:
And the last position?
int x=0;
ReefAngel.LCD.DrawText(0,255,x,120<----(should be 57?),(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,x,120<----(should be 57?),(cloudstart%60));
For proper placement?
yes
Never knew about the overlap thing...very cool idea. Thanks a ton!
Still a little confused...I removed the 00:00 to see what was going on under it and it looks like this:
If I add the 00:00 back...it is just what you see with the 00:00 over it
If I try to do adjustments for x...they just dissapear.
Flipped them
int x=0;
if ((cloudstart/60)>=10) x=48; else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=40; else x=46;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
...now have this
