Clouds and Lightining Effects using standard PWM channels
Would you like to help?
Re: Clouds and Lightining Effects using standard PWM channel
Yes and yes.
You will see in the code that there is a % chance for the lightning. Just change it to 0%.
That would mean never happens :)
Anyway to fit this? Custom display adjustments or?
I'm at 32,902 of 32,256
// Autogenerated file by RAGen (v1.2.2.171), (06/09/2012 20:37)
// RA_060912_2037.ino
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define NUMBERS_8x16
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
 // ReefAngel.LCD.DrawText(0,255,20,57,MoonPhaseLabel());
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  //ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
  ReefAngel.LCD.DrawText(0,255,8,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
     ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.PHMin=830; // 830=PH10.0
    ReefAngel.PHMin=430; // 430=PH7.0
    ReefAngel.SingleATO( true,Port1,600,0 );
    pinMode(lowATOPin,OUTPUT);
    //pinMode(highATOPin,false);//disable highATOpin
    ReefAngel.Relay.On(Port3);//Koralia
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.Off(Port2);//Off
    ReefAngel.Relay.Off(Port1);//Off
    ReefAngel.Relay.On(Port8);//temp fan on (see Standard Fan)
    //ReefAngel.AddWifi();
  ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
  CheckCloud();
    //ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights(Port7,8,15,18,30);//On 8:15 Off 6:30
    ReefAngel.StandardFan(Port8,900,910);
//5 min turbulence wavemaker
   if ( (hour()>=7 && hour()<11))
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(35,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
else if ( (hour()>=11 && hour()<13) )
if (cycle<0)
nexttoggle+=random(10,20);
state=!state;
if (cycle<5)
else if ( (hour()>=13 && hour()<20) )
if (cycle<0)
nexttoggle+=random(15,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
   // ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,80,0) );//80%
   // ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );//85%
    if (hour()>=6 && hour()<20)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Lightning_Change_per_Cloud 0
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
    //ReefAngel.LCD.Clear(255,0,120,132,132);
    //ReefAngel.LCD.DrawText(0,255,5,120,"C");
    //ReefAngel.LCD.DrawText(0,255,11,120,"00:00");
    //ReefAngel.LCD.DrawText(0,255,45,120,"L");
    //ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Try removing the large fonts.
Got it to fit...I'm having problems with switching from PWMSlope to PWMParabola? I'm guessing it is because of how it is defined in the code...how do I go about using Parabola instead of Slope?
Like this?
ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
  DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
  CheckCloud();
I've noticed that PWMSlope is in the code? Will this mess up?
Here:
And here:
Yes, it should work the way you have.
Don't worry about the ReversePWM. It's for the cloud effect.
It's uploaded. We will see how it works!
Ok it seems to be working...how does this work for dimming? I noticed a ReversePWM based on my Cool White ramping down one step at a time...then it went to 0..then jumped by increments of 10 to 70...then down in increments of 10 to 0...
The other thing...the "Cloud" on my custom main just stayed at 00:00...how do I fix this?
Current code:
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
  CheckCloud();
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
state=!state;
if (cycle<5)
if (cycle<0)
state=!state;
if (cycle<5)
void CheckCloud()
#define Clouds_Every_X_Days 2
  // In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
  // In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
    ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
    ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
This is the section that draws the cloud time.
You moved the label, but didn't mode the rest.
      int x=0;
What's the purpose of:
ReefAngel.LCD.DrawText(0,255,48,57,"00:00"); <---Mainly this one
Just to draw zeros.
Otherwise, when you go from for example 17:10 to 9:32, if you don't clear or draw zeros, you would see 19:32 instead of 09:32.
ok...so should they overlap???? or be in a different location of them?
Yes, they should overlap, so you actually draw over the 00:00
For both the
ReefAngel.LCD.DrawText(0,255,48,57,(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,40,57,(cloudstart%60));
Both should overlap 00:00?
I don't think that will work.
That's what the x is for.
When it is >=10, it's 2 digits and you have to offset the drawing by 6 pixels.
So, I think it should be something like this for the hour:
if ((cloudstart/60)>=10) x=40; else x=46;
And same thing for the minutes.
if ((cloudstart%60)>=10) x=48; else x=54;
got it:
And the last position?
int x=0;
ReefAngel.LCD.DrawText(0,255,x,120<----(should be 57?),(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,x,120<----(should be 57?),(cloudstart%60));
For proper placement?
yes
Never knew about the overlap thing...very cool idea. Thanks a ton!
Still a little confused...I removed the 00:00 to see what was going on under it and it looks like this:
If I add the 00:00 back...it is just what you see with the 00:00 over it
If I try to do adjustments for x...they just dissapear.
Flipped them
int x=0;
if ((cloudstart/60)>=10) x=48; else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=40; else x=46;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
...now have this
The alignment is off.
You will need to align them perfect just like it was before.
got them to line up i think? What exactly is this determining? The time before the next cloud?
It reads 29:00 right now
If I'm reading this right...it states, "14:29" thus my next cloud is at 2:29pm? Or am I way off?
yeah. whatch and see if it is correct
It works...going to post a video soon
Ramp from cloud and back...showed 12 min duration (perfect) and next cloud due at 1553
AWESOME!
Of course the phone's camera has no white balance nor does it show shimmer very well from the LEDs
And new main showing next cloud and next duration (in minutes)....
NMTX
Post by NMTX »
I'm unsure entirely if this has been covered, but is there a way to define how much the daylights dim during cloud cover? In other words, instead of dimming all the way down to 0V, dim down to 1V (or 10%, however you look at it)? If so, how?
It would be kind of cool if the dimming amount was random, but hey, it's cool as-is. :)
Change this line:
To this:
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,10,180);
Good thought! I'll be changing this on mine
NMTX
Post by NMTX »
Yeah, my LED-based light (named for a Greek god) is great, but below 1V, the LEDs just shut down since the driver can't go lower. As I was watching the cloud-dimming simulation—something that I really do enjoy, thank you Roberto et al—I just thought it would look smoother in my application to stop the whites at 1V rather than going off entirely, and still give the desired effect.
I really do enjoy this controller.
