Clouds and Lightining Effects using standard PWM channels
Would you like to help?
PostPosted: Wed Aug 22, 2012 10:46 am
Just to draw zeros.
Otherwise, when you go from for example 17:10 to 9:32, if you don't clear or draw zeros, you would see 19:32 instead of 09:32.
PostPosted: Wed Aug 22, 2012 10:47 am
ok...so should they overlap???? or be in a different location of them?
PostPosted: Wed Aug 22, 2012 10:48 am
Yes, they should overlap, so you actually draw over the 00:00
PostPosted: Wed Aug 22, 2012 10:52 am
For both the
ReefAngel.LCD.DrawText(0,255,48,57,(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,40,57,(cloudstart%60));
Both should overlap 00:00?
PostPosted: Wed Aug 22, 2012 11:01 am
I don't think that will work.
That's what the x is for.
When it is >=10, it's 2 digits and you have to offset the drawing by 6 pixels.
So, I think it should be something like this for the hour:
if ((cloudstart/60)>=10) x=40; else x=46;
And same thing for the minutes.
if ((cloudstart%60)>=10) x=48; else x=54;
PostPosted: Wed Aug 22, 2012 11:06 am
got it:
And the last position?
int x=0;
ReefAngel.LCD.DrawText(0,255,x,120<----(should be 57?),(cloudstart/60));
ReefAngel.LCD.DrawText(0,255,x,120<----(should be 57?),(cloudstart%60));
For proper placement?
PostPosted: Wed Aug 22, 2012 11:08 am
yes
PostPosted: Wed Aug 22, 2012 11:09 am
Never knew about the overlap thing...very cool idea. Thanks a ton!
PostPosted: Wed Aug 22, 2012 11:22 am
Still a little confused...I removed the 00:00 to see what was going on under it and it looks like this:
If I add the 00:00 back...it is just what you see with the 00:00 over it
If I try to do adjustments for x...they just dissapear.
PostPosted: Wed Aug 22, 2012 11:36 am
Flipped them
int x=0;
if ((cloudstart/60)>=10) x=48; else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=40; else x=46;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
...now have this
Return to Tutorials
