Clouds and Lightining Effects using standard PWM channels
Would you like to help?
saf1
Re: Clouds and Lightining Effects using standard PWM channel
Post by saf1 »
Does this feature work in the current libraries or development libs I should say?
Also, would be sort of cool if you could add in a option to turn on, for a short burst, say your ports that control wave makers. So you mix in the cloud and storm effects with a quick burst of current.
Probably be a bad thing if it got stuck on...but would be sort of good to build up all the movement for a short period of time. I'm sort of doing that with the Hydor 425's I'm using or trying to anyway. The Koralia circulation and wave pumps say they work on timers. So I'm randomly turning on the ports on the relay box on and off between 60 and 300 seconds. With 2 in the tank I'm trying to find a way to randomly let them overlap at least once every 24 hours...tie that to the storm module would be really cool.
Yeah, it works.
You can also change the code to move water more violently.
Not sure how good it would be with a koralia though. Maybe Jebao, Tunze or Vortech would give you better results.
fran_
Post by fran_ »
Hi, I try to use this code
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
  DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
  CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          ActinicPWMValue=100;
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
but I get this error
'PWMSlope' was not declared in this scope
Watchdog Timer
Version Menu
Dimming Signal
Simple Menu
In file included from CloudStandard.cpp:18:
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:86: error: 'ParamsStruct' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:88: error: 'RA_NokiaLCD' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:89: error: 'RA_JoystickClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:90: error: 'LEDClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:92: error: 'RA_ATOHighClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:93: error: 'RA_ATOLowClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:94: error: 'RA_TempSensorClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:95: error: 'RelayClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:97: error: 'RA_PWMClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:133: error: 'TimerClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:315: error: 'Total_Menus' was not declared in this scope
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:316: error: 'Total_Menus' was not declared in this scope
CloudStandard.cpp: In function 'void loop()':
CloudStandard.pde:-1: error: 'PWMSlope' was not declared in this scope
CloudStandard.pde:-1: error: 'class ReefAngelClass' has no member named 'PWM'
CloudStandard.cpp: In function 'void CheckCloud()':
CloudStandard.pde:-1: error: 'NumMins' was not declared in this scope
CloudStandard.pde:-1: error: 'class ReefAngelClass' has no member named 'LCD'
fran_
Post by fran_ »
I have deleted arduino folder and reinstalled RA and the problem persists - 'PWMSlope' was not declared in this scope. Can be a problem in the code?
Sorry.... Yes, it was code related.
Try this:
  CheckCloud();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
          DaylightPWMValue=0;
          ActinicPWMValue=0;
        delay(1);
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
fran_
Post by fran_ »
Thanks Roberto, works perfect.
Can I change this
  CheckCloud();
for this?
  ActinicPWMValue=PWMSlope(10,00,21,00,1,100,120,1);
  DaylightPWMValue=PWMSlope(10,00,21,00,0,100,120,0);
  CheckCloud();
to use actinic channel 1% as moonlight
jjdezek
Post by jjdezek »
i read through this and noticed it says pwm for everything. does this work for anolog? I have 3 heat sinks over my 210 with the meanwell ELN 60-48D drivers hooked up to the anolog expansion. right now all white are hooked to same port 0 and all blues are hook to same port 1 but i can hook them up to different ports so each heat sink is on its own port and allow for the effect of a cloud passing over my tank if thats possible? the lightening would be neat as well but more interested in the cloud.
I believe its the same commands for pwm and analog. The hardware takes care of the differences.
jjdezek
Post by jjdezek »
cool. well i have no idea now to do coding so if anyone could figure out how to do a cloud slowly passing over my tank from one side to the other that would be cool. say i have left heat sink whites in port 0 blues in port 1, middle heat sink whites in port 2 blues in port 3, right heat sink whites in port 4 and blues in port 5. could it start dimming on left then middle then dim right and brighten left then middle and right with a slow moving cloud effect, or is that too complex?
Yeah, totally doable :)
Let me try to find some time to put this together.
jjdezek
Post by jjdezek »
Ok cool thanks. I will get some wire to set my lights up to those ports.
Can you open a new thread for this?
Bruz4023
Post by Bruz4023 »
Did we open a new thread for this?
jegillis
Post by jegillis »
I think I broke something my storm is after the clouds is that right?
void CheckCloud()
#define Start_Cloud_After NumMins(15,00)
#define End_Cloud_Before NumMins(22,00)
#else
#endif
      if (cloudchance)
  if (cloudchance)
      DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,15,180);
          DaylightPWMValue=0;
          ActinicPWMValue=15;
        delay(1);
      cloudindex++;
    ReefAngel.LCD.DrawText(0,255,8,108,"Cloud");
    ReefAngel.LCD.DrawText(0,255,8,118,"00:00");
    ReefAngel.LCD.DrawText(0,255,90,108,"Storm");
    ReefAngel.LCD.DrawText(0,255,48,108,"Length");
    ReefAngel.LCD.DrawText(0,255,90,118,"00:00");
      int x=0;
      if ((cloudstart/60)>=10) x=8; else x=14;
      ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart/60));
      if ((cloudstart%60)>=10) x=58; else x=64;
      ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart%60));
      int x=0;
      if (((cloudstart+(cloudduration/2))/60)>=10) x=90; else x=96;
      ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))/60));
      if (((cloudstart+(cloudduration/2))%60)>=10) x=108; else x=114;
      ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
