Controlling Jebao/Tunze/Speedwave pumps
Would you like to help?
PostPosted: Sun Mar 23, 2014 5:56 pm
When you open up the dimming module if you see the following...
You will need to put a jumper across the ports that you want to change to Analog.
The jumpers are the same as you would put on a computer motherboard or hard drive.
PostPosted: Mon Mar 24, 2014 5:55 pm
Enviado desde mi GT-I9300 mediante Tapatalk
PostPosted: Sat Mar 28, 2015 12:23 am
rimai wrote:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,ReefCrestMode(60,20,true)*2.55);
analogWrite has a range of 0-255 instead of 0-100
ReefCrestMode is the default setting for the DC pump correct? And if I add ReefAngel.DCPump.UseMemory = true; I can set my pump from the portal or the RA Debug app in development.
PostPosted: Sat Apr 11, 2015 1:44 pm
rimai wrote:Remove R2.
rimai, are there any I'll effects by removing both resistors and leaving the cap?
PostPosted: Sat Apr 11, 2015 2:56 pm
Should be fine.
PostPosted: Sat Apr 11, 2015 2:57 pm
Actually, if you remove R1, the signal will never reach the pump. You must leave R1.
PostPosted: Mon Apr 13, 2015 11:13 am
Can I substitute the 10k with a 1.8k? At 100% my wp10 doesn't seem to be pushing as hard.
PostPosted: Mon Apr 13, 2015 11:16 am
The value won't affect the result, unless you increase to a really larger value, which would cause it to have slow response. You can even remove it and solder the pads together if you want to.
PostPosted: Mon Apr 13, 2015 11:19 am
Thanks rimai. I'll just leave the 10k on R1 then. But other than that it works great using the ATO port.
Previous
Return to Tutorials
