Controlling Jebao/Tunze/Speedwave pumps
Posted: Sat Mar 30, 2013 10:00 pm
Hi Everyone,
With the libraries v1.0.4 release, all the wave pattern functions are already included. I'm still keeping the previous post at the bottom for reference, but please consider it deprecated and don't use it anymore.
If you followed the previous post prior to v1.0.4, you will need to remove all that code you added at the bottom of your code or you will get a lot of errors with the new update.
If this is your first time, all you need to do is choose which wave pattern you would like to use in the thread below and call it in your code.
http://forum.reefangel.com/viewtopic.php?f=7&t=2844
For this example, we will use ReefCrest wave pattern at speed 60% with +/- 20%, which will give you a range of 40% to 80%.
Inside your loop() section of your INO code, you will see a section like this:
You must place the wave pattern code between those two comment lines. It will end up being like this:
The above lines will place your daylight channel in sync mode and actinic channel in anti-sync mode.
Upload your code and watch your Jebao or Tunze pumps being controlled by your Reef Angel.
Enjoy
Original post just for reference. Do not use this anymore.
Hi Everyone,
With the Jebao cables coming out and several members already getting them and getting very confused on how to get the pumps to work with the cable, I decided to put this little tutorial. This tutorial can be used for both Jebao and Tunze pumps.
Because the code used in this tutorial are not yet released together with our libraries, this is a temporary tutorial.
So, this will be updated as the libraries get updated.
Let's get coding....
The first thing you want to do is copy and paste this code to the very end of your INO code. You will see that the last line of your code will be a }. Paste after the last bracket.
Now, you must choose which wave pattern you wish to use. Please check this thread for the list of all wave patterns:
Enjoy
ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,false) ); // ReefCrest at 60% +/- 20% on anti-sync mode
Enjoy
Hi Everyone,
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
PulseMinSpeed=constrain(PulseMinSpeed,30,100);
PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
if (PulseSync)
return tspeed;
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
double x,y;
x=double(now()%(PulseDuration));
x/=PulseDuration;
x*=2.0*PI;
if (!PulseSync) x+=PI; // shift the sine wave for the right pump
y=sin(x);// y is now between -1 and 1
y+=1.0; // y is now between 0 and 2
y/=2.0; // y is now between 0 and 1
// now compute the tunze speed
y*=double(PulseMaxSpeed-PulseMinSpeed);
y+=double(PulseMinSpeed);
y+=0.5; // for proper rounding
// y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
return constrain(byte(y),30,100);
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,100);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
static byte WavePhase=0;
static time_t WaveStart=0;
static byte speed=PulseMinSpeed;
static byte anti_speed=PulseMinSpeed;
if (WavePhase==0)
WavePhase++;
WaveStart=now();
else if (WavePhase==1)
if (now()-WaveStart>2700)
WavePhase++;
if ((millis()-lastwavemillis) > PulseDuration)
if (speed==PulseMinSpeed)
speed=PulseMaxSpeed;
anti_speed=PulseMaxSpeed;
else if (WavePhase==2)
if (now()-WaveStart>4500) WavePhase++;
if (now()-WaveStart<=2760)
if (now()-WaveStart<=3300)
anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
else if (WavePhase==3)
if (now()-WaveStart>7200) WavePhase++;
else if (WavePhase==4)
if (now()-WaveStart>9000) WavePhase=0;
if (now()-WaveStart<=7260)
if (now()-WaveStart<=8400)
anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
anti_speed=0;
if (PulseSync)
return speed;
return anti_speed;
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
static byte speed=0;
static byte anti_speed=0;
if (WavePhase==0)
WavePhase++;
WaveStart=now();
if (now()-WaveStart>900) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
speed+=WaveMaxSpeed/2;
anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
anti_speed+=WaveMaxSpeed/2;
if (now()-WaveStart>1800) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
speed+=WaveMaxSpeed/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
anti_speed+=WaveMaxSpeed/4;
if (now()-WaveStart>2700) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
if (now()-WaveStart>3600) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
speed+=(WaveMaxSpeed*3)/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
anti_speed+=(WaveMaxSpeed*3)/20;
else if (WavePhase==5)
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
else if (WavePhase==6)
if (now()-WaveStart>5400) WavePhase++;
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
speed+=(WaveMaxSpeed*5)/20;
anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
anti_speed+=WaveMaxSpeed/20;
else if (WavePhase==7)
if (now()-WaveStart>6300) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
else if (WavePhase==8)
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
speed+=(WaveMaxSpeed*7)/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
else if (WavePhase==9)
if (now()-WaveStart>8100) WavePhase++;
speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
else if (WavePhase==10)
speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
anti_speed=speed;
if (PulseSync)
return speed;
return anti_speed;
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
// Contribution of lnevo
double moonOffset; // gap between high and low
double amplitude; // tide curve
double wavelength=12*SECS_PER_HOUR;
// Calculate the gap between high and low tide based on MoonPhase()
moonOffset=cos(((2*PI)/100)*MoonPhase());
moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
// Find out the current tidal height
amplitude=sin(((2*PI)/wavelength)*now());
moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
amplitude=amplitude*moonOffset;
// Adjust the calculate speed to be in our adjusted range
return constrain(WaveSpeed+amplitude,0,100);
Enjoy
