Hi,
I would like to use the wizard on my netbook but cant cause the wizard window is missing the bottom. This issue happens on netbooks with resolution 1024x600 trying to run applications not compatible with the resolution.
I cannot change the resolution on the netbook and I do not have another laptop to use. Does anyone know a workaround to this problem that would let me view the wizard properly?
Wizard bottom missing on netbook ((workaround))
ahmedess
ahmedess
Re: Wizard bottom missing on netbook ((workaround))
found a solution in this link if anyone comes across this issue and needs a temporary fix you can change the resolution to 1024x768 run the wizard and when you re done you can change the res. back to your original
http://mobileoffice.about.com/od/netboo ... lution.htm
