Help with Custom Menus
Posted: Fri Oct 18, 2013 8:19 pm
by Bruz4023
So I am having successes with the custom menus but what i want is an option to turn my lights on at anytime to full brightness. it says that the class PWMSetPercent doesnt exist but you had said in the manual that it does. what am I missing
#include <RT_PWM.h>
#include <avr/pgmspace.h>
byte RoyalBluePWMValue=0;
byte WhitePWMValue=0;
byte BluePWMValue=0;
byte PinkPWMValue=0;
  prog_char menu0_label[] PROGMEM = "Feeding";
  prog_char menu2_label[] PROGMEM = "ATO Clear";
  prog_char menu3_label[] PROGMEM = "Overheat Clear";
  prog_char menu4_label[] PROGMEM = "PH Calibration";
  prog_char menu5_label[] PROGMEM = "Date / Time";
  prog_char menu6_label[] PROGMEM = "Version";
  prog_char menu7_label[] PROGMEM = "Lighting";
  menu0_label, menu1_label, menu2_label,
  menu3_label, menu4_label, menu5_label,
  menu6_label,menu7_label//, menu7_label, menu8_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.PWMSetPercent(byte p);
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.StandardATO( Port1,1800 );
    ReefAngel.StandardLights( Port3,7,0,22,0 );
    ReefAngel.StandardLights( Port4,11,0,23,0 );
    ReefAngel.StandardHeater( Port7,780,790 );
    RoyalBluePWMValue= PWMSlope(7,0,23,0,0,100,90,RoyalBluePWMValue) ;
    WhitePWMValue=PWMParabola(10,0,22,0,0,100,WhitePWMValue) ;
    BluePWMValue=PWMParabola(8,30,20,0,0,100,BluePWMValue) ;
    PinkPWMValue=PWMSlope(7,30,22,30,0,100,90,PinkPWMValue) ;
    CheckCloud();
    ReefAngel.PWM.SetChannel( 0, RoyalBluePWMValue);
    ReefAngel.PWM.SetChannel( 1, WhitePWMValue );
    ReefAngel.PWM.SetChannel( 2, BluePWMValue );
    ReefAngel.PWM.SetChannel( 3, PinkPWMValue  );
    ReefAngel.Portal( "Bruz4023" );
Re: Custom Menus
Posted: Sat Oct 19, 2013 8:18 am
Is it for the standard dimming channels or expansion module?
Re: Custom Menus
Posted: Sat Oct 19, 2013 9:57 am
by Bruz4023
Expansion Module i am using channels 0-3
Re: Custom Menus
Posted: Sat Oct 19, 2013 5:04 pm
Try this:
void MenuEntry8()
  if (ReefAngel.PWM.GetChannelOverrideValue(0)<=100)
    ReefAngel.PWM.SetChannelOverride(0,255);
    ReefAngel.PWM.SetChannelOverride(1,255);
    ReefAngel.PWM.SetChannelOverride(2,255);
    ReefAngel.PWM.SetChannelOverride(0,100);
    ReefAngel.PWM.SetChannelOverride(1,100);
    ReefAngel.PWM.SetChannelOverride(2,100);
Re: Custom Menus
Posted: Sun Oct 20, 2013 3:54 pm
by Bruz4023
rimai wrote:Try this:
void MenuEntry8()
So That logically makes sense to me but i got an error
" Clouds2:91: error: 'class RA_PWMClass' has no member named 'GetChannelOverrideValue' "
Thats the same problem I was having
Another question in the code you gave I understand the 0, 1, 2 those correspond to the channels but what is the 255? and why cant you just force it to go full brightness why do you need the if and else statements?
Re: Custom Menus
Posted: Sun Oct 20, 2013 4:03 pm
If the lights are overriden, put them back to normal otherwise override them.
255 is the default (non overriden value)
Sounds like you have older libraries. Try installing the latest versionx
Re: Custom Menus
Posted: Sun Oct 20, 2013 4:58 pm
Yeah, if you override them to 100%, you would need a way to put them back to normal mode, right?
That's why I made the if...else statement or you would be forever in 100% :cry:
Re: Custom Menus
Posted: Sun Oct 20, 2013 6:57 pm
by Bruz4023
That makes perfect sense! so I just uninstalled and re installed the reef controller program. no luck it is giving me the same issue.
What are the eagle files? i haven't figured out what they are or where they go? I am kinda assuming that missing them is my problem.
Re: Custom Menus
Posted: Mon Oct 21, 2013 9:01 am
What do you get when you do to Tools->Reef Angel Libraries Version?
Eagle files are the files to create the PCB. You don't need them.
http://www.cadsoftusa.com/
Re: Custom Menus
Posted: Mon Oct 21, 2013 9:05 am
by Bruz4023
O ok that looks cool I will check tonight when I get home What version should I have?
I did delete all files and re install the RA arduino program, so i should have the most up to date!
Re: Custom Menus
by Bruz4023
Re: Custom Menus
Posted: Mon Oct 21, 2013 2:26 pm
by Bruz4023
ok I just checked and it says 1.0.9 that is the older version right? what steps do i need to take to ensure it is installed with up to date libraries?
Re: Custom Menus
Posted: Mon Oct 21, 2013 2:42 pm
Yes, 1.0.9 is the latest.
I could swear those functions were introduced on 1.0.8, but now you made me doubt it.
Let me double check
Re: Custom Menus
Posted: Mon Oct 21, 2013 2:49 pm
Oh, sorry...
That one function is queued for next release :(
Try this then:
void MenuEntry8()
  if (ReefAngel.PWM.ExpansionChannelOverride[0]<=100)
Re: Custom Menus
Posted: Mon Oct 21, 2013 7:17 pm
by Bruz4023
so it accepted that code but it didnt do anything when I selected it? should there be a delay or something?
Re: Help with Custom Menus
Posted: Mon Oct 21, 2013 8:29 pm
I just tested it and it is working just fine here.
