RA Wizard - No Night Mode?
Would you like to help?
PostPosted: Sat Jan 11, 2014 6:38 am
Newbie here.
While setting up the Reef Angel Wizard, I realized there are no settings for the night mode and that means the wave makers will be running at full speed at night.
Am I missing something?
PostPosted: Sat Jan 11, 2014 7:20 am
The Wizard is just a way to get you started with the basic functions. You can create custom coding if you want to run a different pattern at night.
PostPosted: Sat Jan 11, 2014 8:32 am
Is there a "newbie-friendly" way to make that adjustment.
I don't know much about coding at this point.
PostPosted: Sat Jan 11, 2014 8:41 am
Can you copy and paste the code you are using. The code the Wizard generates for you at the end.
paste it inbetween [ code] paste it here [ /code] without the spaces in the brackets.
PostPosted: Sat Jan 11, 2014 9:15 am
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.DelayedOn( Port2,15 );
    ReefAngel.Wavemaker( Port5,120 );
    ReefAngel.DCPump.SetMode( LongPulse,100,60 );
    ReefAngel.Portal( "AnesthDoc" );
PostPosted: Sat Jan 11, 2014 9:18 am
Are you trying to keep the longpulse mode at a lower speed or change to a constant low speed at night?
PostPosted: Sat Jan 11, 2014 9:38 am
Lets say you want to set Longpulse during the day and constant mode at night
In your void loop()
remove this line
then in the void loop() custom code area put this
  if (hour()>=22 || hour()<11) { // if hour is >=10pm or hour is <11am
    ReefAngel.DCPump.SetMode( Constant,30,10 ); // Set dc pump mode to Constant at 30% power
  else if (hour()>=11 && hour()<22) { // if hour is >=11am and <10pm
  ReefAngel.DCPump.SetMode( LongPulse,100,60 ); // Set dc pump mode to LongPulse at 100% power, 60 second duration
So this would be your new code
PostPosted: Sat Jan 11, 2014 10:49 am
Awesome and thanks for making it look so easy.
Do I remove the original code or just copy and paste the new code?
PostPosted: Sat Jan 11, 2014 10:56 am
I gave you the option to edit your code or just replace it all together :)
PostPosted: Sat Jan 11, 2014 11:01 am
What would be a good place for someone like me to learn how to code.
Thanks again for all your help and time.
Next
Return to Tutorials
