Re: Analog relay box
Posted: Wed Mar 05, 2014 2:58 pm
by deputy1234
lnevo wrote:So the VR-SW should get shorted out (ie connected to each other...) It should not go to any 12V connection. This will make sure the UNIT stays ON all the time.
From reading what is on the board, +12V is also VR-SW1 . Its labled +12V-D/ VR-SW from what I can see.
Posted: Wed Mar 05, 2014 4:38 pm
Pictures tell a thousand words...the one you referenced did not show anything involving 12V
Posted: Wed Mar 05, 2014 7:50 pm
by howaboutme
I'm a member of WAMAS and know the person that tried this. I'm not an expert on this at all but I think some confusion could be because Evergrow changed their dimmer boards from the one that was posted earlier. If you're trying to replicate step by step with what was posted, see this post:
http://wamas.org/forums/topic/63974-has ... ontroller/
Starting on post #6.
Not sure if this helps but thought I would post just in case.
