Documentation
Would you like to help?
Re: Documentation
Correct. For ShortPulse mode, the minimum speed is always 0, defined inside the libraries.
The user should not need to worry about the minimum speed and simply use the settings according to what you placed in the comment above. So 50 would be the pump speed in % and 10 would be duration in milliseconds.
The wizard is capable of creating constant and lagoon. You may need to scroll up the pop-up options selection.
Storm is a mode I invented but it is not much used by anyone and Custom mode is for advanced users that want to have extreme control over the pumps.
The code for each of them is exactly the same for all modes. The only thing that changes is the mode.
This is the list of modes (case sensitive):
Constant
Lagoon
ReefCrest
ShortPulse
LongPulse
NutrientTransport
TidalSwell
Storm
Else
Sine
Gyre
So, you would change this:
ReefAngel.DCPump.SetMode( ShortPulse,50,10 );
To this:
ReefAngel.DCPump.SetMode( Constant,50,0 );
The above code would put the pumps in Constant mode at 50%. Duration is not used in Constant mode.
Naptalene
Re: Documentation
Post by Naptalene »
Ok cool, figured that but just wanted to make sure.
Naptalene
Re: Documentation
Post by Naptalene »
Hi, another clarifier please,
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,15,100,60,15) ); //
Could you please give me the descriptions of the numbers, in order for both the shapes.
There are too many "0"s from what comes out of the wizard :P
Can you ommit those values happily?
Re: Documentation
Start hour, start minute, end hour, end minute, start percentage, end percentage, time of slope, default value.
So, 9,00 is 9 AM, 20,0 is 8 PM. 9,30 would be 9:30 AM. 21,45 would be 9:45 PM. You can't leave them out.
Naptalene
Re: Documentation
Post by Naptalene »
Oh goodness, so the first 2 numbers there are hour/minutes...... that's embarrasing/funny.
I thought they were 2 seperate fields completely.
Thanks.
Re: Documentation
Where are we updating this? I don't see anything new on the github wiki... Roberto, didn't we setup a different wiki on the forum at one point too?
Re: Documentation
lnevo wrote:Where are we updating this? I don't see anything new on the github wiki... Roberto, didn't we setup a different wiki on the forum at one point too?
yeah i thought we had a separate wiki as well. i do not recall the location of it though.
Naptalene
Re: Documentation
Post by Naptalene »
To be honest I was too embarrassed to load stuff onto any of the official sites.
I just started a spreadsheet with every unit.
Now I'm using the Wizard to push out stock code for different things.
I got a lot of that sorted and started a wiki today just linking a whole load of stuff. I'm learning how to do that on the fly...
I just didn't want to
a) overwrite anything by mistake
B) let anything I'm doing be seen as "official"
I wanted to get it done and then let you guys decide what you think.
Then if you OK'd it figured we could move it accross.
http://reefangelcontrollerdocuments.wikia.com
Hope this place is okay for now and lots still to do.
I would need you guys to make sure my explanations are all correct etc.
And then I thought we could make a page with the breakdowns where I take the library info and put it in there?
I'd copy/paste as its way out of my depth?
Anyway, I've learnt tons already. Let me know if I must keep going?
I would just like it to be "unofficial" and away from the world ( he says as he starts a freaking wiki)before you guys are happy.
Cheers
Andrew
Re: Documentation
You can use the wiki above too. We have nothing in that wiki so far :(
Re: Documentation
I don't think I have access to edit on the RA wiki.
Re: Documentation
Which one lol
Re: Documentation
Re: Documentation
Are you able to login using the same user/pass of the forum?
Re: Documentation
I don't see a place to login.
Re: Documentation
Top right corner
Naptalene
Re: Documentation
Post by Naptalene »
Lol
I'll shunt it all over to there if it's empty.
You guys okay with the way I'm doing iron the link one?
Re: Documentation
I like it :)
Naptalene
Re: Documentation
Post by Naptalene »
Continuing with the "Village idiot" theme.......
The RA wiki doesnt have a WYSIWIG interface. It's going to take me ages to get into doing it that way.
I can obviously figure out how to do the headings etc, but links and all that fun stuff will be a bit of a pain. I'm doing this in-between sessions at our studios so I cant really learn it.
I'll carry on in this one
http://reefangelcontrollerdocuments.wik ... ments_Wiki
and get the actual info down and then we can get it over onto the RA site.
Current workflow is...... non-existant and I'm flying all over the place :)
Naptalene
Re: Documentation
Post by Naptalene »
Hi, please can you guys help with this:
IOExpander:
How do you call it? I got this by looking at the Library (be very afraid)
ReefAngel.IOPorts(0); // where IOPorts is the IOExpansion, 0 is the first Port
As an example, could you give me the following(I know its very basic):
Float switch on IOExpansion Channel 0
When it triggers Relay box port 1 turns off.
PowerControlExpander:
How do you call it?
As an example, could you give me the following(very basic again)
Floatswitch on ATO low.
When it triggers turn Power control port1 on.
I couldn't find that info easily.
Thanks in Advance
Naptalene
Re: Documentation
Post by Naptalene »
And another,
Rope leak detector:
ReefAngel.LeakShutoffPorts = 0; // Turn off port if leaks are detected
I assume thats for the standard relay box.
If we use an expansion relay?
ReefAngel.LeakShutoffPorts = Box1_Port1;//
and on both?
ReefAngel.LeakShutoffPorts = 0,Box1_Port1;//
Re: Documentation
Roberto, I found the login button. Thanks. :D
How does one create a new page?
Re: Documentation
cosmith71 wrote:Roberto, I found the login button. Thanks. :D
you need to edit a page and create a link to the new page. then it will allow you to create the new page.
Re: Documentation
I/O Expansion Module
It has 6 channels. Channel 0 through 5
We can check for status of each channel by using ReefAngel.IO.GetChannel( channel ), where channel is a value from 0 to 5.
Example
Let's check if the float switch connected to channel 3 of I/O Expansion module is floating and if it is, turn on port 1 of the relay box:
if (ReefAngel.IO.GetChannel(3))
  ReefAngel.Relay.On( Port1);
  ReefAngel.Relay.Off( Port1);
Power Control Expansion Module
It has 8 ports. It works just like a relay expansion module. The ports are referenced the same way.
Relay and Power Control Expansion modules can be mix/matched and up to 8 can be connected to the system.
Each one needs its own ID, which can be set by changing the dip switch inside the module. The IDs can be set from 1 to 8.
Each port can be referenced using this ID. So, for example you want to reference port 3 of the box ID 1, you would use Box1_Port3.
To turn on/off a port, you can use ReefAngel.Relay.On( port ) and ReefAngel.Relay.Off( port ), where port is the name of the port depending on the ID you have set explained above.
Example
Let's check if the float switch connected to ATO Low port is floating (not active) and if it is, turn on port 3 of the Power Control Expansion module set to ID 1
if (!ReefAngel.LowATO.IsActive())
  ReefAngel.Relay.On( Box1_Port3);
  ReefAngel.Relay.Off( Box1_Port3);
Re: Documentation
You can set each port, on the main relay box or on any expansion module to be turn on/off depending on which mode or special conditions.
We have 2 modes: feeding and water change and 3 special modes: lights on, overheat and leak detection.
Example
Let's turn port 1 and port 7 of the main relay box on feeding mode:
    ReefAngel.FeedingModePorts = Port1Bit | Port7Bit;
Let's turn port 2 of the main relay box and port 5 of relay expansion box ID 1 on feeding mode:
Note: The ID is actually decremented by 1 when you reference them in this code.
    ReefAngel.FeedingModePorts = Port2Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit;
Other modes and special conditions you can set:
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPortsE[0] = 0;
jegillis
Re: Documentation
Post by jegillis »
You can also set a delay on ports turning on after feeding or water change
ReefAngel.Relay.DelayedOn(Port7,1);
This is placed in the loop. (port,timeinminutes)
I use it to delay starting my in sump skimmer
Naptalene
Re: Documentation
Post by Naptalene »
Thanks gents.
A big penny dropped with the power expander being addressed the same as a relay box.
I'll double check the layout wrt the modes, and I prefer having it all in your guys words.
WRT the delayed ports etc.
I was thinking of setting up a Wizard page.
In that page have list of those port modes etc. That you can choose for the relay boxes.
Naptalene
Re: Documentation
Post by Naptalene »
Work is getting the better of me. I'll get back onto it ASAP
Naptalene
Re: Documentation
Post by Naptalene »
Hello,
I got time again today. It's starting to flesh out but I think it still makes for easy navigation.
I havent added the last bit of code you supplied to me but hopefully I'll get that in tomorrow.
Cheers
Re: Documentation
Andrew, it would be great if there were a link of To Do items in the wiki. Could you create a list of topics that still need to be covered so someone who wants to contribute like myself can see where their efforts are best spent :)
