Documentation
Would you like to help?
PostPosted: Fri Feb 20, 2015 5:54 am
And another,
Rope leak detector:
ReefAngel.LeakShutoffPorts = 0; // Turn off port if leaks are detected
I assume thats for the standard relay box.
If we use an expansion relay?
ReefAngel.LeakShutoffPorts = Box1_Port1;//
and on both?
ReefAngel.LeakShutoffPorts = 0,Box1_Port1;//
PostPosted: Fri Feb 20, 2015 7:03 am
Roberto, I found the login button. Thanks. :D
How does one create a new page?
PostPosted: Fri Feb 20, 2015 7:47 am
cosmith71 wrote:Roberto, I found the login button. Thanks. :D
you need to edit a page and create a link to the new page. then it will allow you to create the new page.
PostPosted: Fri Feb 20, 2015 9:33 am
I/O Expansion Module
It has 6 channels. Channel 0 through 5
We can check for status of each channel by using ReefAngel.IO.GetChannel( channel ), where channel is a value from 0 to 5.
Example
Let's check if the float switch connected to channel 3 of I/O Expansion module is floating and if it is, turn on port 1 of the relay box:
if (ReefAngel.IO.GetChannel(3))
  ReefAngel.Relay.On( Port1);
  ReefAngel.Relay.Off( Port1);
Power Control Expansion Module
It has 8 ports. It works just like a relay expansion module. The ports are referenced the same way.
Relay and Power Control Expansion modules can be mix/matched and up to 8 can be connected to the system.
Each one needs its own ID, which can be set by changing the dip switch inside the module. The IDs can be set from 1 to 8.
Each port can be referenced using this ID. So, for example you want to reference port 3 of the box ID 1, you would use Box1_Port3.
To turn on/off a port, you can use ReefAngel.Relay.On( port ) and ReefAngel.Relay.Off( port ), where port is the name of the port depending on the ID you have set explained above.
Example
Let's check if the float switch connected to ATO Low port is floating (not active) and if it is, turn on port 3 of the Power Control Expansion module set to ID 1
if (!ReefAngel.LowATO.IsActive())
  ReefAngel.Relay.On( Box1_Port3);
  ReefAngel.Relay.Off( Box1_Port3);
PostPosted: Fri Feb 20, 2015 9:45 am
You can set each port, on the main relay box or on any expansion module to be turn on/off depending on which mode or special conditions.
We have 2 modes: feeding and water change and 3 special modes: lights on, overheat and leak detection.
Example
Let's turn port 1 and port 7 of the main relay box on feeding mode:
    ReefAngel.FeedingModePorts = Port1Bit | Port7Bit;
Let's turn port 2 of the main relay box and port 5 of relay expansion box ID 1 on feeding mode:
Note: The ID is actually decremented by 1 when you reference them in this code.
    ReefAngel.FeedingModePorts = Port2Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit;
Other modes and special conditions you can set:
    // Ports turned off when Leak is detected
    ReefAngel.LeakShutoffPortsE[0] = 0;
PostPosted: Fri Feb 20, 2015 2:13 pm
You can also set a delay on ports turning on after feeding or water change
ReefAngel.Relay.DelayedOn(Port7,1);
This is placed in the loop. (port,timeinminutes)
I use it to delay starting my in sump skimmer
PostPosted: Sun Feb 22, 2015 1:34 pm
Thanks gents.
A big penny dropped with the power expander being addressed the same as a relay box.
I'll double check the layout wrt the modes, and I prefer having it all in your guys words.
WRT the delayed ports etc.
I was thinking of setting up a Wizard page.
In that page have list of those port modes etc. That you can choose for the relay boxes.
PostPosted: Sun Mar 01, 2015 3:03 am
Work is getting the better of me. I'll get back onto it ASAP
PostPosted: Wed Mar 11, 2015 7:35 am
Hello,
I got time again today. It's starting to flesh out but I think it still makes for easy navigation.
http://reefangelcontrollerdocuments.wik ... ments_Wiki
I havent added the last bit of code you supplied to me but hopefully I'll get that in tomorrow.
Cheers
PostPosted: Wed Mar 11, 2015 12:33 pm
Andrew, it would be great if there were a link of To Do items in the wiki. Could you create a list of topics that still need to be covered so someone who wants to contribute like myself can see where their efforts are best spent :)
Return to Tutorials
