Setting Reminders
Would you like to help?
PostPosted: Mon Aug 03, 2015 11:19 am
GreenVF wrote:Hi Inevo
Thanks for your response.
I think my problem is where in my code to add "checkReminders(); in my main loop and also were to add the function.
My code is all from the wizard. except where I tried to add the reminders. I'm a total noob when it comes down to coding. I do have the wifi module , and reef angel plus.
and then the errors
sketch_aug03a.cpp: In function 'void loop()':
sketch_aug03a:86: error: 'checkReminders' was not declared in this scope
sketch_aug03a:91: error: a function-definition is not allowed here before '{' token
sketch_aug03a:101: error: a function-definition is not allowed here before '{' token
sketch_aug03a:145: error: expected `}' at end of input
Your code cuts off the closing of the file. You placed all of the code inside the loop when only checkReminders(); needed to be in there. Here's what it should look like:
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.DelayedOn( Port1 );
    ReefAngel.StandardHeater( Port4 );
    ReefAngel.ActinicLights( Port5 );
    ReefAngel.DayLights( Port6 );
    ReefAngel.MoonLights( Port7 );
    ReefAngel.DCPump.DaylightChannel = AntiSync;
    checkReminders();  // functions are defined below
    ReefAngel.Portal( "GreenVF" );
// Reminder Code is listed below
void checkReminders()
   // grab the current time and use it for processing the reminders
   // do it this way to prevent rollover errors...just in case
   time_t t = now();
   remindTraceElements(t);
   remindWaterChange(t);
   remindMonthly(t);
void remindTraceElements(time_t t)
   // Sunday = 1, Monday = 2, etc
   if ((weekday(t) == 2) || (weekday(t) == 5)) {
      // Every monday and thursday at 10pm
      if ((hour(t) == 22) && (minute(t) == 0) && (second(t) == 0)) {
         // send reminder, No Spaces Allowed in message
         sendReminder("Add+Trace+Elements");
void remindWaterChange(time_t t)
   if (weekday() == 4) {
      // Every wednesday at 8pm
      if ((hour(t) == 20) && (minute(t) == 0) && (second(t) == 0)) {
         sendReminder("Water+Change+Time");
void remindMonthly(time_t t)
   // Every 1st of the month at 8pm
   if (day(t) == 1) {
         sendReminder("Change+filter+pads");
void sendReminder(char* msg)
   static WifiAlert r;
        // No delay, for immediate sending
   r.SetDelay(0);
   // No spaces are allowed in the msg
   r.Send(msg);
I moved things around for you and it should be just fine.
PostPosted: Tue Aug 04, 2015 4:16 am
Thank you Binder
Much appreciated. Got it now compiling. I also found a I had a few errors that I managed to sort out.
note to self. case sensitive and I had to include WifiAlert.h file
Here is the completed working code for now.
newsetup.ino
(3.94 KiB) Downloaded 194 times
PostPosted: Tue Aug 04, 2015 10:56 am
awesome. glad you got it compiling.
yeah, things are case sensitive.
Previous
Return to Tutorials
