Setting Reminders
Would you like to help?
PostPosted: Fri Jul 24, 2015 8:15 pm
Plus you haven't used wifialert much so it's all good. I figured the chances were low but just wanted to point out the possibility
PostPosted: Fri Jul 24, 2015 8:25 pm
lnevo wrote:Plus you haven't used wifialert much so it's all good. I figured the chances were low but just wanted to point out the possibility
Yeah, I wasn't sure about how it works exactly. I didn't realize those possibilities. Thanks again for feedback.
Sent from my Moto X
PostPosted: Fri Jul 24, 2015 8:39 pm
Thank you both for this!
Just so I'm clear, these alerts are going to alert me through the app? Right? Is there a way to do text messages?
PostPosted: Sat Jul 25, 2015 7:18 am
fishflipper wrote:Thank you both for this!
no. they will be sent through the portal not the app. you will also need the portal(...) line added to your code. then from the portal, you will enter your email address and you can get email messages with these alerts (some carriers have a special email address that sends you a txt message to your phone).
there is really not a way to do this from the phone except for adding in manual alarms...so that defeats the point of the controller sending the reminders.
PostPosted: Sat Jul 25, 2015 7:43 am
Here are the formats for most of the US services. 《number》is your 10 digit phone number.
AT&T: number@txt.att.net
T-Mobile: number@tmomail.net
Verizon: number@vtext.com
Sprint: number@messaging.sprintpcs.com or number@pm.sprint.com
Virgin Mobile: number@vmobl.com
Tracfone: number@mmst5.tracfone.com
Metro PCS: number@mymetropcs.com
Boost Mobile: number@myboostmobile.com
Cricket: number@sms.mycricket.com
Nextel: number@messaging.nextel.com
Alltel: number@message.alltel.com
Ptel: number@ptel.com
Suncom: number@tms.suncom.com
Qwest: number@qwestmp.com
U.S. Cellular: number@email.uscc.net
PostPosted: Sat Jul 25, 2015 8:54 am
Thanks, I would rather have text messages. I didn't think there was a way to do it.
PostPosted: Sat Jul 25, 2015 6:01 pm
awesome. great list. I knew they existed but didn't know them.
Sent from my Moto X
PostPosted: Sun Aug 02, 2015 5:28 am
Hi there
Has anyone got this code up and running, working?. I'm having troubles in trying to get the code to compile.
PostPosted: Sun Aug 02, 2015 6:10 am
Whats your error
PostPosted: Mon Aug 03, 2015 5:27 am
Hi Inevo
Thanks for your response.
I think my problem is where in my code to add "checkReminders(); in my main loop and also were to add the function.
My code is all from the wizard. except where I tried to add the reminders. I'm a total noob when it comes down to coding. I do have the wifi module , and reef angel plus.
    ReefAngel.SetTemperatureUnit( Celsius );  // set to Celsius Temperature
    ReefAngel.FeedingModePorts = Port2Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.DelayedOn( Port1 );
    ReefAngel.Relay.DelayedOn( Port2 );
    ReefAngel.StandardHeater( Port4 );
    ReefAngel.ActinicLights( Port5 );
    ReefAngel.DayLights( Port6 );
    ReefAngel.MoonLights( Port7 );
    checkReminders();
void checkReminders()
   // grab the current time and use it for processing the reminders
   // do it this way to prevent rollover errors...just in case
   time_t t = now();
   remindTraceElements(t);
   remindWaterChange(t);
   remindMonthly(t);
void remindTraceElements(time_t t)
   // Sunday = 1, Monday = 2, etc
   if ((weekday(t) == 2) || (weekday(t) == 5)) {
      // Every monday and thursday at 10pm
      if ((hour(t) == 22) && (minute(t) == 0) && (second(t) == 0)) {
         // send reminder, No Spaces Allowed in message
         sendReminder("Add+Trace+Elements");
void remindWaterChange(time_t t)
   if (weekday() == 4) {
      // Every wednesday at 8pm
      if ((hour(t) == 20) && (minute(t) == 0) && (second(t) == 0)) {
         sendReminder("Water+Change+Time");
void remindMonthly(time_t t)
   // Every 1st of the month at 8pm
   if (day(t) == 1) {
         sendReminder("Change+filter+pads");
void sendReminder(char* msg)
   static WifiAlert r;
        // No delay, for immediate sending
   r.SetDelay(0);
   // No spaces are allowed in the msg
   r.Send(msg);
    ReefAngel.Portal( "GreenVF" );
and then the errors
sketch_aug03a.cpp: In function 'void loop()':
sketch_aug03a:86: error: 'checkReminders' was not declared in this scope
sketch_aug03a:91: error: a function-definition is not allowed here before '{' token
sketch_aug03a:101: error: a function-definition is not allowed here before '{' token
sketch_aug03a:145: error: expected `}' at end of input
newsetup.ino
not working code file
(3.84 KiB) Downloaded 73 times
Return to Tutorials
