Static IP on the WiFi Attachment
Posted: Mon May 25, 2015 1:41 pm
by alekos
Please set up your WiFi using the Official WiFi attachment Manual from ReefAngel to ensure that everything is working properly
You need to use terminal(Teraterm) for this instructions to work
If you feel uncomfortable with the instructions I will recommend you to STOP and don't do it.
1. Entering Command mode
Type: $$$ <Enter>
2. setting the Static IP
Type: set ip dhcp 0 <Enter>
The device will respond with AOK.
3. setting the IP address
Type: set ip address <ip Address> <Enter>
(example: set ip address 192.168.1.15)
4. setting the gateway:
Type: set ip gateway <gateway> <Enter>
(example: set ip gateway 192.168.1.1)
5. setting the netmask
Type: set ip netmask <netmask> <Enter>
(example: set ip netmask 255.255.255.0)
6. set protocol:
Type: set ip protocol 2 <Enter>
7. set authentication: option 4 is WAP2-PSK refer to the manual for your authentication type
Type: set w a 4 <Enter>
8. setting the SSID
Type: set w s <string> <Enter>
9. Setting username:
Type: set w s <username> <Enter>
10. setting password
Type: set w p <Password> <Enter>
11. setting the port
Type: set i l 2000 <Enter>
12. Type: save <Enter>
13. Type: reboot <Enter>
The device will respond with *reboot*.
the following commands are to retrieve all the settings saved.
1. Type: get ip <Enter>
2. Type: get w <Enter>
3. Type: get u <Enter>
to go back to Factory settings:
Type: factory RESET
The device will respond with: Set Factory Defaults
Type: reboot
Enjoy!
Re: Static IP on the WiFi Attachment
Posted: Sat Aug 13, 2016 8:11 pm
by jgwinner
I didn't bother with the above commands, but still have a static IP
What I did was go into the setup pages on my router, wait till the ReefAngel connected, then added an IP reservation for that MAC address.
Every router is different so I can't really give tutorial steps, but if you don't know what I meant, typing the above commands may be easier ... however, pick a really high IP address, or your router might give out your static IP to someone else.
No idea what "PasteAS" means in this context. I think we'd all need more info to help.
== John ==
Posted: Sun Aug 14, 2016 5:30 am
by cosmith71
I think Ronalddam is a bot.
