Hi,
I just wanted some advise on how people have setup a skimmer container with a float switch so if it triggers i can turn port 2 off until the switch is off again? any suggestions please?
To explain further i have a 10 litre container that the skimmer dumps into and i just want it to switch the skimmer off if the float is reached. Yes i have have it over flow because the skimmer just decides to go insane and i run a fairly wet skim.
Tony
Advice needed to stop a skimmer in the event of overflow
Topcat
Ademster
Re: Advice needed to stop a skimmer in the event of overflow
this is how I had mine set up.
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.On(Port2);
}Adam
58 Gal
58 Gal
Topcat
This worked a treat thank you, but if I still wanted the port controlled via a timer as in off between 22 and 8. With this programming it is not switching off.
Any ideas?
Any ideas?
Try this:
if ((hour()<8) || (hour()>=22))
