coding vortech pumps with rf module
briank6050
hi, im new to both the ra and writing codes. got most of the probs figured out using the wizard but dont know how to make my mp40 pump go into night mode. any help would be much appreciated. thanks
Re: coding vortech pumps with rf module
// Turn off Night Mode
if (hour()>8 && ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Night_Stop,0,0);
// Turn on Night Mode
if (hour()>20 && ReefAngel.RF.Mode!=Night) ReefAngel.RF.SetMode(Night,20,0);
briank6050
where exactly do i put this info into the sketch?
In the custom code section inside the loop() function.
briank6050
i dont even see the night mode anywhere in the code. im so confused
I posted it above...not sure what the question is. If you post your full code, i can show you where it goes..
