WifiTest Code skecth too big
PostPosted: Fri Aug 04, 2017 7:40 am
Finally managed to get a wifi adaptor for my RA.
When I try upload first wifitest code it says sketch too big ?
PostPosted: Fri Aug 04, 2017 8:36 am
I can run the wizard , no problems, when I add wifi attachment, I add my user name to field, and home to DNS server, but when wizard tries to update, I get an error.
Please help
PostPosted: Sat Aug 05, 2017 3:20 am
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Removing connection to COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
* Please, enter a SSID
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 78524 3 WiFly_GSX-2.32
< 22 44704 3 wps_app
< 33 1052 10 config
< 34 78524 3 WiFly_GSX-2.32
< 54 49072 3 wps_app
< 67 1052 10 user
< 68 88548 3 wifly-GSX-441-r1057
< 165 Free, Boot=68, Backup=34
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s STUDY2
< set w s STUDY2
< AOK
< <4.41>
> set w p qwertyuiop
< set w p qwertyuiop
< AOK
< <4.41>
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=STUDY2
< Chan=3
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=32396
< Boot=2069
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=192.168.1.40:2000
< NM=255.255.255.0
< GW=192.168.1.1
< HOST=104.36.18.155:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router DSL-2750U
Port 2000 is now being forwarded to 192.168.1.40
PostPosted: Sat Aug 05, 2017 3:22 am
So I think that means everything is OK with wifi unit ?
Blue light not flashing.
What is my ip address that I need to put into the Uapp setting please ?
PostPosted: Sat Aug 05, 2017 3:25 am
And I cannot access it via ip address in Explorer
PostPosted: Sat Aug 05, 2017 3:29 am
But I can ping it
PostPosted: Sat Aug 05, 2017 3:58 am
And if I try restore original code through Ardiono I get
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 36,354 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.exportApplet(Sketch.java:1797)
at processing.app.Sketch.exportApplet(Sketch.java:1783)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2357)
at java.lang.Thread.run(Thread.java:619)
PostPosted: Sat Aug 05, 2017 8:37 am
The IP address shows at the bottom. 192.168.1.40
The web server is listening to port 2000, so you have to go http//192.168.1.40:2000
But you may have better results using chrome.
The WiFi attachment by itself will not give you anything on the browser though. Your RA is the one that returns data to the browser.
Do you have a standard RA or RA+?
Return to For New Members
