Got my controller,
Re: Got my controller,
Ok. I created a ticket.
https://github.com/reefangel/Libraries/issues/46
- lnevo
- lnevo
Ok, have some bug fixes and some cleanup. My Vortech's were going in and out of night mode all night because of how I was setting the timer. I hope this resolves it. I also implemented the SunLocation class that binder put together from the code I scraped together. Deails on that class are located on this post (with fixes) http://forum.reefangel.com/viewtopic.php?p=14508#p14508
I have one issue still.. I'm trying to add a menu option to toggle the refugium light.. not working as I'd hope. If there is a simple way to do it, I'd be grateful
Thanks and Enjoy
Thanks and Enjoy
#include <SunLocation.h>
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 8
#define NUMBERS_8x16
// Custom Menu Code
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Vortech Mode";
prog_char menu4_label[] PROGMEM = "Refugium Light";
prog_char menu5_label[] PROGMEM = "ATO Clear";
prog_char menu6_label[] PROGMEM = "PH Calibration";
prog_char menu7_label[] PROGMEM = "Date / Time";
prog_char menu8_label[] PROGMEM = "Version";
menu7_label, menu8_label
// Vortech Defaults
byte vtMode=Random2;
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=65;
byte vtNTMDuration=5;
byte vtNightSpeed=10;
byte vtNightDuration=20;
byte vtPrevMode;
byte vtPrevSpeed;
byte vtPrevDuration;
boolean isNight=false;
boolean isFeeding=false;
boolean vtOverride=false;
SunLocation sl;
byte SunriseHour, SunriseMin, SunsetHour, SunsetMin;
//Define Relay Ports
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define UPS 5
#define Heater 6
#define Refugium 7
#define Vortech 8
// Setup on controller startup/reset
// Initialize Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port4Bit | Port7Bit ;
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( Vortech );
ReefAngel.Relay.On( UPS );
// Setup SunLocation class
sl.Init(-18.285833, 147.699722);
sl.SetOffset(-9,472,-9,506);
// Save previous used vortech mode.
vtPrevMode=InternalMemory.RFMode_read();
vtPrevSpeed=InternalMemory.RFSpeed_read();
vtPrevDuration=InternalMemory.RFDuration_read();
ReefAngel.Relay.DelayedOn( Skimmer, 20 );
ReefAngel.StandardHeater( Heater,778,782 );
sl.CheckAndUpdate();
SunriseHour=sl.GetRiseHour(); SunriseMin=sl.GetRiseMinute();
SunsetHour=sl.GetSetHour(); SunsetMin=sl.GetSetMinute();
// Send the SunLocation info to the portal
ReefAngel.CustomVar[0]=SunriseHour; ReefAngel.CustomVar[1]=SunriseMin;
ReefAngel.CustomVar[2]=SunsetHour; ReefAngel.CustomVar[3]=SunsetMin;
// Turn the lights on
ReefAngel.StandardLights( WhiteLEDs,SunriseHour+1,SunriseMin,SunsetHour-3, SunsetMin );
ReefAngel.StandardLights( BlueLEDs,SunriseHour,SunriseMin,SunsetHour,SunsetMin );
// Let's make the time one number so we can figure out it's night or day...
int currTime = hour()*100+minute();
int riseTime=SunriseHour*100+SunriseMin;
int setTime=SunsetHour*100+SunsetMin;
if ( (currTime <= riseTime) || (currTime >= setTime) ) isNight=true; else isNight=false;
if (isNight)
ReefAngel.Relay.On( Refugium );
if (vtOverride==false && isFeeding==false) {
setRFmode(Night,vtNightSpeed,vtNightDuration);
// It's Daytime!
ReefAngel.PWM.SetDaylight( 0 );
ReefAngel.PWM.SetActinic( 0 );
ReefAngel.Relay.Off( Refugium );
if (vtOverride==false && vtMode==Night) {
setRFmode(vtPrevMode,vtPrevSpeed,vtPrevDuration);
if (ReefAngel.DisplayedMenu==FEEDING_MODE) isFeeding=true;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.On( Refugium );
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && isFeeding )
isFeeding=false;
setRFmode(Smart_NTM,vtNTMSpeed,vtNTMDuration);
if (vtOverride && ReefAngel.Timer[1].IsTriggered())
vtOverride=false;
setRFmode(); // Update if set externally
ReefAngel.Portal( "lnevo" );
// Vortech Helper functions
void setRFmode(int mode, int speed, int duration) {
// Check if mode has changed
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
if (mode!=InternalMemory.RFMode_read()) {
InternalMemory.RFMode_write(mode);
// Temp fix for coming out of night mode
if (vtPrevMode==Night) {
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
if ( (isNight && vtMode != Night) || vtMode==Smart_NTM) {
setRFtimer(30);
// Check if speed has changed
if (speed!=vtSpeed) {
vtPrevSpeed=vtSpeed;
vtSpeed=speed;
if (speed!=InternalMemory.RFSpeed_read()) {
InternalMemory.RFSpeed_write(speed);
// Check if duration has changed
if (duration!=vtDuration) {
vtPrevDuration=vtDuration;
vtDuration=duration;
void setRFmode() {
setRFmode(InternalMemory.RFMode_read(), InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
void setRFtimer(int minutes) {
ReefAngel.Timer[1].SetInterval(minutes*60);
ReefAngel.Timer[1].Start();
vtOverride=true;
// Menu Code
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
byte mode, speed,duration;
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
speed=50; duration=0; // Constant
} else if (mode == 1) {
speed=40; duration=0; // Lagoon
} else if (mode == 2) {
speed=45; duration=0; // Reef Crest
} else if (mode == 3) {
speed=50; duration=10; // Short Pulse
} else if (mode == 4) {
speed=50; duration=20; // Long Pulse
} else if (mode == 6) {
speed=45; duration=10; // Smart_TSM
} else if (mode == 5) {
speed=vtNTMSpeed; duration=vtNTMDuration; // Smart_NTM
} else if (mode == 7) {
speed=vtNightSpeed; duration=vtNightDuration; // Night
mode=9;
setRFmode(mode,speed,duration);
void MenuEntry4()
ReefAngel.Relay.Toggle ( Refugium );
void MenuEntry5()
ReefAngel.ATOClear();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
void MenuEntry7()
ReefAngel.SetupDateTime();
void MenuEntry8()
ReefAngel.DisplayVersion();
// Custom Main Screen
char buf[16];
byte x = 5;
byte y = 2;
byte t;
if (isFeeding) { ReefAngel.ClearScreen(DefaultBGColor); return; }
// Main Header
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, y,"Lee's Reef");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, y+9, 128, y+9);
// Param Header
y+=18;
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,x+5,y,"Temp:");
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,x+60, y, "PH:");
// Temp and PH
y+=8;
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+60, y, buf, Num8x16);
/// Display Sunrise / Sunset (to be calculated later...)
y+=20; t=x;
sprintf(buf, "%02d:%02d", SunriseHour, SunriseMin);
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,t,y,"Rise:"); t+=31;
ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,t,y,buf);
sprintf(buf, "%02d:%02d", SunsetHour, SunsetMin); t+=36;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,t,y,"Set:"); t+=25;
// MoonPhase
y+=10;
ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,x+(128-x),y+8);
ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
// MoonLight %
y+=10;
t = intlength(ReefAngel.PWM.GetDaylightValue()) + 1; t *= 5;
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+68, y, 1);
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x+68+t, y, "%");
// Vortech Mode
y+=10; t=x;
ReefAngel.LCD.DrawText(0,255,x,y,"RF:"); t+=20;
ReefAngel.LCD.Clear(DefaultBGColor,t,y,x+(128-x),y+8);
if (vtMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,t,y,"Constant");
else if(vtMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,t,y,"Lagoon");
else if (vtMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,t,y,"Reef Crest");
else if (vtMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,t,y,"Short Pulse");
else if (vtMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,t,y,"Long Pulse");
else if (vtMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,t,y,"Smart NTM");
else if (vtMode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,t,y,"Tidal Swell");
else if (vtMode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,t,y,"Night");
y+=10; t=x;
ReefAngel.LCD.DrawText(0,255,x,y,"RF Speed:"); t+=60;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,t,y,InternalMemory.RFSpeed_read()); t+=15;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,t,y,"/"); t+=10;
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,t,y,InternalMemory.RFDuration_read());
// Relays
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
// Date+Time
Can you help me replicate this issue?lnevo wrote:Also, sometimes when going into feeding mode, the LCD does not clear completely even though i added a flag to return and clearscreen in my CustomMain.
I was unable to do so...
I'd like to fix in the libraries, but I can't get it to do that.
- lnevo
I'll take a few more peaks the next few feedings and see if I'm still experiencing it. If you have any troubleshooting you'd like me to try... You could also run my code (but now you'll need the SunLocation class
) as a test...if I'm just crazy...
- lnevo
Modified my code to use heater temp settings from memory so I can modify without changing code. I also added a function to the SunLocation class so I can have my lighting times controlled by memory. I'll be posting that separately. I also added my float switches and set the Low to turn off my pump / skimmer when the water level in the return chamber gets too low (drain problem, ato problem?). The high I am using to send me an alert if something happens and the sump gets too full (return pump issue, return line obstruction...) Next up waiting for my water level sensor and I'll be able to monitor my ATO reservoir.
Edit: Needed to add a flag instead of just checking the mode, otherwise it would never turn return pumps back on after water change / feeding mode... The flag is used if triggered, mode change, or controller restart and is reset once the HighATO.IsActive function comes up false. This way it's only disabled once and not when we trigger it on purpose.
Here's the code.
Here's the code.
#define CUSTOM_MENU
// Custom Menu Code
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
byte vtPrevDuration=0;
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=55;
boolean activatedHighATO=true;
SunLocation sl;
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define UPS 5
#define Heater 6
#define Refugium 7
#define Vortech 8
// Initialize Menu
sl.Init(-18.285833, 147.699722); // GBR
sl.SetOffset(-9,472,-9,506); // 9 hour difference
ReefAngel.Relay.DelayedOn( Skimmer, 5 );
ReefAngel.StandardHeater( Heater );
// Turn on the lights
ReefAngel.StandardLights( WhiteLEDs );
ReefAngel.ActinicLights( BlueLEDs );
int currTime=NumMins(hour(),minute());
int riseTime=NumMins(sl.GetRiseHour(),sl.GetRiseMinute());
int setTime=NumMins(sl.GetSetHour(),sl.GetSetMinute());
if (isNight)
// Trigger night mode again to extend built-in timer
if ( ((hour() == 6) && (minute() == 00) && (second() == 00) ) ) {
// It's Daytime!
ReefAngel.Timer[1].ForceTrigger();
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) activatedHighATO=true;
isFeeding=false;
else if (vtOverride && ReefAngel.Timer[1].IsTriggered())
vtOverride=false;
if ( ((hour() == 15) && (minute() == 00) && (second() == 00) ) ) {
bitClear(ReefAngel.Relay.RelayMaskOff,Return-1);
bitClear(ReefAngel.Relay.RelayMaskOff,Skimmer-1);
if (!activatedHighATO) {
ReefAngel.CustomVar[0]=2;
ReefAngel.CustomVar[0]=1;
activatedHighATO=false;
// Turn off Skimmer if Return pump is shutoff.
if (bitRead(ReefAngel.Relay.RelayMaskOff,Return-1)==0) {
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
setRFtimer(30);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
byte mode,speed,duration,prev_mode,prev_speed,prev_dur;
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
mode=9;
prev_mode=vtPrevMode; prev_speed=vtPrevSpeed; prev_dur=vtPrevDuration;
if (!isNight) {
vtPrevMode=prev_mode; vtPrevSpeed=prev_speed; vtPrevDuration=prev_dur;
void MenuEntry4()
if (isNight) {
if (bitRead(ReefAngel.Relay.RelayMaskOff,Refugium-1)==1) {
bitClear(ReefAngel.Relay.RelayMaskOff,Refugium-1);
bitSet(ReefAngel.Relay.RelayMaskOff,Refugium-1);
if (bitRead(ReefAngel.Relay.RelayMaskOn,Refugium-1)==1) {
bitClear(ReefAngel.Relay.RelayMaskOn,Refugium-1);
bitSet(ReefAngel.Relay.RelayMaskOn,Refugium-1);
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
void MenuEntry8()
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Param Header
y+=18;
// Temp and PH
y+=8;
y+=20; t=x;
sprintf(buf, "%02d:%02d", sl.GetRiseHour(), sl.GetRiseMinute());
sprintf(buf, "%02d:%02d", sl.GetSetHour(), sl.GetSetMinute()); t+=36;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
// Relays
// Date+Time
- lnevo
Added my relay expansion yesterday. Lot's of new additions to the code. The following features have been added:
Vacation Mode - Use WL sensor and turn the extension cord I have plugged in, into an ATO port
ATO Refill - Use WL sensor to fill my ATO reservoir to 100%
Power Outage detection - Turn off all unnecessary items if we lose power.
Complete Darkness - Added 2 hours without moonlghts to my schedule
Smart_NTM Delay - Added a delay after feeding mode before Smart_NTM is activated
Dosing Pumps - Added these, but I need to get better pumps
Coral Acclimation Schedule - Need to test this, but should be working good.
#define CUSTOM_MENU
// Custom Menu Code
prog_char menu5_label[] PROGMEM = "Clear Overrides";
prog_char menu7_label[] PROGMEM = "WLS Calibration";
prog_char menu8_label[] PROGMEM = "Date / Time";
prog_char menu9_label[] PROGMEM = "Version";
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
byte vtSpeed=45;
byte vtDuration=5;
byte vtNTMSpeed=65;
byte vtNightSpeed=20;
byte vtNightDuration=10;
boolean feedDelay=false;
boolean floatHigh=true;
boolean powerOutage=true;
int riseOffset=472;
int setOffset=506;
byte acclTime=0;
SunLocation sl;
//Define Custom Memory Location
#define Mem_B_RefillATO 100
#define Mem_B_Vacation 101
#define Mem_B_AcclTime 102
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Extension 5
#define Heater 6
#define Refugium 7
#define Reactor 8
#define Unused1 Box1_Port1
#define Unused2 Box1_Port2
#define Vortech1 Box1_Port3
#define Vortech2 Box1_Port4
#define VortechUPS Box1_Port5
#define Unused3 Box1_Port6
#define DPump1 Box1_Port7
#define DPump2 Box1_Port8
// Initialize Menu
ReefAngel.Relay.On( Vortech1 );
ReefAngel.Relay.On( Vortech2 );
ReefAngel.Relay.On( VortechUPS );
ReefAngel.Relay.Off( Extension );
ReefAngel.Relay.Off( Unused1 );
ReefAngel.Relay.Off( Unused2 );
ReefAngel.Relay.Off( Unused3 );
ReefAngel.CustomVar[7]=255;
ReefAngel.DosingPumpRepeat1( DPump1 );
ReefAngel.DosingPumpRepeat2( DPump2 );
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
powerOutage=false;
LastStart=now();
ReefAngel.CustomVar[1]=0;
ReefAngel.Relay.DelayedOn( Reactor, 10 );
if (InternalMemory.read( Mem_B_Vacation )==1) {
ReefAngel.WaterLevelATO( Extension,30,61,63 );
ReefAngel.CustomVar[3]=1;
ReefAngel.CustomVar[3]=0;
if (InternalMemory.read( Mem_B_RefillATO )==1) {
if (ReefAngel.WaterLevel.GetLevel()<=100) {
ReefAngel.Relay.On( Extension );
ReefAngel.CustomVar[2]=1;
InternalMemory.write( Mem_B_RefillATO, 0);
ReefAngel.CustomVar[2]=0;
acclTime=InternalMemory.read( Mem_B_AcclTime );
if (acclTime > 0) {
ReefAngel.CustomVar[4]=acclTime;
if ( (hour()==0) && (minute()==0) && (second()==0)) {
acclTime--;
InternalMemory.write( Mem_B_AcclTime, acclTime );
sl.SetOffset(-9,riseOffset+(acclTime*240),-9,setOffset+(acclTime*120)); // 9 hour difference
if (isNight)
if ((hour()>=3) && (hour()<=5)) {
// It's Daytime!
if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) floatHigh=true;
isFeeding=false;
feedDelay=true;
setRFtimer(30); // Stay in FeedMode for a while longer.
vtOverride=false;
if(feedDelay) {
feedDelay=false;
if (!floatHigh) {
floatHigh=true;
ReefAngel.CustomVar[0]=0;
floatHigh=false;
// Power Outage - Only Return Pump
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Exp1 Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off (Skimmer);
ReefAngel.Relay.Off (WhiteLEDs);
ReefAngel.Relay.Off (BlueLEDs);
ReefAngel.Relay.Off (Extension);
ReefAngel.Relay.Off (Heater);
ReefAngel.Relay.Off (Refugium);
ReefAngel.Relay.Off (Reactor);
ReefAngel.CustomVar[1]=1;
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
setRFtimer(60);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
speed=55; duration=10; // Short Pulse
speed=55; duration=20; // Long Pulse
speed=50; duration=10; // Smart_TSM
mode=9;
if (!isNight) {
void MenuEntry4()
if (isNight) {
void MenuEntry5()
ReefAngel.OverheatClear();
void MenuEntry6()
void MenuEntry7()
ReefAngel.SetupCalibrateWaterLevel();
void MenuEntry8()
void MenuEntry9()
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// if (isFeeding) { ReefAngel.ClearScreen(DefaultBGColor); return; }
// Main Header
// ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, y,"Lee's Reef");
// Date+Time
ReefAngel.LCD.DrawDate(x+1, y);
// Param Header
y+=12;
// Temp and PH
y+=2;
y+=6;
y+=5;
y+=15; t=x;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
// Display Water level
y+=10; t=x;
ConvertNumToString(buf, ReefAngel.WaterLevel.GetLevel(), 1);
strcat(buf," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"AT0 Level:"); t+=60;
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,t,y,buf);
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
y+=15;
// Relays
ReefAngel.LCD.DrawOutletBox(12, y, TempRelay);
y+=12;
- lnevo
Bugs worked out with Coral Acclimation counter and a lot of comments / code cleanup
//#include <Salinity.h>
//#include <IO.h>
//#include <ORP.h>
//#include <AI.h>
#define CUSTOM_MENU
// Custom Menu Code
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "WLS Calibration";
prog_char menu9_label[] PROGMEM = "Date / Time";
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
// Default Mode
byte vtSpeed=45;
byte vtDuration=5;
// NTM mode
byte vtNTMSpeed=65;
// Night Mode
byte acclTime=0;
SunLocation sl;
#define Mem_B_ClearATO 103
//Define Relay Ports by Name
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Extension 5
#define Heater 6
#define Refugium 7
#define Reactor 8
// Initialize Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit ;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port6Bit;
// Ports that default on
// Ports that default off
sl.Init(-18.285833, 147.699722); // Great Barrier Reef
// What was our previous modes before we restarted?
// Default port modes. Use Memory settings for external control
// See if power is back on so DelayedOn ports will reset.
powerOutage=false;
LastStart=now();
ReefAngel.Relay.DelayedOn( Skimmer );
ReefAngel.Relay.DelayedOn( Reactor );
// We're on vacation! Use external pump to top off the top off.
// Real ATO Clear
if (InternalMemory.read( Mem_B_ClearATO )==1) {
// ATO Refill mode. Top off ATO reservoir until it's at 100%
// See if we are acclimating corals and decrement the countdown each night
static boolean acclCounterReady=false;
if ( acclCounterReady && now()%86400==0) {
acclTime--;
if ( now()%86400!=0 ) acclCounterReady=true;
// -9 hour difference for time zone. 472/506 seconds were calculation corrections
// The acclTime will adjust the sunrise/sunset if we are adjusting for new coral
sl.SetOffset(-9,472+(acclTime*240),-9,506-(acclTime*120));
// Calculate the new Sunrise / Sunset based on our GPS coordinates
if (isNight)
// Some complete darkness
// Set moonlights to the MoonPhase
// Vortech's to night mode.
// Turn on refugium light opposite normal lights
} else { // It's Daytime!
// Regular lights are controlled by Memory variables set in SunLocation class
// Go back to our regularly scheduled program.
// Force the trigger to make sure we break feeding/night modes.
// Enable Feeding Mode flag
// Turn on Refugium light during water change mode
// Enable ATOHigh flag on purpose during feed/water change mode so we don't get alerts.
/*** RF Modes ***/
// Here's what we do if we're just out of feeding mode...
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && isFeeding ) {
isFeeding=false;
feedDelay=true; // This will let us know we want some extra time before Smart_NTM
setRFtimer(30); // Start Smart_NTM in 30 minutes...
} else if (vtOverride && ReefAngel.Timer[1].IsTriggered()) { // Our RF timer is over.
vtOverride=false; // Stop overriding the default RF mode
// First let's deal with that extra 30 minutes
if(feedDelay) {
feedDelay=false; // Reset the feedDelay flag
setRFmode(Smart_NTM,vtNTMSpeed,vtNTMDuration); // Smart_NTM time!
// Otherwise go to Previous settings
setRFmode(); // Update the mode if we change it remotely
// A little extra Smart_NTM never hurt anyone
/*** End of RF modes ***/
// Turn off return pump if we run out of water!
// Turn off return if we are somehow overflowing the sump
if (!floatHigh) {
floatHigh=true;
floatHigh=false;
// Power Outage - Only Return Pump should be active
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
powerOutage=true;
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
// Fix for coming out of night mode
// If it's at night or we are setting NTM, do this only temporarily
setRFtimer(60);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
byte mode,speed,duration;
byte prev_mode,prev_speed,prev_dur;
mode=vtMode;
mode++;
if (mode > 9 ) {
mode=0;
mode=9;
// If it's night time, don't overwrite the default daytime mode when using the menu
if (!isNight) {
void MenuEntry4() {
if (isNight) { // Turn off the Refugium light
} else { // Turn on the Refugium light
void MenuEntry5() {
void MenuEntry6() {
void MenuEntry7() {
void MenuEntry8() {
void MenuEntry9() {
void DrawCustomMain() {
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Date+Time
// Param Header
y+=12;
// Temp and PH
y+=2;
y+=6;
y+=5;
y+=15; t=x;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
y+=10; t=x;
strcat(buf," ");
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
y+=15;
// Relays
y+=12;
void DrawCustomGraph() {
- lnevo
- lnevo
Got my controller,
Ok, figured out what happened. I overwrote the code that reads the timer from memory and updates my CustomVar when I pasted roberto's timer change. So acclTime reverted to 0 and memory was written as 255. Portal showed 0 since I was no longer updating that variable. I will post my fixes and final code tonight.
- lnevo
Ok, more bugs fixed with the acclimation timer and final changes from SunLocation incorporated. Also added a display for the acclimation counter if its active. Some more comments and cleanup.
// Custom Menu Code
// Vortech Defaults
byte vtPrevMode=0;
byte vtPrevSpeed=0;
// Default Mode
byte vtSpeed=45;
byte vtDuration=5;
// NTM mode
byte vtNTMSpeed=65;
// Night Mode
SunLocation sl;
byte acclDay=0;
byte vacationMode=0;
#define Mem_B_ClearATO 101
#define Mem_B_Vacation 102
#define Mem_B_AcclDay 103
#define Var_HighATO 0
#define Var_Power 1
#define Var_Vacation 2
#define Var_AcclDay 3
#define Return 1
#define Skimmer 2
#define WhiteLEDs 3
#define BlueLEDs 4
#define Extension 5
#define Heater 6
#define Refugium 7
#define Reactor 8
// Initialize Menu
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Vortech1);
ReefAngel.Relay.On(Vortech2);
ReefAngel.Relay.On(VortechUPS);
ReefAngel.Relay.Off(Extension);
ReefAngel.Relay.Off(Unused1);
ReefAngel.Relay.Off(Unused2);
ReefAngel.Relay.Off(Unused3);
// Dummy CustomVar to activate portal feature
ReefAngel.StandardHeater(Heater);
ReefAngel.DosingPumpRepeat1(DPump1);
ReefAngel.DosingPumpRepeat2(DPump2);
ReefAngel.StandardLights(WhiteLEDs);
ReefAngel.ActinicLights(BlueLEDs);
powerOutage=false;
LastStart=now();
ReefAngel.CustomVar[Var_Power]=0;
ReefAngel.Relay.DelayedOn(Skimmer);
ReefAngel.Relay.DelayedOn(Reactor);
// Find out if we are on vacation
ReefAngel.CustomVar[Var_Vacation]=InternalMemory.read(Mem_B_Vacation);
vacationMode=ReefAngel.CustomVar[Var_Vacation];
if (vacationMode==1) {
ReefAngel.WaterLevelATO(Extension,30,61,63);
// Real ATO Clear
if (InternalMemory.read(Mem_B_ClearATO)==1) {
InternalMemory.write(Mem_B_ClearATO, 0);
if (InternalMemory.read(Mem_B_RefillATO)==1) {
ReefAngel.Relay.On(Extension);
InternalMemory.write(Mem_B_RefillATO, 0);
if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
acclDay=InternalMemory.read(Mem_B_AcclDay);
ReefAngel.CustomVar[Var_AcclDay]=acclDay;
if (acclDay > 0) {
if (acclCounterReady && now()%SECS_PER_DAY==0) {
acclDay--;
InternalMemory.write(Mem_B_AcclDay,acclDay);
// The acclDay will adjust the sunrise/sunset if we are adjusting for new coral
sl.SetOffset(-9,472+(acclDay*240),-9,506-(acclDay*120));
if (isNight)
if ((hour()>=3) && (hour()<=4)) {
ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
ReefAngel.Relay.On(Refugium);
ReefAngel.Relay.Off(Refugium);
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) ReefAngel.Relay.On(Refugium);
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && isFeeding) {
isFeeding=false;
if(feedDelay) {
if (!floatHigh) {
floatHigh=true;
ReefAngel.CustomVar[Var_HighATO]=1;
ReefAngel.CustomVar[Var_HighATO]=0;
floatHigh=false;
powerOutage=true;
ReefAngel.CustomVar[Var_Power]=1;
ReefAngel.Portal("lnevo");
if (mode!=vtMode) {
vtPrevMode=vtMode;
vtMode=mode;
setRFtimer(60);
vtSpeed=speed;
void setRFmode() {
vtOverride=true;
// Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
mode=vtMode;
mode++;
if (mode > 9) {
mode=0;
mode=9;
// Backup the previous modes. We don't want Night to become default...
if (!isNight) {
void MenuEntry4() {
// Toggle the refugium light if we choose this menu entry.
// Behavior is opposite for night vs day.
void MenuEntry5() {
void MenuEntry6() {
void MenuEntry7() {
void MenuEntry8() {
void MenuEntry9() {
char buf[16];
byte x = 5;
byte y = 2;
byte t;
// Main Header
// Had no room for this anymore :(
// Date+Time
// Param Header
y+=12;
// Temp and PH
y+=2;
y+=6;
y+=5;
y+=12; t=x;
// MoonPhase
y+=10;
// MoonLight %
y+=10;
y+=10; t=x;
strcat(buf," ");
// Vortech Mode
y+=10; t=x;
y+=10; t=x;
y+=10; t=x;
if (acclDay > 0) {
ConvertNumToString(buf, acclDay, 1);
strcat(buf," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); t+=100;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(128-x),y+8);
// Relays
y+=10; t=x+7;
ReefAngel.LCD.DrawOutletBox(t, y, TempRelay);
y+=12;
