ohkie thanks got it....
i use reef angel wizard and on port 7 i have chosen always off soo do i need to get it always on ? or do i need to select ATO ??
sorry this must be too silly questions but i am new to this stuff....
thanks for the help
have a look at the code i think i have written the code at the right place...
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,17,0,21,0 );
ReefAngel.StandardLights( Port2,17,0,21,0 );
ReefAngel.PWM.SetChannel( 0, MoonPhase() );
ReefAngel.PWM.SetChannel( 1, MoonPhase() );
ReefAngel.PWM.SetChannel( 2, MoonPhase() );
ReefAngel.DCPump.SetMode( ShortPulse,20,10 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
ReefAngel.DCPump.ExpansionChannel[1] = Sync;
ReefAngel.DCPump.ExpansionChannel[2] = Sync;
ReefAngel.WaterLevelATO(Port7,50,90,95);
ReefAngel.Portal( "jack" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,49,68, "SAL:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.Salinity,COLOR_DARKKHAKI,73,68, 10 );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,82, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,82, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Lunar hub and water level expansion
jack
Re: Lunar hub and water level expansion
yeahhh its working .... thanks roberto and inevo for answering my silly questions :p
soo here comes one more question
i think i am not able to control my Jeabo and moonlights
reason
1) jeabo overflowing the tank with waves soo thinking its running 100%
2) moonlights are not getting off in the morning ... are they suppose to ?
soo here is the pic i have attached where i have pluged the Jeabo and moon light cables...
the first from the left is the dimming modules wire
and the second is jeabo.... the one in middle, next to computer cable
i hope this helps
thanks
reason
i hope this helps
thanks
- lnevo
Do you have a dimming expansion? All your ports are set to MoonPhase()
That could be interfering. Is your wifi module setup? What does the portal show for your DCPump settings (under Internal memory...)
jack
My reefangelid:
jack
Connection Status:
Unreachable Address
Last Update:
20 September 2013 5:46:36 PM GMT+05:30
Displaying data from:
Webbanner database
this is what my portal says now...
i am not able to connect... daam
jack
Connection Status:
Unreachable Address
Last Update:
Webbanner database
- lnevo
Ok, well don't panic...
Since the portal received an update from your controller at This means your wifi is working and it's sending data to the portal.
What you need to focus on now is setting up port forwarding. You will need to go into your router configuration and set port 2000 to forward to the IP address of your RA Wifi. This is the address you should have gotten during the setup.
There's a lot of threads on troubleshooting the port forwarding on the forum and on google, but obviously post back here for specific questions.
