Upload Error - Help
catman78
Upload Error - Help
Post by catman78 »
Another error uploading. Sketch compiled correctly. I was trying to load custom main
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x18
avrdude: Send: A [41] . [82] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [00]
avrdude: Recv: . [10]
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00] [20]
avrdude: Send: P [50] [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75] [20]
avrdude: Recv: . [d4] . [8f] . [95] . [0f] . [10]
avrdude: arduino_read_sig_bytes(): (a) protocol error, expect=0x14, resp=0xd4
avrdude: error reading signature data for part "ATMEGA328P", rc=-2
avrdude: error reading signature data, rc=-1
avrdude: Send: Q [51] [20]
avrdude: Recv: 0 [30]
avrdude: stk500_disable(): unknown response=0x30
avrdude done. Thank you.
Re: Upload Error - Help
It seems that either your cable or RA keeps messing with your communication, because you keep having this same problem.
It looks as if the communication starts and in the middle it gets corrupt. It is failing after it starts uploading, right?
catman78
Post by catman78 »
yep, looks like it's running fine, then fails.
I've tried several different usb ports. Unplugged/rebooted controller.
catman78
Post by catman78 »
tried it again and it loaded. I hate intermittent problems...
catman78
Post by catman78 »
Roberto
I keep have problems uploading. It's getting really annoying. I'm disappointed big time.
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
Extra Font - Numbers Only - Huge Font (16x16 pixels)
Date/Time Setup Menu
Standard Menu
Binary sketch size: 30,428 bytes (of a 32,256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM6 -b115200 -D -Uflash:w:C:\Users\Mark\AppData\Local\Temp\build594482832089372293.tmp\sketch_sep11a.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [15]
avrdude: stk500_getsync(): not in sync: resp=0x15
catman78
Post by catman78 »
here's another error.
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
Standard Menu
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM6 -b115200 -D -Uflash:w:C:\Users\Mark\AppData\Local\Temp\build5843165608912899799.tmp\sketch_sep11a.cpp.hex:i
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: Send: A [41] . [80] [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81] [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [98] [20]
Hardware Version: 3
Firmware Version: 4.0
avrdude: Send: A [41] . [84] [20]
avrdude: Send: A [41] . [85] [20]
avrdude: Send: A [41] . [86] [20]
avrdude: Send: A [41] . [87] [20]
avrdude: Send: A [41] . [89] [20]
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00] [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00] [20]
avrdude: Recv: . [94]
avrdude: stk500_cmd(): programmer is out of sync
Do you have any device that may be trying to use the port or anything, because it looks as the problem is not consistent as you mentioned before.
catman78
Post by catman78 »
no other devices plugged in to USB ports. I've tried quite a few times with no luck uploading.
Changed ports, rebooted, etc.
No Luck
PM me if you want me to look at it
