The number is 935 when out of the water. When I blow in it it goes to 2000+. Thats the same number I get when I put the PVC back in the water to calibrate. After a few days my water level percentge is different even though the water level is the same.
Thanks for the help with the font color.
New System
Re: New System
Yes I used teflon tape.
Re: New System
What I have noticed is. If the sensor times out. Even though I reset the ATO. The water level is screwed up. I have to do a calibration. As long as the ATO pump isnt timed out. The water level works fine. Is that something that can be fixed?
Re: New System
No but I will this weekend and see if that helps.
