Hi again! If my diming port output voltage are 1-10V (during the port operation) then my RA is analog signal?
And if is 10V (during the port operation) stabilization then my RA is PWM?
Preloaded code and change...
Re: Preloaded code and change...
And something else. Τhe PWM led driver work with analog signal and the opposite??
http://www.reefangel.com/Product_PWMvsAnalog.aspx
When measured with a standard multimeter, you can't tell which signal you have.
They both show the same voltage. You need a scope to see the signal.
The drivers will work with another signal, but you won't get a very good dimming linearity. It's best to use the correct one.
Ok! I understand!!!!Thanks
