Error Uploading
Re: Error Uploading
yes i did im still getting the error thanks for your help by the way
Re: Error Uploading
Can you copy and paste the errors in red you are getting??
Not the wizard error.... Try to upload any code...
Re: Error Uploading
when trying to verify the is what it reads
Watchdog Timer
Version Menu
Simple Menu
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:11: undefined reference to `setup'
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:14: undefined reference to `loop'
Watchdog Timer
Version Menu
Simple Menu
Re: Error Uploading
heres the what i get when trying to upload a pre-loaded code \
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 38,738 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\paul\AppData\Local\Temp\build5120656404065021473.tmp\RA_Preloaded.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0e]
avrdude: Recv: . [14]
avrdude: stk500v2_getsync(): can't communicate with device: resp=0x01
avrdude done. Thank you.
Watchdog Timer
Version Menu
Dimming Signal
Standard Menu
Re: Error Uploading
Does the controller reboot a few seconds after you hit upload?
Right when the "Rebooting Reef Angel Controller" message shows in the screen.
Re: Error Uploading
Can you take a photo of the usb-ttl cable connector? The one with several colors at the end?
Re: Error Uploading
here it is
sorry its a link the forum wont let me upload the picture
http://i241.photobucket.com/albums/ff19 ... ac25a0.jpg
Re: Error Uploading
It looks like you have it plugged into the wrong pins, although it is not that clear in the pic. The plug should be biased to the right not the left, i.e. the black lead should go to the right most pin.
Re: Error Uploading
Just taken a second look and you are connected correctly. I initially had problems by missing the end pin.
Re: Error Uploading
I am getting this error when trying to upload the InitialInternalMemory on my new RA+. I have selected the correct board, the correct COM port and Checked the cable at least 3 times to make sure it is plugged in properly (black wire to the outside right pin):
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 7,420 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\SMOOTH~1\AppData\Local\Temp\build9041109765076733720.tmp\InitialInternalMemory.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM5
avrdude: Recv:
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
Re: Error Uploading
I tried installing the software on a different computer thinking that there may have been some kind of issue with my desktop running Vista Ultimate 64bit. Installed on my old laptop running xp and I'm getting the exact same error so it's likely either a bad cable or controller board.
Re: Error Uploading
Roberto, I don't have enough posts yet to reply to your pm. I sent you an email earlier from the address I used to place the order. It's an swbell dot net email address.
Re: Error Uploading
You should have enough posts now.smoothdog wrote:Roberto, I don't have enough posts yet to reply to your pm. I sent you an email earlier from the address I used to place the order. It's an swbell dot net email address.
Re: Error Uploading
hmmm i had trouble the other day trying to redo my RA+ using the wizard. it wouldnt upload error plz try again. Going to spend more time today fiddling with it. I may need some help today 8/
Re: Error Uploading
Roberto sent a new cable and all is well now. Great customer service, thanks for the quick response Roberto!
Re: Error Uploading
I've got the same problem. How do I get a new cable?
Re: Error Uploading
Did you check if you have the correct board selected under menu Tools->Board and also the correct COM port under menu Tools->Serial Port?
Re: Error Uploading
Got it working, didn't know I had to upload the memory file.
Re: Error Uploading
This is exactly what I have been getting for the last few hours I have tried to reinstall the software,double checking com port and board, reverting back to default coding ETC.. all I get is the red code at the bottom similar to this all I .. this is my first time trying to use it and have been combing the forum to find a fix without posting but I am at witts end LOL.. Not sure whats going on but the pin is def in the right area and the wizard code verifies and the screen blinks on reboot I will keep trying and hoping I figure it out.smoothdog wrote:I am getting this error when trying to upload the InitialInternalMemory on my new RA+. I have selected the correct board, the correct COM port and Checked the cable at least 3 times to make sure it is plugged in properly (black wire to the outside right pin):
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
Re: Error Uploading
Here is the screen shot. please tell me what the issue is thanks.. I know im new but ive been trying everything I can find to fix this issue and get my RA online unsuccessfully..
Dang I don't know why that IS sooo big. should I be doing it as a jpeg instead? I can change it if needed..sorry
- reef angel issue
- Capture.PNG (113.33 KiB) Viewed 4737 times
Re: Error Uploading
Yes I have the plus. I made sure it was checked in the box along with the right com port.
