Error Uploading
Sebyte
Re: Error Uploading
Post by Sebyte »
Just taken a second look and you are connected correctly. I initially had problems by missing the end pin.
smoothdog
Re: Error Uploading
Post by smoothdog »
I am getting this error when trying to upload the InitialInternalMemory on my new RA+. I have selected the correct board, the correct COM port and Checked the cable at least 3 times to make sure it is plugged in properly (black wire to the outside right pin):
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 7,420 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\SMOOTH~1\AppData\Local\Temp\build9041109765076733720.tmp\InitialInternalMemory.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM5
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude done. Thank you.
Re: Error Uploading
Does the controller reboot?
smoothdog
Re: Error Uploading
Post by smoothdog »
No, it does not.
smoothdog
Re: Error Uploading
Post by smoothdog »
I tried installing the software on a different computer thinking that there may have been some kind of issue with my desktop running Vista Ultimate 64bit. Installed on my old laptop running xp and I'm getting the exact same error so it's likely either a bad cable or controller board. :(
smoothdog
Re: Error Uploading
Post by smoothdog »
Roberto, I don't have enough posts yet to reply to your pm. I sent you an email earlier from the address I used to place the order. It's an swbell dot net email address.
Re: Error Uploading
smoothdog wrote:Roberto, I don't have enough posts yet to reply to your pm. I sent you an email earlier from the address I used to place the order. It's an swbell dot net email address.
You should have enough posts now. :)
dnastynice
Re: Error Uploading
Post by dnastynice »
hmmm i had trouble the other day trying to redo my RA+ using the wizard. it wouldnt upload error plz try again. Going to spend more time today fiddling with it. I may need some help today 8/
smoothdog
Re: Error Uploading
Post by smoothdog »
Roberto sent a new cable and all is well now. Great customer service, thanks for the quick response Roberto!
mason dixon
Re: Error Uploading
Post by mason dixon »
I've got the same problem. How do I get a new cable?
Re: Error Uploading
Did you check if you have the correct board selected under menu Tools->Board and also the correct COM port under menu Tools->Serial Port?
mason dixon
Re: Error Uploading
Got it working, didn't know I had to upload the memory file.
dapg8gt
Re: Error Uploading
Post by dapg8gt »
smoothdog wrote:I am getting this error when trying to upload the InitialInternalMemory on my new RA+. I have selected the correct board, the correct COM port and Checked the cable at least 3 times to make sure it is plugged in properly (black wire to the outside right pin):
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
This is exactly what I have been getting for the last few hours I have tried to reinstall the software,double checking com port and board, reverting back to default coding ETC.. all I get is the red code at the bottom similar to this all I .. this is my first time trying to use it and have been combing the forum to find a fix without posting but I am at witts end LOL.. Not sure whats going on but the pin is def in the right area and the wizard code verifies and the screen blinks on reboot I will keep trying and hoping I figure it out.
dapg8gt
Re: Error Uploading
Post by dapg8gt »
Here is the screen shot. please tell me what the issue is thanks.. I know im new but ive been trying everything I can find to fix this issue and get my RA online unsuccessfully..
Dang I don't know why that IS sooo big. should I be doing it as a jpeg instead? I can change it if needed..sorry
reef angel issue
reef angel issue
Re: Error Uploading
Do you have RA+?
dapg8gt
Re: Error Uploading
Post by dapg8gt »
Yes I have the plus. I made sure it was checked in the box along with the right com port.
