New Reef Angel is Awesome
VSpeck
Post by VSpeck »
I received my reef angel last week and I have started messing with coding some the last couple of days. I read a C++ tutorial but have no prior programming experience. Most of the code came from the forums but the tutorial helped to understand it. Thanks everyone for all the help you have provided without even talking to me yet :lol:
Anyway what i would like is somebody experienced to review my code. I have it controlling the tunzes for now since I cant really mess anything up in the tank with that but I'm scared to put everything on the controller until I have somebody look it over.
I want tunze control with a night mode which seems to be working
I want alk to dose on the hour between 11pm and 3pm the next day for ~1 minute
I dont know how big of a span I should give my heater does this look ok?
Ports are:
1 Heater
2 Cal Doser
3 Alk Doser
4 Return Pump
5 Right Tunze
6 Left Tunze
7 Actinic Leds
8 Mhs
Heres the code I'm using:
    ReefAngel.FeedingModePorts = Port4Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port6Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 841 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
     //Tunze short pulse functions
     byte TunzeShortPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,0,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,0,100);
  if (PulseSync)
    return tspeed;
    ReefAngel.StandardHeater( Port1,807,813 );
    ReefAngel.StandardLights( Port2,19,0,19,17 );
    ReefAngel.StandardLights( Port7,15,0,23,0 );
    ReefAngel.StandardLights( Port8,16,0,22,0 );
   //night mode for tunzes
    if ( (hour() >=23) || (hour() <=12) )
      ReefAngel.PWM.SetActinic( TunzeShortPulse(30,30,10,true) );
      ReefAngel.PWM.SetDaylight( TunzeShortPulse(30,50,5,false) );
      //day mode for tunzes
    ReefAngel.PWM.SetActinic( TunzeShortPulse(30,50,2,true) );
    ReefAngel.PWM.SetDaylight( TunzeShortPulse(30,90,2,false) );
  //Night time alk dosing
   if ( ((hour() >= 23) || (hour() <= 15)) &&
       (minute() == 0) &&
       (second() <= 59) )
      ReefAngel.Relay.On(Port3);
      ReefAngel.Relay.Off(Port3);
    ReefAngel.AddWifi();
Re: New Reef Angel is Awesome
Very good job :)
Looks pretty good.
The only thing I see is this line:
It tells port 2 to turn on at 7:00pm and turn off at 7:17pm
I don't know if this is intended or not, but would like to point out.
VSpeck
Post by VSpeck »
rimai wrote:Very good job :)
Looks pretty good.
Thats what I intended. It is my calcium dosing pump and since it doesnt raise ph I am ok with dosing it all at once. Thanks for looking it over and thanks again for all the help.
Ouch. You should not dose all at once as your calcium is gonna swing up and down. there are functions specific to dosing pumps that you can use instead of lights and you have a controller now so you can spread it out over multiple doses...
VSpeck
Post by VSpeck »
I had it on timers before and have always done it like this.
I had it originally programmed on dosing modes but I prefer it this way. I have talked to many people about it and as long as the calcium is there all day to be consumed it is not as critical that it stays as precise as temp or alk. This is jmho from what i have gathered and how I have run my reefs but thanks for the input.
Thats fine. You can still use the dosing pump function. Or the lights if it suits you better :)
Welcome VSpeck
