also just noticed this coming up on cool term, so it must have been talking tot he controller at some stage
GET /status/submitp.aspx?t1=0&t2=0&t3=0&ph=827&id=aus996&em=72&rem=1&key=&atohigh=0&atolow=0&r=67&ron=0&roff=255&r1=0&ron1=0&roff1=255&pwma=20&pwmd=20&sal=60&phe=0
lost port connection
Re: lost port connection
You are connected to the controller.
You need to have the wifi attachment connected to the usb-ttl cable instead.
That's what we are trying to get configured, right?
The wifi attachment, right?
Yes sorry, have tried both, just gave it another shot this morning. Wifi is flashing quick blue and slow green, have tried the cool term connection with both 9600 and 57600 but its still not sending the $$$ string like it did last time to get the 2.32 coding message, although the controller was plugged back into the tank with PH and temp sensors attached so i might have to retry it again this afternoon when I take it off and put it on the standby relay. I am beginning to think it could be an issue with cool term perhaps?
You don't need the controller to setup the wifi attachment.
Simply plug the wifi attachment into the usb-ttl cable.
ahh, leave it with me, been plugging and unplugging so many things this is where i have been going wrong
Okay so I have activity on both 9600 and 57600
at 9600 I am getting an $$$...ERR: ? - Cmd..<2.32>.
and on 57600 just get 00 E0
Ahhh.
There we go.
You should be able to setup the wifi attachment without messing with Cool Term then.
Use the wifi utility to set it up.
There we go.
Yep cool I will give it a shot tonight, thanks once again for all your help
And once again all is good
Real steep learning curve here, got stop doing things with this on about 3 hours sleep, make too many stupid mistakes
