Need a quick check of my code plz
mason dixon
Post by mason dixon »
I've copy/pasted several snippets of code from here and just want to make sure it is all in the right place and not missing anything
    ReefAngel.FeedingModePorts = Port7Bit;
    ReefAngel.WaterChangePorts = Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port6Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 790 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,9,0,20,0 );//4500
    ReefAngel.StandardLights( Port2,9,0,20,0 );//RB
    ReefAngel.StandardLights( Port3,8,0,23,0 );//Blue 1 & 2, Act, UV
    ReefAngel.StandardLights( Port4,20,0,9,0 );//ATS
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,80,15) );//4500
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,15,100,15) );//RB
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,15,100,15) );//BLUE 1 & 2
    ReefAngel.PWM.SetChannel( 3, PWMParabola(8,0,23,0,15,100,15) );//ACT & UV
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(20,0,10,0,15,70,20,15) );
 if (hour()>20 && hour()<8)
      ReefAngel.PWM.SetActinic(30);
      ReefAngel.PWM.SetDaylight(30);
    //*** Define only one mode ***
    //#define TUNZE_MODE_SINE // sine wave, no pulse
    //#define TUNZE_MODE_LONG // no sine wave, long pulse
    //#define TUNZE_MODE_SHORT // no sine wave, short pulse
    //#define TUNZE_MODE_LONGSINE // sine wave, long pulse
    #define TUNZE_MODE_SHORTSINE // sine wave, short pulse
    #define TUNZE_MIN 30
    #define TUNZE_MAX 85
    #define TUNZE_SINE_SEC 23400
    #define TUNZE_SINE_SYNC false
    #define TUNZE_LONGPULSE_SEC 2
    #define TUNZE_LONGPULSE_SYNC true
    #define TUNZE_SHORTPULSE_MS 500
    #define TUNZE_SHORTPULSE_SYNC true
    //PulseMinSpeed - % for minimal speed
    //PulseMaxSpeed - % for maximum speed
    //PulseDuration - Duration (milliseconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
    //PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
    byte TunzeShortPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
      byte tspeed=0;
      PulseMinSpeed=constrain(PulseMinSpeed,30,100);
      PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
      tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
      if (PulseSync)
        return tspeed;
        return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
    //PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
    byte TunzeLongPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
      byte tspeed=0;
      tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
      if (PulseSync)
        return tspeed;
    byte TunzeSineWave(boolean isleftpump, byte minspeed, byte maxspeed, int period_sec) {
      double x,y;
      x=double(now()%(period_sec));
      x/=period_sec;
      x*=2.0*PI;
      if (!isleftpump) x+=PI; // shift the sine wave for the right pump
      y=sin(x);// y is now between -1 and 1
      y+=1.0; // y is now between 0 and 2
      y/=2.0; // y is now between 0 and 1
      // now compute the tunze speed
      y*=double(maxspeed-minspeed);
      y+=double(minspeed);
      y+=0.5; // for proper rounding
      // y is now between minspeed and maxspeed, constrain for safety
      return constrain(byte(y),30,100);
    void RunTunzes() {
    #ifdef TUNZE_MODE_SINE
        ReefAngel.PWM.SetDaylight(TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC)); // left tunze
        ReefAngel.PWM.SetActinic(TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC)); // right tunze
    #endif
    #ifdef TUNZE_MODE_LONG
        ReefAngel.PWM.SetDaylight(TunzeLongPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_LONGPULSE_SEC,true)); // left tunze
        ReefAngel.PWM.SetActinic(TunzeLongPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_LONGPULSE_SEC,TUNZE_LONGPULSE_SYNC)); // right tunze
    #endif
    #ifdef TUNZE_MODE_SHORT
        ReefAngel.PWM.SetDaylight(TunzeShortPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_SHORTPULSE_MS,true)); // left tunze
        ReefAngel.PWM.SetActinic(TunzeShortPulse(TUNZE_MIN,TUNZE_MAX,TUNZE_SHORTPULSE_MS,TUNZE_SHORTPULSE_SYNC)); // right tunze
    #endif
    #ifdef TUNZE_MODE_LONGSINE
        ReefAngel.PWM.SetDaylight(TunzeLongPulse(TUNZE_MIN,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_LONGPULSE_SEC,true)); // left tunze
        ReefAngel.PWM.SetActinic(TunzeLongPulse(TUNZE_MIN,TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_LONGPULSE_SEC,TUNZE_LONGPULSE_SYNC)); // right tunze
    #endif
    #ifdef TUNZE_MODE_SHORTSINE
        ReefAngel.PWM.SetDaylight(TunzeShortPulse(TUNZE_MIN,TunzeSineWave(true,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_SHORTPULSE_MS,true)); // left tunze
        ReefAngel.PWM.SetActinic(TunzeShortPulse(TUNZE_MIN,TunzeSineWave(TUNZE_SINE_SYNC,TUNZE_MIN,TUNZE_MAX,TUNZE_SINE_SEC),TUNZE_SHORTPULSE_MS,TUNZE_SHORTPULSE_SYNC)); // right tunze
    #endif
    ReefAngel.Portal( "Mason Dixon" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // Parameters
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor( 15, 39, ReefAngel.Params );
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,76, "PHE:" );
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,76, ReefAngel.Params.PHExp );
    // Main Relay Box
    // Date and Time
Re: Need a quick check of my code plz
Try this:
    RunTunzes();
  int x,y;
  x = 15;
  y = 2;
    if ( a>2 ) x = 75;
    if ( a==3 ) y = 2;
    y += 10;
  // Parameters
  // pH Expansion
  // Main Relay Box
  // Date and Time
//will stay at maximum speed for PulseDuration.
  byte tspeed=0;
  if (PulseSync)
    return tspeed;
//stay at maximum speed for PulseDuration.
  byte tspeed=0;
  if (PulseSync)
    return tspeed;
  double x,y;
  x/=period_sec;
  x*=2.0*PI;
void RunTunzes() {
#endif
#endif
#endif
#endif
#endif
mason dixon
Thanks Roberto,
I'd like to add one more snippet of code.
I'd like to use one of the float switches on my display tank to turn off the return pump (port 6) if the overflow is blocked. I won't need to use the 2nd float switch as of now.
Try this:
ReefAngel.Relay.Set(Port6,ReefAngel.HighATO.IsActive());
mason dixon
thanks again, just to be sure, I added that last snippet here
      ReefAngel.Relay.Set(Port6,ReefAngel.HighATO.IsActive());//Turns off return pump if DT is flooding
        RunTunzes();
      int x,y;
      x = 15;
      y = 2;
        if ( a>2 ) x = 75;
        if ( a==3 ) y = 2;
        y += 10;
      // Parameters
      // pH Expansion
      // Main Relay Box
      // Date and Time
      byte tspeed=0;
      if (PulseSync)
        return tspeed;
      byte tspeed=0;
      if (PulseSync)
        return tspeed;
      double x,y;
      x/=period_sec;
      x*=2.0*PI;
    void RunTunzes() {
    #endif
    #endif
    #endif
    #endif
    #endif
Good to go?
no, it has to be on the loop section.
The setup section only happens once when the controller boots up.
mason dixon
Roberto, does my wiring look ok? My lights don't seem to be dimming, they just turn on and off. I'm using the above code.
My whites are on channel 0 on the pwm dimming module. My royal blues are on channel 1. They are hooked up to meanwell drivers, I tried switching the dimming wires around to no avail.
My accent colors are on channel 2 and my act/uv are on channel 3. I'm hooking them up with steves leds drivers. Is my diagram the correct way to hook them up?
Yes, it looks good to me.
mason dixon
Roberto, thanks so much for your help. I tried the above code on the tunzes and don't think it is going to work for my system. How would I code this?
I would like my tunzes to go from 30-60 percent in 3 seconds and back down to 30 in 4 seconds and just keep repeating that during hours 9-14 and 18-20. During hours 14-18 I would like them to go from 30-90 in 3 seconds and back down to 30 in 4 seconds. I would also like the pumps to turn off for 10 minutes while I feed at 10 and at 16:30. At night I would like them to stay at 30 percent between 20 and 9.
Try this:
      if (hour()>=9 && hour()<14)
        ReefAngel.PWM.SetActinic(TunzeLongPulse(30, 60, 4, true));
        ReefAngel.PWM.SetDaylight(TunzeLongPulse(30, 60, 4, true));
      else if (hour()>=14 && hour()<18)
        ReefAngel.PWM.SetActinic(TunzeLongPulse(30, 90, 3, true));
        ReefAngel.PWM.SetDaylight(TunzeLongPulse(30, 90, 3, true));
      else if (hour()>=18 && hour()<20)
It doesn't have the feeding mode turn off though.
mason dixon
Thanks again and just to be sure its in the right place
looks ok to me.
mason dixon
Got the error message "TunzeLongPulse not declared in scope"
Oh, you need to add the function to the end of your code...
These functions are not in the libraries yet.
They will be in the next release, but in the mean time, just add this to the very end of your code after the last }
      byte tspeed=0;
      if (PulseSync)
        return tspeed;
mason dixon
I would like for my tunze pumps to turn off for 10 mins at 10:28am, 11:58pm, 1:28pm, 258pm. How is that coded? Thanks
          byte tspeed=0;
          if (PulseSync)
            return tspeed;
Try this:
  if (now()%37680<600 || now()%43080<600 || now()%48480<600 || now()%53880<600)
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
  byte tspeed=0;
  if (PulseSync)
    return tspeed;
mason dixon
thanks, another question, i was just going through the sunrise/sunset tutorial
does this need to be part of my code?
Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
//End of PWM Expansion Code Header
The code I mentioned above is already doing sunset/sunrise.
mason dixon
Roberto, can you add a bit of code to this please.
I need port 8 on my relay box to come on once every hour for 25 seconds. Otherwise it should be off. Thanks
      byte tspeed=0;
      if (PulseSync)
        return tspeed;
Add this to your loop():
ReefAngel.Relay.Set(Port8,now()%3600<25);
You could also use this:
ReefAngel.DosingPumpRepeat(Port8,0,60,25);
lnevo wrote:You could also use this:
Nice :mrgreen:
mason dixon
Hi Roberto,
I'm redoing a bunch of stuff and started over with the wizard. When I went to compile it, this error message popped up
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
    InternalMemory.OverheatTemp_write( 874 );
    ReefAngel.StandardLights( Port1,12,0,22,0 );
    ReefAngel.StandardLights( Port2,13,0,20,0 );
    ReefAngel.StandardHeater( Port3,760,770 );
    ReefAngel.StandardHeater( Port4,760,770 );
    ReefAngel.StandardLights( Port5,0,0,21,0 );
    ReefAngel.DCPump.SetMode( Constant,50,10 );
Do you have the relay expansion module?
mason dixon
I've just got the main relay box with the 8 outlets actually
You must assign a function to at least one of the ports in the relay expansion.
mason dixon
The wizard doesn't have a way to select that I'm not using an expansion relay box. I only have the main relay box that came with the reefangel.
mason dixon
I figured it out, had expansion selected at the beginning of setup, sorry I'm a doofus
