ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port1,9,0,20,0 );//4500
ReefAngel.StandardLights( Port2,9,0,20,0 );//RB
ReefAngel.StandardLights( Port3,8,0,23,0 );//Blue 1 & 2, Act, UV
ReefAngel.StandardLights( Port4,20,0,9,0 );//ATS
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,80,15) );//4500
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,15,100,15) );//RB
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,15,100,15) );//BLUE 1 & 2
ReefAngel.PWM.SetChannel( 3, PWMParabola(8,0,23,0,15,100,15) );//ACT & UV
ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(20,0,10,0,15,70,20,15) );
ReefAngel.Relay.Set(Port6,ReefAngel.HighATO.IsActive());//Turns off return pump if DT is flooding
if (hour()>=9 && hour()<14)
ReefAngel.PWM.SetActinic(TunzeLongPulse(30, 60, 4, true));
ReefAngel.PWM.SetDaylight(TunzeLongPulse(30, 60, 4, true));
else if (hour()>=14 && hour()<18)
ReefAngel.PWM.SetActinic(TunzeLongPulse(30, 90, 3, true));
ReefAngel.PWM.SetDaylight(TunzeLongPulse(30, 90, 3, true));
else if (hour()>=18 && hour()<20)
ReefAngel.PWM.SetActinic(30);
ReefAngel.PWM.SetDaylight(30);
ReefAngel.Portal( "Mason Dixon" );
