Wizard Update
Paulturner911
Re: Wizard Update
Post by Paulturner911 »
Paulturner911 wrote:I placed it here....
ReefAngel.Relay.DelayedOn( Port1,30 );
ReefAngel.StandardLights( Port2,11,0,23,0 );
ReefAngel.StandardLights( Port3,10,0,22,0 );
ReefAngel.StandardLights( Port5,12,0,19,0 );
ReefAngel.StandardLights( Port6,12,0,19,0 );
ReefAngel.Relay.DelayedOn( Port7,15 );
ReefAngel.StandardLights( Port8,22,0,10,0 );
ReefAngel.StandardLights( Box1_Port2,9,0,19,0 );
ReefAngel.StandardFan(Port2,790,800);
The second line of code is my original setting from the wizard I use to turn them on an hour before the halides come on and an off an hour after.
What is the 8th line of code that refers to box1 port2 9am-7pm? IM not sure where I would have set that?
Looking over these the are starting to mean something! I just have to get used to this. Is there a way to cancel feedmode on the controller once it has started?
What does that 8th line mean?
dmolton
Re: Wizard Update
Post by dmolton »
Paulturner911 wrote: What does that 8th line mean?
StandardLights() is a basic timer function. You give it a port, on hour, on minute, off hour, off minute.
Box1_Port2 refers to the second port on your expansion relay box. Whatever equipment is plugged into that port will turn on at 9:00AM and off at 7:00PM. You probably set it up using the wizard when you got to the screen where you can configure your relay expansion.
Paulturner911
Re: Wizard Update
I did that before I got the unit, then wnet back and "unselected" the expansion module once I realized the relay box is not and expansion. I see! So I can remove that line of code when I add the fan temp code and the ato float codes correct?
dmolton
Re: Wizard Update
Post by dmolton »
Yep
Paulturner911
Re: Wizard Update
ReefAngel.StandardFan(Port1,790,800);
Roberto suggested this for my fan on port2 to turn on after 79....
I would need to change the port# in the code. My question is can I add this in addition to the 2nd line of code which has them as a timed event. Will it work with both?
dmolton
Re: Wizard Update
Post by dmolton »
I believe the 2 lines will conflict with each other and you will run into a scenario where the controller is toggling Port2 on and off very rapidly.
What is purpose of the fan on Port 2? Is the fan keeping your lights cool or keeping your tank water cool?
Best way to figure out how to code the fan behavior is to know what exactly you're trying to accomplish with your fan on port 2, and under what circumstances you want it to turn on and off.
Paulturner911
Re: Wizard Update
dmolton wrote:I believe the 2 lines will conflict with each other and you will run into a scenario where the controller is toggling Port2 on and off very rapidly.
The fans pump air into my canopy with holes in the top convectionish.... It does make the tank run cooler due to evaporative cooling thouh. I always had them on when the halides come on and an hour after the halides turn off, the fans will also. But the other day, I activated a mask and my fans did not runn all day....oops my tank still has not gotten back to normal operating temp.... So I would like them to run in cycle to the MH BUT in case of anything I would like them to ALSO come on at any temp over 79....no matter of the condition of the MH lights. I would think this is possible.
Also when in the iphone app mine shows Lights: N/A why is this?
Thanks a bunch! the people on this forum have been very helpful in helping me understand this whole RA.
Wizard Update
You'll need to custom code that...I would just have the fan temp based though...
