The slashes would NOT work, I got an error during verifying.
I also had an error in my PWM daylight
ReefAngel.PWM.SetDaylight(0) );
should have been
ReefAngel.PWM.SetDaylight(0) ;
But I got through it!!
Before I uploaded it I was going to ask if there is anything simple for screen change or custom menu I should do? I havent read much into them but Im going to start....
Thanks guys, I gotta crawl before I can walk
PWM Readings
PWM Readings
Menus are a little tricky...there's an app to help generate menus though...
Re: PWM Readings
Thanks, Im gonna pass on that right now
Re: PWM Readings
you can at least look at it to understand more. depending on what you customize with the menu, you can reduce the size of your code.Paulturner911 wrote:Thanks, Im gonna pass on that right now
Re: PWM Readings
Why does my moon phase never match what this says??
http://www.calendar-365.com/moon/curren ... phase.html
Re: PWM Readings
https://github.com/reefangel/Libraries/issues/63
http://forum.reefangel.com/viewtopic.php?p=21300#p21300
It should be much closer after patch.
Re: PWM Readings
Thanks! I just got my NEW order for you guys!! Still waiting on my WP40...
Any idea when the new libs gonna be released?
Im thinking I can knock it all out at once (never the case) and get the PWM installed, WP coded and the second moonlight hooked up with the updated libs.
I also read in the PWM manual that there were jumpers that needed to be installed inside the RA? Is this still the case? I didnt see any in my shipment.
