ERROR
cgonser
ERROR
Post by cgonser »
I just got my RA+ today and I am super excited to get it all programmed, BUT every time I run the wizard, I get an error! I have been reading on the forum but dont see any fixes, so I guess for now I am DEAD in the water! I have tried to call Reef Angel but keep getting the voicemail, someone please HELP! Thanks
Dead in the Water
cgonser
ERROR
What error? Can you copy/paste or screenshots?
cgonser
Re: ERROR
Post by cgonser »
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Simple Menu
Binary sketch size: 28,898 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Susan\AppData\Local\Temp\build2992672625348245638.tmp\sketch_feb25b.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
ERROR
You have the wrong board selected. Thats why it says you only have 32mb of memory. Make sure to pick the reefangel+
cgonser
Re: ERROR
Post by cgonser »
sounding like a newbie but I dont know where to do that, I never got a chance to select. Also, I fear this is the PWM RA and I ordered the other type, how can a verify?
cgonser
Re: ERROR
Post by cgonser »
OK, figured out how to switch to RA+ but still unsure of other question
ERROR
It'll have an analog sticker on the relay box if its not pwm
cgonser
Re: ERROR
Post by cgonser »
Ok we are good there ,no Im trying to figure out the wifi attachment....so far no good! lol
cgonser
Re: ERROR
Post by cgonser »
I have wifi connected! Any reason why my temp probe would be reading over 185 degrees??
ERROR
That one i have no comment on...
Re: ERROR
cgonser wrote:I have wifi connected! Any reason why my temp probe would be reading over 185 degrees??
Make sure it's connected properly and that there are no loose wires in the connector. You can also try plugging it into a different temp probe port. Otherwise Roberto might have some other suggestions for you.
Re: ERROR
Did it ever report correct readings?
cgonser
Re: ERROR
Post by cgonser »
rimai wrote:Did it ever report correct readings?
It seemed to be reading right, then within 30 min it was 185!
Re: ERROR
Can you check the wires?
That almost seems one of the wires got broken or shorted.
cgonser
Re: ERROR
Post by cgonser »
I have more than one temp probe and I tried another and temp seems to be correct.. Another question, I can only get the app to pull up info on my iphone when my phone is connected to the in house wifi, not when I am out of the house using the 3G...any ideas?
ERROR
I would refer to the response given on the other thread so we don't give you answers in two places...
aus996
Re: ERROR
Post by aus996 »
either your tank is boiling :-) OR more likely your reading is 18.5 degrees , decimal can be hard to see on the display
